587,189 active members*
2,816 visitors online*
IndustryArena Forum > CNC Electronics > Xylotex > Is this same board as xylotex for less $$$?
Results 1 to 15 of 15
    Oct 2006
    64
    Whats the difference betweeen the xylotex board and this one?
    it's $160 bones and i think its bout 140 on ebay
    this ones cheaper and even cheaper than website on Ebay...
    http://www.stepmasternc.com/stepmasternc10606_009.htm
    Mar 2003
    35538
    Based on the specs, it would appear to be based on the same Allegro chip that the Xylotex is.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Oct 2006
    64
    doesnt appear to have the heatsinks on this one? or mabe has some chip heatsinks inline... The curretn and max volts seem to be same, as well as microstepping etc...
    Jul 2006
    1062
    I bought 3 of the sop1's on impulse....Too boring imho.....uneventful wiring and power up...worked straight away without any issues. Total cost £60 and used 3 0.65A 4.7V 4 wire Bipolar steppers from a skip (dumpster) one thing to watch for is loose solder on the PCB (unclean...rings bell) I took a picture at 10x with my microscope and it's an Allegro A3977SLPT rated at 2.5A.....how do they do it in something so small :shrug: Personally I'd never have all my axis on one card (unless it was the cheap 2 axis and I had 2 of em for my lathe ) one blows it's all fubar! I'll post back if I manage to break em :lol:
    Keith
    Apr 2006
    113
    I hope nothing.....I bought one to replace my Xylotex board.....It went out on me and I only bought it in May....the Z went crazy....
    Nov 2006
    85
    Maybee this is a good board for us in Europe? Since we can`t order from Xylotex beacuse their boards not are RoHS complaint...
    Aug 2004
    3215
    it can only handle only up to 30v 2.5a
    Jul 2006
    1062
    Quote Originally Posted by Sperstad View Post
    Personally I recommend a friend in the US to send it as a gift Hell if they wont allow a little non ROHS stuff in they can stop dumping nuclear waste in the sea :lol:
    Keith
    Apr 2006
    113
    they are not ROHS either
    Nov 2006
    85
    Quote Originally Posted by joe2000che View Post
    But Xylotex board are also rated to 2,5 A. And the Xylotex board is rated to 35v, 5v volts more than stepmaster. But will there be a problem using the NEMA 23 269oz stepper motors on the stepmasterboard?
    Dec 2006
    252
    nope.
    I have the Xylotex and 4 - 434oz 2.8a motors I run its vref at 3.5 and after emailing and reading EVERYTHING on the Zylotex site all papers etc etc I found that the xylotex motors both the 269 and the 425 are 2.8amp and run fine on the 3 and 4 axis boards! I ran my other motors on it also no problem.
    SO the assumption (watch out for assumptions) is that this board should have no problem at the 2.5a rating and run those 269oz motors.
    P.S. Xylotex says to run their board at 30v and not to exceed soooo that leads me to believe that tolerances are same and marketing is different.
    Building Stage:[xxxxxxxxxxxxxxxxxxxx] 105%
    Finishing Stage:[xxxxxxxxxxxxxxxxxxx-] 95%
    Feb 2005
    111
    Ok well I live in the USA I am fairly new to diy cnc. I bought a 3 axis board and have a cnc router with 118 oz bi-polar steppers. I need a power supply. Is the xylotex power supply and fan for $50 the best buy? I also have 3 wire limit switches installed on each axis how do I wire them up?
    Jul 2005
    2415
    You may want to look at our low cost Mini-IO series of powered/isolated breakouts. They a direct Xylotex expansion connector and it has all kinds of options including a dandy case that holds all of the MINI-IO option cards and a 3 or 4 axis Xylotex card. A special mounting plate with two wired fans is another piece that makes the single case possible. We also have a matching 20 function hand pendant that plugs into the port2 expansion card.
    I have my table top engraver/router running with a 3 axis unit with all the bells and whistles (Relay Card, Pendant, Single case, remote power supply)
    Check http://www.candcnc.com Click on the top picture of the 4 axis Dual Port Driver unit and it will take you to the page with the finished units and some options.
    Pieces to build your own version of the same thing are at http://www.candcnc.com/Mini-IOProductsChart.htm
    Feb 2007
    632
    Quote Originally Posted by Torchhead View Post
    Hi, I am very interested in the combo box. I can see what the pendant is use for, but what is the purpose of the Mini-IO box. Sorry I am newbie and in the process of setting up a cnc mill. I am particularly interested in the last combo set, i.e. Mini-IO 2 Port Super Combo. at USD350. How is this connected to the xylotex drive controller? Is the 4 axis driver card fitted inside the mini-io case? Or this mini-io box connected via a connector to the xylotex controller box? Thanks.
    Alex
    Feb 2007
    632
    Hi, is this
    XDPSC-2-4 Dual Port Super Combo with XYLOTEX 4 Axis bipolar stepper driver. Includes 24V 5A PSU and Remote Relay (RR2) card w/25 ft DB9 cable AND 20 Function pendant with rotary handwheel (USD575)
    all I need to run my cnc mill? What spec stepper motor do I get? 425oz.in will do?
    Thanks.
