603,893 active members*
3,969 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Is ethernet controller support with linux possible?
Results 1 to 4 of 4
    Jan 2007
    37
    Are there any programs for linux that can support GREX G100 controller over ethernet? As far as i know GREX G100 only works with Mach3 and a plugin.
    Wanted to try out EMC2 software for linux, but it doesn't look like it would work with GREX G100.
    Any ideas?
    Aug 2009
    392
    If there's a plugin for Mach3, It should be possible, in theory, to write a plugin for EMC2. Maybe post something on the EMC forum and see if you can find a programmer or two to work on one.
    Jan 2007
    37
    Wouldn't it be cheaper for me to buy a parallel port controller like G540 and ditch the Grex G100 instead of hiring a programmer to write a g100 plugin for linux?
    Aug 2009
    392
    Quote Originally Posted by Menatep View Post
    Most likely, I was just saying that was the option. I didn't mean as much as hiring a professional as much as seeing if there was somebody who would contribute to the already open-source project. Realistically speaking though, I can't imagine there's a lot of people out there wanting to do what you want, so priorities would be fairly low.
  1. Ethernet
    By TURNER in forum Fanuc
    Last Post: 12-20-2006, 11:36 PM
  2. Ethernet BoB
    By smarbaga in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-01-2006, 02:39 PM
  3. Ethernet - Again
    By 1ctoolfool in forum Haas Mills
    Last Post: 10-25-2006, 08:27 PM
  4. Controller parallel port connected via Ethernet (?)
    By WoodSnarfer in forum CNC Machine Related Electronics
    Last Post: 11-20-2004, 10:48 PM
  5. EMC ( Enhanced Machine Controller ) Linux
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 04-29-2004, 12:07 AM
