I was wondering what is the smallest helix bore you can make with an iscar hi feed mill cutting tool? Most tools I use have a min and max of the helix bore that can be made with a particular tool
Maximum helix bore? Are you sure? Minimum should be a the outside cutting diameter plus the inside cutting diameter of the inserts.
