after having alot of trouble with the TB6560 boards i'm thinking of buying this set on ebay: http://www.benl.ebay.be/itm/18084063...84.m1423.l2649
it seems these M542 drivers have a better reputation on this forum than the TB6560 controller
is this a wise choice if you don't have a large budget like me?
and is this wiring correct?
also:
- Why is there an aditional 5V connection (under the emergency stop connection) when there is already a 5V power supply given by the USB connector? or is this in case you don't use the USB connector?
- Wich wiring code is correct (upper left top of drawing)??
-> because the website from the seller give these 2 options.
-> or does this not mather as long as you connect the Pul+ to XS, Dir+ to XD, Ena+ to XE and the Pul-/Dir-Ena- to XN?
also:
- the resistors between the controller and the driver, how do you guys connect them? do you just solder them at the end of the wire or what do you do? it seems so fragile to just solder them on the wire and then connect the other end of the resistor to the controller....
-> it also says if using 5V there are no Resistors needed, but in my case is this the 5V of the controller or the 24V for the motors i have to take in to account?
and another question:
- How do my dip switches 1 to 4 need to be when using these motors?
-> Stepper Motor Nema 23 - (57BYGH56-401A) Single-Shaft Stepper Motors 1.26Nm/175oz-in 2.8A
thanks in advance!!
