587,930 active members*
4,130 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > J325 thrust bearing numbers
    Jul 2004
    176
    Does anyone know the part numbers for the Thrust Bearings on the X and Y axis? Looking to replace them and would like to have them in hand before I tear into the mill.
    thanks for any help
    Feb 2009
    6028
    Re: J325 thrust bearing numbers
    Noise or backlash? If just noise, they should have a zerk fitting underneath that silences them right up with lithium grease. Can't help with numbers, never had to change even one set while working for the distributor.
    Sent from my A3-A20FHD using Tapatalk
    Jul 2004
    176
    Quote Originally Posted by underthetire View Post
    Alittle backlash in the "y" so figured since I was doing it, I might aswell do "X". Also chasing a small finish issue in "x" aswell. machining a side cut, go down one way, smooth, go the opposite and alittle chattery. Climb milling, same part, opposite sides.
  1. Ballscrew Bearing/Thrust Bearing Arrangement (G0704)
    By inthebay in forum Benchtop Machines
    Last Post: 02-16-2022, 10:22 PM
  2. top spindle bearing number for a J325
    By cnctoolman in forum Tree
    Last Post: 07-31-2013, 10:25 AM
  3. thrust bearing ?
    By slowlearner in forum Fadal
    Last Post: 07-17-2011, 03:08 PM
  4. X-Axis Thrust Bearing?
    By TurtleRacing in forum Fadal
    Last Post: 05-22-2009, 12:22 AM
  5. Thrust bearing numbers
    By geebee1912 in forum Fadal
    Last Post: 08-25-2007, 06:43 PM
