This is probably an easy question, so hopefully someone can point me in the correct direction... I have a Nema23 Stepper from Japan Servo. They have a 6 pin connector on it that I cannot find mate to. Anyone know a vendor that could help me?
Look in the DigiKey catalogue, they usually cover most.
Al.
Albert E.
I did just that, but no luck finding. I suspect I just don't know what the connector name is.
What is the pitch size?
Even if you can get one with half the pitch and use every other pin, which it looks like they are made for twice the pin No's.
There is one made by JST XH series which looks close.
2.5mm pitch or 5mm if every other pin?
Molex also have a similar one.
(It pays to get a hard copy of the catalogue)
Al.
Albert E.
Al_The_Man ... All I can say is Yahoo... You hit it perfectly! XHP-11... Just perfect. Thanks greatly.
Good.
DigiKey has always come through for me.
Al.
Albert E.
I like DigiKey too, but they have so many products, sometimes it is difficult to decide/find the right one. Thanks again.
i have got same motor, it can be unipolar stepper motor two phase,and i defined location of this wire. you can try it
three wire first is phase A
three wire second is pha B
2 nd wire and 5 th wire are common wire and connect to VCC
1 st wire is A1
3 th wire is A2
4 th wire is B1
6 th wire is B2
the define above always correct if you rotate motor to any direction
summary:
1: A1
2: common
3: A2
4: B1
5: common
6: B2
good luck for you!
sry my english is very bad![]()
