586,032 active members*
2,993 visitors online*
Thread: jerky
Page 1 of 3 123
Results 1 to 20 of 57
    Feb 2019
    76
    jerky
    Why does the machine work jerky? Before each line of the program there is such a jerk.
    TNG 2020.02.12
    Attached Files Attached Files
    Mar 2017
    1312
    Re: jerky
    Your Z speed is limited. And because Z moves it sets maximum permissible speed.
    Feb 2019
    76
    Re: jerky
    The speed along the z axis is much lower than the limiting speed. I do not see the logic in such a limited.
    Nov 2015
    260
    Re: jerky
    You have set F to 2500 in the program. Your Z axis can only do F2000.
    I suspect that the machine brakes every time.
    Set program F2500 to F2000, also for X. Then the bucking should theoretically be over.
    Feb 2019
    76
    Re: jerky
    Yes, if you increase the speed limit it will work fine. But even if the z-axis is stationary, the machine will still twitch, this is wrong. I don’t know how the program algorithm works, but it’s wrong.
    May 2008
    266
    Re: jerky
    Try including a G64 command at the top of the program. If your machine defaults to G61, then you will get stuttering - check out the difference in the included gcode reference.
    May 2008
    266
    Re: jerky
    Actually, there might be a bug in the G61/G64 code because G64 seems to be ignored if you swap between these two gcodes.
    However, G64 does work straight after restarting TNG, but not after going to G61 and back again.
    Mar 2017
    1312
    Re: jerky
    G64 expects P value to set tolerance. Without P tolerance set, it should default to value in settings. I'll fix this.
    Feb 2019
    76
    Re: jerky
    Quote Originally Posted by PlanetCNC View Post
    where is it set?
    May 2008
    266
    Re: jerky
    Just try something like G64 P1 and see how it performs.
    Check the Gcode manual the comes with TNG for more info.
    Feb 2019
    76
    Re: jerky
    Why does the machine jerk up and down?
    Mar 2017
    1312
    Re: jerky
    You should try latest version.
    Feb 2019
    76
    Re: jerky
    Nothing has changed. The machine works in jerks, and only at two points. You can watch the simulator yourself.
    Mar 2017
    1312
    Re: jerky
    All issues mentioned in this thread were fixed in version 2020-06-18.
    I don't see any jerks in video. Where are they?
    If you are referring to speed decrease on top of circle it is because your machine can not change direction at set speed without breaking acceleration/deceleration limits. If you look closer at your g-code you'll see it is very rough at circle top.
    Feb 2019
    76
    Re: jerky
    I set the acceleration to 2000 and it still slows down. In these places, there cannot be such large accelerations, the trojectory is very smooth. It's not about acceleration.
    This happens very often(in places where the path consists of segments), the machine starts to decrease the speed where it is not necessary to do it. In artcam changed the accuracy from 0,1 to 0.01 and then nothing helps.
    Mar 2017
    1312
    Re: jerky
    Trajectory is not smooth. It is very rough. In some places direction changes are huge. Direction changes causes accelerations/decelerations which exceed set limits. Larger blend values would normally help but not much in these short zig zag segments.
  17. #17
    Feb 2017
    34
    Re: jerky
    Hello, Anriro! Privet, Brat!
    I can not see any errors in your code. I cannot find short zig zag segments too.
    I'm using "Basic CNC Viewer" for simulation view.
    Accuracy is not important - everything should work smoothly and with an accuracy of 1mm
    But you can try G64 P0.05 command here:
    G43 H1 G0Z40.0000
    M3 S18000
    G64 P0.05
    G0 Z20.0000
    X169.4222 Y651.9709
    G1 Z-0.2944 F1000
  18. #18
    Jun 2017
    143
    Re: jerky
    Anriro,
    Have you updated the software? The setting you posted indicated you are running 20200212. There have been 14 releases made that are newer than this. A lot of bug have been fixed in those as well as new features.
  19. #19
    Aug 2011
    252
    Re: jerky
    I have the same problem, I will not make a new thread if I will get answers here.
    The problem is because at any end of line machine will stop and then start again on new line. There is no settings at witch speed to move from one line to another.
    To manage this I lowered acceleration and jerky moves stopped, but that is not the solution, the machine stop moving at the end of line and start on new line.
    That also prolong execution of program unnecessary.
    It will be nice to have some settings to change feed rate by radius like flat 100%, radius 0.4mm 60%, radius 0.2 mm 40%, no radius (like an angle) 20%.
    There is BLEND in settings but I did not understand what is join angle and break angle, not explained in the manual.
  20. #20
    Feb 2011
    138
    Re: jerky
    I have similar problem at the beginning, think the problem lies in pp from program generating g-code. Redone that in f360 solve my problem.
Page 1 of 3 123
  1. jerky g0 movement
    By Lozzy in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 12-31-2018, 12:51 AM
  2. Syntec a bit jerky
    By nash in forum Chinese Machines
    Last Post: 01-25-2014, 07:16 AM
  3. Jerky 3D motion
    By SScnc in forum DIY CNC Router Table Machines
    Last Post: 05-21-2010, 04:15 AM
  4. Jerky motion
    By Matty Zee in forum G-REX
    Last Post: 03-28-2010, 08:35 AM
  5. Jerky Y axis
    By beamsjr in forum Joes CNC Model 2006
    Last Post: 03-08-2010, 03:57 AM
