603,864 active members*
5,553 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > Is it possible to modify factory X5?
Results 1 to 7 of 7
    Jul 2007
    8
    Hello everyone.
    First, sorry for my English: I use a translator software.
    I have thought to ask an X5 + China.
    I have seen that the control box is installed in the rear and the access door is also on the back.
    Is it possible that, at the factory, makes the independent control box to install it on the floor, next to the stand?
    At the same time, eliminate the sloping part of the back cover?
    Thank you.
    Apr 2009
    43
    Quote Originally Posted by pritt View Post
    Hello everyone.
    Thank you.
    I don't think that is a problem. If you have been reading other posts on this forum, you will see that its a strong possibility that the control box will simply fall off the machine and land on floor.
    Jul 2007
    8
    I have not found the posts to which you refer.
    Possible, sure is.
    What I want is to do so at the factory, for three main reasons:
    - Not having to walk by moving the machine, by weight.
    - Do not lose your warranty.
    - Not having to extend cables.
    Regards.
    May 2005
    925
    Hola,
    No creo que en China te hagan la modificacion que estas queriendo hacer, fundamentalmente porque solo arman las maquinas de una sola forma.
    Lo que vos queres hacer es posible, pero vas a tener que realizarlo una vez que tengas la maquina en tu taller.
    suerte!
    Pablo
    ● Distribuidor Syil en Argentina ● "www.syil.com.ar" ●
    Jul 2007
    8
    Gracias por la información y por contestar en castellano.
    Me imaginaba que sería así.
    Es un gran inconveniente, ya que necesito la modificación, por espacio, porque quiero pegar la máquina a la pared y porque quiero hacerle un armario, aparte de poder tener acceso a la electrónica sin tener que mover la máquina.
    Veo que eres distribuidor de Syil en Argentina, ¿por casualidad tienes fotografías de la X5 + en detalle y, sobre todo, de la parte posterior?
    Si además tuvieses con la caja de control desmontada y la carcasa sin instalar (que se vea el armazón), sería estupendo, por hacerme una idea de lo que voy a necesitar.
    Aprovecho el poder hablar en castellano: ¿Hay manuales en castellano?
    De hecho, en la página de Syil (China) tampoco los he encontrado de la X5 + propiamente dicha. Solamente de la X5, en la web americana. En la web de china está el nombre de los archivos, pero sin link.
    Me gustaría ir recopilando información para cuando me llegue.
    Un saludo.
    May 2005
    925
    Hola,
    no, no hay manuales en castellano, yo hice una guia rapida para mach3 en español que esta en nuestro sitio, talvez te pueda ayudar.
    Aca en Argentina vendemos el modelo X5 no el plus, pero salvo el panel de control en el cabezal son mecanicamente iguales.
    Para desarmar la caja de control tenes que sacar dos tornillos de la parte superior del carenado de la maquina y dos desde adentro del tablero en la parte inferior, una vez hecho eso podes separar la caja de control de la maquina, pero tenes el cables hacia los motores que tendras que prolongar.
    Ademas tenes los dos pasacables que van de la caja de control al cabezal de la maquina, esos tambien tendras que prolongar.
    Como te dije, lo que queres hacer se puede y no es complicado, solo tenes que prestar atencion a no empalmar cables equivocados.
    Es una excelente maquina la X5, no te vas a arrepentir. En caso que te interese, aca en Syil Argentina desarrollamos un adaptador para que el control remoto pueda ser usado desde el mach3 y no desde la maquina que te hace perder la referencia. Si te interesa te puedo vender uno.
    Suerte!
    Pablo
    PS: Please excuse the msg exchange in spanish, the user uses google translate to understand english and I tought it would be better for him to read in spanish some quick answers
    Jul 2007
    8
    Gracias por toda la información.
    La modificación pensaba que era más o menos como describes.
    Lo que prefería que lo hiciesen en fábrica, pero sino puede ser, pues me tocará hacerlo a mi.
    Entonces, entiendo que el MPG, ¿no se puede utilizar en modo CNC? Si es así ya me pondría en contacto cuando reciba la máquina a ver cómo lo podemos hacer para comprarte el adaptador.
    Aún tardará la máquina ya que antes de pedirla, estoy esperando a otro compañero español que ha realizado la compra a China (en Europa fue imposible) a ver si le va todo bien y no surge ningún problema: Ya la tiene en España y falta poderla subir a su casa. Si todo le ha ido bien contrataré al mismo forwarder.
    Apologies to all other users for using Spanish, but it is much simpler than English.
  1. Factory service STILL available!!!
    By PGrantz in forum Fadal
    Last Post: 04-09-2010, 04:29 PM
  2. Modify STL in SW
    By DIFF OVER in forum Solidworks
    Last Post: 03-11-2009, 01:54 AM
  3. Factory Orgnizing
    By watzmann in forum Community Club House
    Last Post: 07-21-2006, 08:34 PM
  4. Factory online
    Last Post: 11-30-2005, 11:22 AM
