603,895 active members*
3,050 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > is there any way of testing the power supply without a working tube?
    Jun 2009
    146
    I had a problem with my laser tube where the end of the water supply ring covering the tube lens broke away.
    he laser is no longer firing and I am going to replace the tube. I would like to test the power supply as well to see if there is a problem but am not sure how to test it.
    The machine ammeter no longer registers, is this just because the tube isnt intact or should the ammeter still register a current even without a tube?
    rabbit / ls3040
    The ammeter will not show any current if the tube is missing or destroyed.
    Take care with the PSU, the high voltage could cause fatality also the high voltage may be present on the HT wire for some time after the PSU has been switched off.
    Tweakie.
    CNC is only limited by our imagination.
  1. testing fanuc power supply
    By roni21702 in forum DNC Problems and Solutions
    Last Post: 03-10-2011, 10:55 AM
  2. Testing CO2 power supply
    By pixpop in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 12-20-2009, 03:20 PM
  3. power supply testing
    By Tony611 in forum CNC Machine Related Electronics
    Last Post: 12-09-2009, 04:00 AM
  4. Is it the tube? Or the power supply?
    By SimonArthur in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-20-2008, 06:36 PM
  5. Testing a Power Supply
    By JerryFlyGuy in forum CNC Machine Related Electronics
    Last Post: 03-30-2006, 11:03 PM
