603,374 active members*
4,485 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Is there any sort of chart that can help me with cutting speeds?
Results 1 to 8 of 8
    Jul 2008
    90
    Hi everybody. I was wondering if there is such thing as a quick reference chart for determining the correct rpm and feedrates for a given diameter of tool. Or a book would be fine too. I was hoping for something along the lines of one page dedicated to steel, and a list of common tool diameters and flutes and next to that would be various depths for that tool and correct feed and rpm. For example:
    ALUMINUM
    3/8 inch, 2 flute, cutting depth -0.0625, RPM 3000, max feed rate 20 ipm
    A chart such as this would be very helpful.
    May 2006
    39
    I found one chart for HSS end/slot mills once but cant remember from where.
    Attached Files Attached Files
    Jul 2007
    21
    Speeds
    Thanks for the chart
    Jul 2008
    90
    Thank you for this chart!!! It's what I was looking for. Question though, what is the safe depth for these speeds and feeds?
    Jul 2007
    21
    Depth
    See the top of the chart, it says the depth is equal to the diameter of the cutter, this a standard statement I've seen on many charts. Remember this is only a suggested starting point, you may need to adjust.
    Jul 2008
    90
    Thank you for pointing that out, I missed that.
    May 2008
    26
    Thats a really nice chart................. any chance anyone has a chart like that for wood or foam????
    Oct 2003
    263
    Charts for many materials here, for end milling.
    http://www.niagaracutter.com/techinf...mat/index.html
    Software For Metalworking
    http://closetolerancesoftware.com
  1. What kind of cutting speeds are u running on mild steel?
    By Legion99999 in forum Syil Products
    Last Post: 06-20-2008, 11:34 AM
  2. Cutting Speeds for silver?
    By novacustard in forum MetalWork Discussion
    Last Post: 03-23-2007, 10:33 PM
  3. Speeds for cutting metals relating to pulley size?
    By ZipSnipe in forum Mechanical Calculations/Engineering Design
    Last Post: 06-16-2006, 02:11 AM
  4. feeds speeds and cutting tools
    By replicapro in forum MetalWork Discussion
    Last Post: 09-14-2004, 06:22 PM
  5. What sort of software should I use.
    By ynneb in forum Uncategorised CAM Discussion
    Last Post: 04-12-2004, 02:26 PM
