603,344 active members*
3,977 visitors online*
Page 3 of 5 12345
Results 41 to 60 of 89
  1. #41
    Aug 2004
    3215
    Here is a pretty cool folding Base Design Jason Made, His "Joe's CNC Evolution" is a 5x10 machine.
    CNC Moving - YouTube
    Folding CNC Machine - YouTube
    Lifting legs off. - YouTube
    Thanks,
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
  2. #42
    Aug 2004
    3215
    new build
    Mitch's Evolution Machine making first movements.
    Mitch's Joe CNC Evolution Build - YouTube
    Thanks,
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
  3. #43
    Mar 2007
    29
    Once bitten...
    I've emailed joe about this but will post the question here too...
    I just ended a bad relationship with a CNC kit sold by another individual online. Bought it for using Vectric's V Carve Pro and Adpire carving software. I have a lot invested in it but turns out I have to scrap it. The gantry sags and this ruins the carvings. Nothing that can be done other than to haul it to the dump.
    The plan now is to salvage what I can (like the 2.2 kw spindle) and hopefully find another kit that's built better. Is the gantry on the hybrid 4x4 stiff enough to support my spindle w/o drooping? The current machines gantry droops nearly .075".
    I read good things about joes machines here and on other forums, but after getting burned to the tune of over $3k on the current machine I'm just being cautious.
    Thanks for any help.
  4. #44
    Aug 2004
    3215
    The Evolution machine used a 3"x6" beam and several of my members use the water cooled spindle the beam will work very well with what you have.
    One questions what are your motors and electronics, psu included with amps.
    Thanks,
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
  5. #45
    Mar 2007
    29
    I have 3 each 425 oz nema 23 motors, 3 each cw230 drivers, a 30 amp pwr supply, PC w/ mach 3.
  6. #46
    Aug 2004
    3215
    425oz motors will work fine I have used those unipolar motor wired to bi-polar on my original hybrid machine. You will however need another motor and driver as the machine uses 2 motors on the Y-Axis to drive the gantry from both sides, this increases the power to move the gantry, i.e. each motor only moving 1/2 the weight. we just simply slave the axis in mach3 or EMC.
    On the PSU 30 amp is more than enough, I would make sure you use 36v or above, 48v is better of course.
    Thanks,
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
  7. #47
    Aug 2004
    3215
    I think your drivers may be limited to 36v max. so a 36v PSU will work.
    Thanks,
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
  8. #48
    Mar 2007
    29
    I can scrounge another motor and driver and yes the cw230 have 36 volt limits.
  9. #49
    Aug 2004
    3215
    Paul is finishing his build of a 4x8 Evolution machine.
    Thanks,
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
  10. #50
    Dec 2013
    41
    I've e-mailed asking Joe this, but maybe others who've built the Evo 1.0 could weigh in too. What types of more significant tools or machinery are necessary for this build? I'm not looking for sepecifics, but a good general idea to see if this is feasible with the tools I have access too. I know this may be a tough question due to the many ways or different options of building, but any help would be appreciated.
    Tools I currently have:
    Miter Saw
    Reciprocating Saw
    Hand Drill
    Drill Press
    Common Small Tools (Wrenches/Screw Drivers/etc..)
  11. #51
    Aug 2004
    3215
    you should have received and email yesterday. let me know.
    Thanks,
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
  12. #52
    Dec 2013
    41
    Thank you Joe, I most certainly received your e-mail. I unfortunately don't have a welder, so looks like I'll have to come up with some wooden table. I've just purchased the plans and once activated, I'll be rummaging through the forums to get a game plan together.
  13. #53
    Aug 2004
    3215
    Quote Originally Posted by groc426 View Post
    There are several builds with a wooden base and I believe a couple posted a drawing of theirs.
    Thanks,
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
  14. #54
    Dec 2013
    41
    Got the plans and they look great! Can't wait to see the Evo changes on the forums. I'm also hoping to get a lot of good ideas on the tables from the forums. Thanks again Joe!
  15. #55
    May 2011
    8
    Hello everybody
    This is my first post here and my first step towards building a CNC machine. I hope to learn here and build a CNC machine.
    First what is difference between Joes 4x4 Hybrid and Joes Evolution.
    Apart from Machine Hardware, what electronics will be involved.
  16. #56
    Aug 2004
    3215
    Jason's 5x12 Evolution machine built and now Cutting "Joe's Snap E-Chain" for itself.
    Thanks,
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
  17. #57
    Apr 2011
    33
    Has anyone milled aluminum with the Evolution yet? How deep of cuts? How much gantry flex?
    Thanks,
    Jerry
    Boise
  18. #58
    Aug 2004
    3215
    Yes i cut the evolution kits on mine. 3/4" plate aluminum that people are
    using to build theirs.
    Thanks,
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
  19. #59
    Aug 2004
    3215
    Rich, almost has his machine finished, I think there is about 75-80 of the Evolution's built now.
    Joe's EVO CNC upgrade - YouTube
    Thanks,
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
  20. #60
    Aug 2004
    3215
    Re: Joe's CNC 4x4 Evolution 1.0
    Its been a little while since I posted here, there have been a few more machines built and running, here is a quick video of a member who built a 4x8 machine.
    WP 20140504 171951Z - YouTube
    Thanks,
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
Page 3 of 5 12345
  1. Evolution Kit?
    By estes53 in forum Joes CNC Model 2006
    Last Post: 08-05-2013, 06:23 PM
  2. Joe's Evolution
    By fasteddie58 in forum Joes CNC Model 2006
    Last Post: 03-21-2013, 04:55 AM
  3. DMU 70 Evolution
    By Racetec in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 08-10-2011, 06:46 PM
  4. DMU 50 evolution
    By sguru007 in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 12-29-2009, 09:44 PM
