Re: Is there a way to estimate radial and axial cutting forces of an endmill?
![Quote](images/misc/quote_icon.png)
Originally Posted by
QuinnSjoblom
Trying to determine if a specific rotary table is going to work as a 4th axis for me. Holding torque is the concern. Is there a way to estimate cutting forces from an endmill? I'm milling mostly 7075 aluminum using a carbide 3 flute 37 degree helix endmill, usually rough at 10mm depth, 1mm stepover, 13k rpm, 1500mm/m feed. I need to know what kind of forces are going to act on the stock. Any way to ballpark estimate this?
You can input your info here https://fswizard.com/www/ to get the cutting force after you enter your cut details, just click on the blue bar near the top of the screen to see the cutting force.
Everything in moderation, including moderation.
