587,166 active members*
3,513 visitors online*
Results 1 to 5 of 5
    May 2007
    20
    Is my laser tube ok?
    Hello,
    I have just received my new 80W CO2 laser cutter, but I think that something is not working properly; to cut a piece of 3mm acrylic I have to setup the machine to slow speed and full power. The current meter on the machine moves up to 10mA (i think it's a bit low, because following the manual it would be 25mA).
    So I have taken a video of my tube working...please watch it and tell me if the tube is ok or not
    Paride
    May 2007
    20
    Please help me I don't know what I can do
    I had the exact same problem when I got my laser. It turned out to be either the PCI driver card or a setting within the software. Your meter should and will read about 25ma when everything is working right. On mine, there is a setting when testing that tells the laser how much power to output. I think mine was set to 40 or something like that when I reset it to 100 and then reseated and reinstalled the PCI card everything sprang right to life.
    Mike
    www.classicplayfields.com
    May 2007
    20
    I think that it isn't a problem of the pci card, because when i do the test without the pci card connected the output of the laser is always 10mA I think it is a problem of the power supply...however can you tell me more about this setting?
    May 2007
    250
    Cool Laser machine
    Why don't you talk with vendor? I think that he can reply this problem.
    I buy Laser machine 60 watts from hflaser. When I have some problems. I contact seller directly. He can support me excellent.
    Regards,
    Mongkol
  1. Question About Refilling Laser Tube
    By woodpens in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 03-23-2017, 12:16 PM
  2. Laser Tube Alternative???
    By jmg in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-30-2008, 04:49 AM
  3. Why buy a Laser cutter when you can modify a laser engraver.
    By spacifique1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-13-2007, 08:39 PM
  4. bad laser tube
    By cncadmin in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-04-2007, 04:23 AM
  5. CO2 sealed laser tube
    By jlew in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-30-2007, 05:11 PM
