603,872 active members*
3,343 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > issue with vfd and spindle control from Mach3 on Crp4896
    I am having issues with getting the correct settings or wiring to be able to control my spindle from mach3, I have the 4 axis plug and play nema 23 system with a smooth stepper and the vfd is a Huanyang HY02D223B and the spindle that came with it is 2.2kw water cooled. I can turn on the spindle in mach but it just ramps up to 24000 rpm no matter what I input into mach. I have a total of four wires connecting the BOB to the VFD, and I do not have any pots connected to the VFD either. I am not sure where I went wrong, can somebody lend me a hand?
    Thank you in advance of your help.
    Dec 2013
    41
    Re: issue with vfd and spindle control from Mach3 on Crp4896
    I'm not familiar with the BOB used in CNCRP Nema 23 PnP, but have you tried to measure the signal with a multimeter as you adjust the speed? This is of course assuming you're using a 0-10V PWM signal. This would be the first step to trouble shooting. A couple other things to check in Mach3 would be the PWM setting in smoothstepper plugin and the PWM settings under Ports and Pins, Spindle Setup. Not much help, but you haven't provided enough details of exactly what you've done so it's difficult to trouble shoot. Good luck!
    Thank you for your reply, I will give that a try
  1. Spindle control with mach3???
    By ghettoblaster in forum Spindles / VFD
    Last Post: 08-07-2015, 05:15 PM
  2. G540 / Mach 3 issue (PWM weirdness for spindle control)
    By benha in forum Machines running Mach Software
    Last Post: 11-05-2014, 12:01 AM
  3. Issue with spindle RPM control
    By GTFreeFlyer in forum Mach Mill
    Last Post: 12-24-2013, 11:08 PM
  4. Need help with Mach3 PWM Spindle Control
    By B3030 in forum Machines running Mach Software
    Last Post: 12-11-2013, 01:59 PM
  5. New NM-145 arrival spindle control issue
    By rpovey in forum Novakon
    Last Post: 02-01-2012, 01:07 AM
