Our shop has a Machining Systems HMC 200 with a FANUC 18i-M controller. The problem I'm having is intermittently the machine will read the values in the G10 offsets lines in the program but when you look at the work offset screen, the values will be tripled. The machine most often will over travel at this point. Hitting reset and reading the G10 lines again will most always resolve the issue for that instance.
Has anyone seen this type of issue before and have any suggestions for what is causing this? Every program has a M30 at the end and the programs all go back to the top.
