587,628 active members*
3,474 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Is prestone OK for water cooled spindle
    May 2008
    667
    Hi, like title said, would like to know if I can add some prestone in the water to preserve against bacteria and other contaminant.
    I use distilled water.
    Thanks for your help.
    Jeff
    Jun 2010
    463
    Check with the spindle manufacture, some call of ethylene glycol, others propylene glycol.
    These can react with the cooling fins in the spindle, propylene glycol can react with certain material and cause you issues with breaking down the material and clogging the passages.
  1. water cooled spindle question
    By mccafferty in forum Open Source CNC Machine Designs
    Last Post: 10-07-2009, 08:43 PM
  2. Water cooled spindle
    By i_am_fubar in forum Uncategorised MetalWorking Machines
    Last Post: 05-19-2009, 05:25 PM
  3. Water cooled spindle.
    By Mike F in forum MetalWork Discussion
    Last Post: 04-13-2009, 04:37 PM
  4. Water cooled spindle need ???
    By BFcarbon in forum Commercial CNC Wood Routers
    Last Post: 03-04-2006, 10:05 PM
