588,025 active members*
4,711 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > J425 w/Dynapath delta 20
Results 1 to 4 of 4
    Jul 2014
    25
    Hey all you Tree gurus. I have a Journeyman 425 that has the dynapath delta 20 on it. Everything seems to run just fine but I can't seem to get the rs232 port running. I plugged in an rs232 tester(in line light up tester) and got the result in the picture as I attempted to load a program. If I unplug the tester from the machine, pin 2 flashes and seems to be transferring data from the computer. Am I hosed when it comes to program transfer?Attachment 346444
    Sent from my SM-G935T using Tapatalk
    Feb 2009
    6028
    Re: J425 w/Dynapath delta 20
    No, tree had the com port different. Normally you would have pin 2 and 3 crossed, well tree decided to use 2 to 2 and 3 to 3.
    Sent from my SM-T813 using Tapatalk
    Jul 2014
    25
    Is it normal for it to light up immediately upon connection to the control?
    Jul 2014
    25
    For anyone that was having problems with their rs-232 and no wiring seemed to fix it, I fixed mine by replacing the aux board. I called dynapath and they told me that it was common for the line drivers and receivers get wiped out on the board. Just trying to pay it forward.
  1. DNC w/Dynapath Delta 20
    By rr167 in forum DNC Problems and Solutions
    Last Post: 01-11-2019, 08:43 PM
  2. Dynapath delta 10
    By cncrouter in forum Tree
    Last Post: 09-30-2012, 07:32 PM
  3. dynapath delta 20
    By AWALTERS21 in forum Dynapath
    Last Post: 09-29-2012, 06:52 PM
  4. Dynapath Delta 40
    By racear*2865 in forum Dynapath
    Last Post: 01-10-2010, 02:05 PM
  5. dynapath delta 10 help
    By undertowx in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-05-2006, 03:49 PM
