587,854 active members*
4,099 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > PlasmaCam > Is this a good price on a plasma cam.
Results 1 to 18 of 18
    May 2007
    5
    It is a used plasma cam with a Thermel Dynamics cutmaster 51. It was bought 3 to 4 years ago. They used it for 1 to 1 1/2 years and how it is in storage.
    I can get it for 3,500.00...
    Is this a good deal.....
    Brian
    Jul 2004
    601
    What's the cutmaster worth, and how many consumables are included?
    On all equipment there are 2 levers...
    Lever "A", and Lever F'in "B"
    May 2007
    5
    Quote Originally Posted by DSL PWR View Post
    The cutmaster is 1,300.00 new. I do not know if it has any consumables with it.
    Brian
    Apr 2005
    80
    what is the location of the table? What state?
    May 2007
    5
    Quote Originally Posted by rpage View Post
    I do not see what this has to do with the question that I ask.
    Jun 2007
    5
    Quote Originally Posted by prerunner68 View Post
    Probably the freight cost to your location so you can have an idea of the overall cost of the purchase...
    Jul 2005
    2415
    You need to check and see if the software comes with it and if the company has the right to sell or give it away. I think there may be a transfer fee on the software that needs to be figured in the price. No other software can be used to the machine.
    Apr 2005
    81
    A new PlasmaCam cost $8000 without a plasma cutter, couldn't you use Mach3 and not worry about transferring the other software?
    $3,500 sounds like a deal.
    Vince
    Mar 2006
    759
    Quote Originally Posted by vcooney View Post
    Vince
    Yes, but then you are left with the daunting task of buying and installing
    1. New servos
    2. New servo drivers
    3. Power supply
    4. BOB
    5. Mach3
    6. Sheetcam (or equivalent CAM program)
    7. Torch height controller
    Because PlasmaCam is all proprietary components, meaning there is not much chance for you to just "plug in" Mach.
    You would basically be buying a bunch of angle steel bolted together for 3500 bucks.
    If you buy it as-is, then you are still left with the software transfer fees and perhaps finding out WHY it was left in storage for so long.
    If you wind up having to replace some of the hardware, then you could easily wind up spending the same amount you would have to purchase a brand new machine elsewhere.
    Just my opinion, of course.
    "If the women don't find you handsome, they should at least find you handy"
    -RedGreen show.
    Apr 2005
    81
    Why would he have to buy new servos?
    I'm not an expert I'm just learning.
    Vince
    Mar 2006
    759
    Vince
    Because the PlasmaCam electronics and hardware are all proprietary, meaning they are designed to work with PlasmaCam's software/hardware, and ONLY PlasmaCam, nothing else.
    There might be a way to make the motors that are already there work with different drivers, but I haven't heard of anyone doing it as of yet.
    In the end, even at the 3500 price, you could build a new machine yourself.
    -RedGreen show.
    Jul 2005
    2415
    Quote Originally Posted by massajamesb View Post
    Stay tuned...........(film at 11:00)
    Tom Caudle
    www.CandCNC.com
    Mar 2006
    759
    Quote Originally Posted by Torchhead View Post
    Tom Caudle
    www.CandCNC.com
    You have piqued my interest, Tom.
    Might I ask what you have up your sleeve?
    -RedGreen show.
    Aug 2005
    828
    He is gana hack plasmaCAM!
    Dennis
    May 2007
    72
    do you have the computer with the software to go with the table? I don't need the plasma machine. I have a td 1000 already
    Dec 2007
    578
    Hello,
    My work here just got a plasmaCam loaned to us. Its been in a BAD(rusting) storage of some sort.We have only had it about 5 days now.I kept getting a motor short problem.Switched axis wires and came to X axis,took of encoder cap and it smells burnt.Took apart servo and shows windings next to shaft burnt.Is there anyway of finding out what kind of servo they use? And use MACH 3 to interface with the plasmaCam control?Or to get an "off the Shelf" motor to use with the plasmaCam?
  17. #17
    May 2007
    428
    Mach should be ok I would think.
  18. #18
    Dec 2007
    578
    Angry
    Any idea on how to find a replacement servo?They have no info on the motor
  1. V19 for 200.00 did I get a good price?
    By nate in forum BobCad-Cam
    Last Post: 12-12-2006, 07:17 PM
  2. Enco 9X20 good price?
    By guzziee in forum Mini Lathe
    Last Post: 03-07-2005, 06:10 AM
  3. Good Price??
    By crow in forum Rhino 3D
    Last Post: 02-16-2005, 02:33 AM
  4. best horizontals for good price ?
    By ben hinchl in forum Uncategorised MetalWorking Machines
    Last Post: 09-03-2004, 04:30 AM
  5. Acme rod - Good price?
    By jeffs555 in forum DIY CNC Router Table Machines
    Last Post: 06-16-2004, 02:12 AM
