587,333 active members*
3,588 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Is there a quick way to use a Haas Probe to measure width or diameter of work piece
    May 2013
    170
    From time to time I want to do a quick measurement on a work piece to check the width or depth, and I use the slow method of probing the left side of the piece and writing down the that number from my offset page, and then probing the right side and getting out the calculator to determine the difference to give me my width.
    Is there a quicker way that would probe both sides and then display the width right on the screen?
    My haas is running the pre NG controller.
    Thanks,
    Kent
    Re: Is there a quick way to use a Haas Probe to measure width or diameter of work pie
    calipers , micrometers depth micrometer is going to be faster and more accurate . I would never trust measurements taken from the machine that made the part
  1. Haas Work shift Cal/Measure Function
    By Andy128r in forum Haas Machines
    Last Post: 06-01-2022, 06:22 AM
  2. measure result of HAAS Probe
    By tedarentjcn in forum Haas Mills
    Last Post: 04-13-2022, 06:36 PM
  3. Haas TL2 X diameter measure oddity
    By Machoot in forum Haas Lathes
    Last Post: 01-26-2022, 01:16 PM
  4. NEED HELP~~ HAAS SL 20 X DIAMETER MEASURE
    By jjperformance in forum Haas Lathes
    Last Post: 06-20-2017, 06:03 PM
