587,475 active members*
3,706 visitors online*
Results 1 to 6 of 6
    Jan 2005
    183
    Jerky Movement
    Hi I'm doing some scallop routines in mastercam which output the following moves
    <code>N190 G01 Z.1879 F50.
    N200 X-1.4597 Y1.4908 Z.1871 F145.
    N210 X-1.2639 Y1.2711 Z.1791
    N220 X-1.2711 Y1.2555 Z.1797
    N230 X-1.316 Y1.2084 Z.1831
    N240 X-1.3496 Y1.171 Z.1856
    N250 X-1.3968 Y1.1142 Z.1892
    N260 X-1.4281 Y1.074 Z.1917
    N270 X-1.4671 Y1.02 Z.1948
    N280 X-1.4988 Y.973 Z.1973
    N290 X-1.5379 Y.9097 Z.2006
    N300 X-1.5646 Y.8631 Z.2029
    N310 X-1.5976 Y.8003 Z.2058
    N320 X-1.6275 Y.7376 Z.2085
    N330 X-1.6478 Y.6917 Z.2104
    N340 X-1.6732 Y.6277 Z.2128
    N350 X-1.6948 Y.5667 Z.215
    N360 X-1.715 Y.5022 Z.2172
    N370 X-1.7322 Y.4394 Z.2192
    N380 X-1.747 Y.3766 Z.221
    N390 X-1.7594 Y.3139 Z.2227
    N400 X-1.7694 Y.2511 Z.2242
    N410 X-1.7753 Y.204 Z.2253
    N420 X-1.789 Y.1941 Z.2263
    N430 X-2.0872 Y.2112 Z.2434</code>
    mach 3 runs this really jerky always accelerating and decelerating even in constant velocity, is there a way to fix this, or is there another controller software i should look at?
    Mar 2006
    489
    If you have backlash compensation turned on, those moves will be very jerky.
    Paul
    Oct 2007
    35
    del
    Oct 2007
    35
    I have the same problem. it is accel- and decelaraiting like it is not supposed to. I have tried in different forum but no luck / help.
    I found out to check:
    - check constant velocity
    - shuttle accel 0.001
    - backlash not enabled
    I was thinking if it had anything to do with my second matter: the machine axis can not be zerod by pressing the button. only by autozero!
    I hope to get some help because other than that it is a great prog.
    Leo
    Jun 2003
    125
    There are a few things that affect CV.
    - CV button (make sure your program isn't turning CV off by accident G61/64)
    - shuttle accel (if you have steppers then this needs to be reasonable, if servos then I set it to 0) only affects things when backlash is enabled.
    - backlash (this can be enabled, but you need to set the speed higher than your feedrate for it to work smoothly) If you have steppers then this can cause lost steps. For servos set it at 100% at fly!!
    - All the other settings for CV should be off, and the lookahead needs to be set very high. Art recommends 200 or so.
    -Set the Kernal speed to as low as possible. I have problems at 100Khz, but if you only need 25Khz, then set it there. The program will be much more responsive/smoother.
    Apr 2006
    3498
    "Jerky Movement"
    By seeing the thread name, the first impression in mind was a new Film Release with the name "JERKY MOVEMENT"
  1. Jerky Movement on Interact 1 MK2
    By palikalsi in forum Bridgeport / Hardinge Mills
    Last Post: 04-27-2007, 11:41 PM
  2. Replies: 3
    Last Post: 01-15-2007, 09:23 PM
  3. Jerky Z axis????
    By bill south in forum Benchtop Machines
    Last Post: 09-10-2006, 03:33 PM
  4. Bridges & jerky movements.
    By Moondog in forum Machines running Mach Software
    Last Post: 07-30-2006, 04:28 AM
  5. jerky toolpath from rhino model
    By senor J. in forum Rhino 3D
    Last Post: 02-08-2005, 12:36 AM
