587,223 active members*
3,088 visitors online*
Thread: iso20 vs TTS
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    Re: iso20 vs TTS
    I think the r8 prolight 1000s had toolchangers before TTS even existed. does anybody know what they used originally?
  2. #22
    Dec 2013
    158
    Re: iso20 vs TTS
    So I was able to use a interesting pair of vise grips to grab onto the spindle and torque the drawbar. Sure enough I ran into some bad programming where there was severe chatter and stalling of the spindle. Absent was any sort of pull out or collet slip. The surface finish isn't as good as without the TTS, but I would call it acceptable. So I will be looking at a new solution for tightening the drawbar, and keep my TTS in service.
Page 2 of 2 12
  1. Mill tapers: aprox cutter and materials for ISO10, ISO15, ISO20
    By cncuser1 in forum Mechanical Calculations/Engineering Design
    Last Post: 12-07-2017, 02:24 AM
  2. Designing ISO20 spindle w/ tapered roller bearings and ball bearing stud puller.
    By Roadsidejobshop in forum Vertical Mill, Lathe Project Log
    Last Post: 07-19-2016, 07:52 AM
  3. ISO20 ATC spindle for Mills and Routers
    By dwalsh62 in forum News Announcements
    Last Post: 02-13-2014, 01:38 PM
  4. BT15/ISO15 and BT20/ISO20 Spindle Cartridges.
    Last Post: 08-31-2013, 12:56 PM
  5. ISO20, ISO30, HSK 50 HSK 63????
    By 15mgtar in forum CNC Tooling
    Last Post: 08-21-2010, 02:25 PM
