603,333 active members*
3,749 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > ISEL Techno G-Code DaVinci Education Mill
Results 1 to 9 of 9
    Oct 2008
    14
    Hello. My school has a Techno G-Code DaVinci Education Mill for milling out small balsa cars. Recently, the mill has started acting up. When we try milling out a car, the Z axis automatically gos up and the software comments with "Please remove arm from limit switch"
    Is there something wrong with the mill mechanically or is it the G-Code interface program? I had a problem working on another student's car where the CAM software (QuickCAM) gave me the error that the part was created in Inches. Do you think that could be the problem with the mill? We use the metric system (MM) because that is easier to use.
    Right before I left, I performed a test on the mill, a startup test, it worked perfectly and the software reported what the mill was saying.
    I reset the control interface, but have not tried to get the mill to work yet as I had to leave, but I was wondering what you think my problem is.
    For CAD, I use dotCAD, recently renamed to Educator
    http://www.thinkdimensions.com/
    Oh, and I am not the teacher at the school, my teacher asked me to find out more about the mill and what could be wrong. He trusts me 100% with working on the mill.
    Help would be appreciated, Thank You.
    Jan 2007
    723
    I have had several problems working with stepper motor based techno davinci's. It all comes down to their horrible control software. I use software called KAY to control the mill and it works perfect every time. If you have a servo davinci, that is a different animal, the z axis encoder might be broken! There is usually no way to fix the encoder itself if the glass wheel inside it is broken. A replacement can be ordered from techno for $180! I went though the same problems with my LC4896 when I purchased it from e-bay!
    -plug
    Oct 2008
    14
    Well, I solved it. The problem is that the Z Axis stepper motor goes up before it goes down.
    The material was about half an inch off of the jig because of improperly securing it. This took me about an hour to find. After that, the machine did not hit the limit switch. The Z axis went up and hit the limit switch when the execution started.
    Jan 2007
    723
    Good to hear you were able to correct your problem. Check out Galaad to get the most out if that mill.
    P.S.
    I am a tech(shop) teacher!
    Oct 2008
    14
    KAY G-Code interface
    That Kay G-Code interface looks good. I wonder if its possible to make my own G-Code interface, all those interfaces look like they're really old, probably because the window color.
    We are actually going to integrate a computer, well, I am. We just got a whole bunch of Core 2 Duo computers in, and I feel that 1 of them will be a great match for the mill. Just comes down to putting the monitor somewhere.
    Sep 2007
    48
    just got one
    I just got one of those DaVinci Servo. Will K work for the interface?
    Scoob
    Jan 2007
    723
    No, it will only work for the stepper davinci and some of the older controllers. Be happy you have a servo system. They run at least twice as fast as the stepper model and have slightly better free control software.
    http://www.glenspeymillworks.com Techno LC4896 - 2.2Kw Water Cooled Spindle | Moving Table Mill from Omis 3 CMM, 500Lb granite base | Epilog Legend 32 Laser Engraver
    May 2013
    Regarding Kay; has anyone tried any other software? The kay seems to be the best, but the price tag is out of my reach. (especially considering i'm just starting out. It would actually be cheaper for me to retro-fit my davinci with a custom made stepper driver board and an arduino Any help would be greatly appreciated.
    Thanks in advance.
    Al
    Jan 2007
    723
    Quote Originally Posted by alheyne View Post
    Regarding Kay; has anyone tried any other software? The kay seems to be the best, but the price tag is out of my reach. (especially considering i'm just starting out. It would actually be cheaper for me to retro-fit my davinci with a custom made stepper driver board and an arduino Any help would be greatly appreciated. Thanks in advance. Al
    I don't think there is any other software except for technos G code stepper interface.
  1. Techno-Isel Davinci upgrade help
    By Ferny in forum Controller & Computer Solutions
    Last Post: 08-05-2020, 12:25 PM
  2. Techno Isel questions/help
    By LJG in forum Commercial CNC Wood Routers
    Last Post: 05-07-2019, 11:51 PM
  3. Techno Isel Software
    By johnono in forum Commercial CNC Wood Routers
    Last Post: 08-02-2010, 02:31 AM
  4. Techno Isel
    By cuemaker1 in forum Commercial CNC Wood Routers
    Last Post: 12-15-2007, 01:51 AM
  5. Techno Isel
    By wood_donkey in forum Commercial CNC Wood Routers
    Last Post: 04-20-2007, 12:13 AM
