603,960 active members*
2,672 visitors online*
Results 281 to 300 of 1751
Threaded View
joecnc2006 Joe's CNC Model 2006 11-25-2005, 10:48 AM
mvaughn Very nice Joe! I had... 11-25-2005, 08:19 PM
joecnc2006 I have already started... 11-25-2005, 08:38 PM
mvaughn What are the overall... 11-25-2005, 09:18 PM
spalm Nice looking drawings Joe. ... 11-25-2005, 10:04 PM
joecnc2006 Working it out in cadd it is... 11-26-2005, 07:04 AM
CNCRob Looks good Joe. What program... 11-25-2005, 10:19 PM
joecnc2006 thanks, I used Solidworks,... 11-26-2005, 06:53 AM
Putterman Hi Joe If you are looking for... 10-03-2006, 12:49 AM
joecnc2006 Like to see a little more of... 10-03-2006, 05:06 AM
silver4dracs Hey Joe it may be of help to... 10-10-2006, 05:41 AM
sdantonio All of a sudden I see the... 11-25-2005, 11:17 PM
Lionclaw Looks awesome Joe. I can't... 11-26-2005, 09:14 AM
cag How did it turn out? 05-08-2007, 04:16 AM
joecnc2006 If you are refering to the... 05-08-2007, 05:02 AM
sblack cutting sheet aluminum 05-09-2007, 02:11 AM
raverys12 What CAD 06-18-2007, 12:29 PM
kb18951452 Joe can correct me if i am... 06-18-2007, 01:57 PM
acondit Joe, At the rate your... 11-26-2005, 05:31 PM
joecnc2006 Well Hope to get it finished... 11-27-2005, 12:43 AM
joecnc2006 Gantry Upper Torsion Box... 11-27-2005, 12:45 AM
joecnc2006 Motor and Leadscrew Bearing... 11-27-2005, 12:46 AM
joecnc2006 Gantry Lower Torsion Box and... 11-27-2005, 07:29 AM
dan dimock plans 12-08-2006, 06:18 PM
bp092 Dan, plans are free, even the... 12-09-2006, 03:06 AM
walltoddj Nice Job 12-18-2006, 03:58 PM
sdantonio Joe, while you posting can... 11-27-2005, 11:04 PM
joecnc2006 This machine is using the 1"... 11-28-2005, 01:11 AM
joecnc2006 I had already recieved my... 11-28-2005, 01:15 AM
joecnc2006 Well I got tiered of using a... 11-28-2005, 05:28 AM
mvaughn Joe, I'd like to get some... 12-04-2005, 12:31 AM
Lionclaw I got mine from someone on... 12-04-2005, 12:55 AM
ger21 Are the skins on that gantry... 12-03-2005, 12:49 PM
joecnc2006 Everything is glued even the... 12-03-2005, 04:13 PM
Trainhound Looks great Joe! 12-03-2005, 04:58 PM
joecnc2006 Here are the Z Axis Slide... 12-04-2005, 12:23 AM
sdantonio Hi Joe, Do you (or anyone... 12-04-2005, 04:22 AM
joecnc2006 I have never used any, mine... 12-04-2005, 05:48 AM
joecnc2006 The X-Axis Carriage finished... 12-04-2005, 05:49 AM
joecnc2006 Inside the Z Axis Slide. 12-05-2005, 12:05 AM
joecnc2006 Here is the gantry together... 12-05-2005, 12:11 AM
Jason Marsha Good work Joe. Jason 12-05-2005, 02:16 AM
Lionclaw It's looking awesome Joe. It... 12-05-2005, 03:42 AM
joecnc2006 Thanks, Jason It is... 12-05-2005, 04:22 AM
mhiggins Joe, You must have been... 12-07-2005, 04:57 AM
joecnc2006 that would help some left to... 12-07-2005, 05:26 AM
mhiggins I'm still in the early... 12-07-2005, 05:49 AM
joecnc2006 I went to lowes and looked... 12-08-2005, 03:33 AM
sdantonio Hi joe, I saw that you... 12-08-2005, 05:10 AM
sdantonio sorry, hit the wrong button. ... 12-08-2005, 05:16 AM
joecnc2006 Actually USE-ENCO.com is... 12-08-2005, 05:51 AM
joecnc2006 The lovejoys had a ever so... 12-13-2005, 08:19 PM
ger21 The play is (was :) ) to... 12-13-2005, 09:11 PM
joecnc2006 I should not need it in my... 12-13-2005, 09:58 PM
joecnc2006 I just was not satified with... 12-19-2005, 05:25 AM
Lionclaw Pretty nifty Joe. Looks good. 12-19-2005, 08:45 AM
sdantonio Hi Joe, Nice fix on the... 12-19-2005, 02:58 PM
joecnc2006 Thanks, Lionclaw and... 12-19-2005, 04:07 PM
ger21 After moving my gantry back... 12-19-2005, 06:16 PM
spalm “making flats on the... 12-19-2005, 06:27 PM
sdantonio For some reason I thought I... 12-19-2005, 05:11 PM
ger21 No need to sand them, they... 12-19-2005, 06:54 PM
joecnc2006 Yea the Galv. Gas pipe does... 12-19-2005, 08:44 PM
spalm OK, guess I haven’t worked... 12-19-2005, 09:25 PM
joecnc2006 Thanks Steve, I have you,... 12-19-2005, 09:47 PM
ger21 I can't without a lot of... 12-20-2005, 02:02 AM
ger21 I just took a closer look,... 12-20-2005, 03:58 AM
joecnc2006 I am using the gas pipe so... 12-20-2005, 04:01 AM
spalm Definition from Google: ... 12-20-2005, 08:04 PM
joecnc2006 that would explain it, but on... 12-20-2005, 08:10 PM
spalm I know, I just couldn't... 12-20-2005, 08:13 PM
sdantonio I suppose the way to get... 12-20-2005, 10:06 PM
2muchstuff Galvanized is a coating... 12-21-2005, 05:58 AM
joecnc2006 Started on the Bottom Portion... 12-21-2005, 06:29 AM
sdantonio Hi Joe, I'm assuming from... 12-21-2005, 01:30 PM
joecnc2006 you can e-maill it to me if... 12-21-2005, 02:46 PM
ger21 Steven is correct. Without... 12-21-2005, 03:11 PM
spalm Joe, You absolutely have... 12-21-2005, 03:43 PM
joecnc2006 ok i will do it, I understand... 12-21-2005, 04:42 PM
sdantonio Hi Joe, I whipped this... 12-21-2005, 07:01 PM
joecnc2006 Thank you for your input, I... 12-21-2005, 08:25 PM
joecnc2006 I sat down to update all my... 12-22-2005, 10:25 PM
joecnc2006 Finished cutting Large Y Axis... 12-24-2005, 04:42 AM
creative_mind joe2000che, Can you pass... 12-29-2005, 07:03 PM
txcowdog Well now that's just... 12-24-2005, 05:23 AM
randyf1965 Would make a cool... 12-24-2005, 08:49 AM
joecnc2006 Thanks Guys I really... 12-26-2005, 01:07 AM
Jason Marsha Thats a good looking router... 12-26-2005, 10:52 AM
zoltan Hi Joe, Your machine is... 12-29-2005, 08:06 PM
truman Hey Joe I love the way you... 12-30-2005, 02:03 AM
joecnc2006 Thanks, :) Well I took my... 12-31-2005, 09:26 AM
mvaughn Can you post a few pictures... 12-31-2005, 09:04 PM
joecnc2006 Here it is so far i did not... 01-01-2006, 03:33 AM
joecnc2006 Finished it up today, I added... 01-02-2006, 02:00 AM
ger21 They sure end up a lot... 01-02-2006, 02:01 AM
truman If I wasn't making mine out... 01-02-2006, 02:08 AM
joecnc2006 Yes with out a doubt :) ... 01-02-2006, 02:23 AM
sdantonio Joe, Great job, looks really... 01-03-2006, 05:18 AM
joecnc2006 Yes you are correct they are... 01-03-2006, 05:25 AM
sdantonio Right now I'm using... 01-04-2006, 06:54 PM
joecnc2006 I can save the edrawings to... 01-04-2006, 07:03 PM
sdantonio Joe, that would be great. ... 01-04-2006, 09:15 PM
joecnc2006 mine are the same as jgro, ... 01-04-2006, 09:22 PM
ger21 I made mine 12" for more... 01-05-2006, 12:26 AM
joecnc2006 Here is the New Z Axis... 01-05-2006, 05:15 AM
sdantonio Joe, Thanks again for the... 01-04-2006, 09:42 PM
sdantonio Hi Gerry, I finally... 01-05-2006, 01:38 PM
joecnc2006 I use 0.433 for all the... 01-05-2006, 05:12 PM
jmytyk Hey Joe-- roughly how much... 01-07-2006, 05:26 AM
joecnc2006 so far on this new one i have... 01-07-2006, 05:51 AM
mike hide When the angle is bolted in ,... 01-15-2007, 06:02 PM
ccsparky Thanks Joe and David, the... 01-15-2007, 06:15 PM
joecnc2006 http://www.hightechsystemsllc.... 01-15-2007, 06:53 PM
KPaulJ Joe I would like to thank... 01-07-2006, 10:46 PM
joecnc2006 In that machine i used... 01-07-2006, 10:53 PM
joecnc2006 Finished cutting the Bottom... 01-09-2006, 04:23 AM
johne Joe, I can't stop stareing at... 01-10-2006, 09:29 AM
joecnc2006 Once the torsion box is glued... 01-10-2006, 02:35 PM
joecnc2006 got a chance to finish the... 01-12-2006, 02:26 AM
randyf1965 What did the 3/4" version... 01-12-2006, 03:54 AM
ger21 What size is that box. I... 01-12-2006, 02:38 PM
PaulH If you're still willing to... 01-12-2006, 11:40 PM
joecnc2006 I'm trying to hold off until... 01-12-2006, 11:53 PM
PaulH Understood. Just keep me in... 01-13-2006, 01:49 AM
joecnc2006 I took a video with a webcam... 01-13-2006, 05:58 AM
steptoey What a fantastic cost... 01-07-2008, 01:04 PM
thorsgaard Hey Joe! It's me from the... 01-13-2006, 12:31 AM
xairflyer Joe That is a really nice... 01-18-2006, 01:36 PM
joecnc2006 Thanks, The improvements to... 01-18-2006, 02:02 PM
Bob Cole Absolutely Wonderful 01-21-2006, 03:21 PM
txcowdog Hi Joe, You have so many... 01-22-2006, 07:28 AM
joecnc2006 thanks, I will try it out. ... 01-23-2006, 07:59 PM
eqreservoir Joe, You do great work. I... 01-23-2006, 08:10 PM
joecnc2006 I would like to finish the... 01-23-2006, 08:21 PM
joecnc2006 Well my daughter made a... 01-24-2006, 06:38 AM
lurch Looks great! It makes it... 01-24-2006, 06:57 AM
eqreservoir I like it. That's the colors... 01-24-2006, 08:13 AM
sdantonio Hi Joe, The color scheme... 01-24-2006, 03:48 PM
joecnc2006 Started painting the pieces... 01-27-2006, 09:48 PM
joecnc2006 Made a new X Axis Bearing... 01-28-2006, 02:46 AM
joecnc2006 Well have not posted in a few... 02-04-2006, 05:59 AM
wallyh Very nice Joe, have you put a... 02-04-2006, 09:41 PM
joecnc2006 I'm still trying to figure... 02-04-2006, 10:18 PM
Mr.Chips Good job Joe. And thanks so... 02-05-2006, 12:22 AM
joecnc2006 I can send out the e-drawings... 02-06-2006, 01:58 AM
creative_mind When do you think the... 02-07-2006, 03:04 AM
lurch Can't wait to see these new... 02-07-2006, 03:41 AM
joecnc2006 Ok, I got the E-Drawings done... 02-07-2006, 04:49 AM
ynneb I downloaded your latest PDF.... 02-05-2006, 12:30 PM
wallyh Joe, as far as price is... 02-05-2006, 08:15 PM
whirlybomber I bet the shipping to down... 02-05-2006, 10:57 PM
dgeugene Pour joe2000che Merci pour... 02-06-2006, 08:17 AM
joecnc2006 send me a pm with your email... 02-06-2006, 03:02 PM
gmfoster Joe that set of parts just... 02-06-2006, 05:07 PM
joecnc2006 no pricing suggestions?? 02-06-2006, 09:55 PM
faithblinded Well obviously start with... 02-06-2006, 10:37 PM
Hobbiest Joe...you speak French? Or... 02-07-2006, 05:08 AM
Bob Cole Joe: I down loaded the... 02-07-2006, 01:49 PM
Smackre The files are made for a free... 02-07-2006, 02:09 PM
Bob Cole Wonderful Job Joe 02-08-2006, 01:14 AM
dighsx I would also be interested in... 02-08-2006, 02:06 AM
jdbaker Just like to echo the... 02-08-2006, 05:17 PM
joecnc2006 send me an e-mail :... 02-08-2006, 06:55 PM
joecnc2006 that email must be down it... 02-10-2006, 01:54 AM
cornfed Hi Joe, What would be the... 02-10-2006, 04:24 AM
joecnc2006 the HobbyCNC kit works well... 02-10-2006, 05:19 AM
Fodder1 Metric Users 02-10-2006, 06:06 AM
joecnc2006 the 1/2" MDF measures just... 02-10-2006, 06:58 AM
cornfed Hey Joe, What is the largest... 02-10-2006, 02:08 PM
ger21 I'm pretty sure your 12MM mdf... 02-10-2006, 03:15 PM
joecnc2006 the machine travel is... 02-10-2006, 04:22 PM
jdbaker Your plans look great, it... 02-10-2006, 05:14 PM
joecnc2006 I will see if i can do an... 02-10-2006, 08:59 PM
joecnc2006 Here is a quick Hardware list... 02-12-2006, 07:34 AM
joecnc2006 Putting this together in my... 02-14-2006, 04:52 AM
tinygiants Joe, I am a complete newbie.... 02-15-2006, 05:24 AM
joecnc2006 Some people have asked for a... 02-15-2006, 05:18 PM
tinygiants If I get to the point of ever... 02-15-2006, 09:24 PM
wallyh Your build and drawings look... 02-15-2006, 05:43 PM
joecnc2006 25"x49"x7" 02-15-2006, 05:45 PM
eqreservoir Do you have a parts/price... 02-15-2006, 09:16 PM
cornfed Greetings Joe, I've got my... 02-16-2006, 11:31 PM
joecnc2006 I will be finished with it by... 02-16-2006, 11:45 PM
joecnc2006 Got the Z Axis Bearing Slide... 02-17-2006, 02:25 AM
Fodder1 Hi Joe, I have to say that... 02-17-2006, 03:35 AM
FPV_GTp Hi joe2000 nice piece of... 07-09-2006, 07:34 PM
chuckknigh I like it...I tried to figure... 02-19-2006, 05:33 AM
joecnc2006 are you just refering to the... 02-20-2006, 06:51 PM
scrolleagle Joe, You do great work. I... 02-19-2006, 11:08 PM
joecnc2006 I have not done a set of... 02-20-2006, 06:54 PM
Salty72 Joe, I have just sat and... 02-22-2006, 01:39 AM
AMorgan I liked Joe's New Router so... 02-22-2006, 01:45 AM
CNCRob It is a really nice machine. 02-22-2006, 02:42 AM
cadfish Joe check your pm 02-22-2006, 05:22 AM
eqreservoir Are there kits available? 02-22-2006, 06:04 AM
scrolleagle Hi, Joe Could you send me... 02-22-2006, 09:12 AM
joecnc2006 A Word of causion, Wear... 02-22-2006, 05:41 PM
sdantonio Joe, Your a very lucky... 02-22-2006, 07:03 PM
Fodder1 Eye protection. 02-23-2006, 12:19 AM
eqreservoir Shop Notes magazine has a two... 02-23-2006, 06:28 PM
posix joe don't throw away those... 02-23-2006, 06:46 PM
AMorgan Dobar dan, Posix, you are a... 02-23-2006, 09:39 PM
Madclicker As my brother would say, "At... 02-23-2006, 10:32 PM
posix well, there's an angle :D 02-23-2006, 10:51 PM
joecnc2006 Well I'm embarresed to say I... 02-24-2006, 02:08 AM
aggie_67 Belleville washers 02-24-2006, 04:50 AM
joecnc2006 thought i would empty my... 02-24-2006, 05:28 AM
joecnc2006 I have not tried them 02-24-2006, 05:35 AM
aggie_67 Z Axis Rods 02-24-2006, 09:46 PM
joecnc2006 you could use pipe if you... 02-24-2006, 10:15 PM
joecnc2006 Here is the New E-drawing ... 02-24-2006, 02:16 AM
Wolfspaw Joe: I downloaded the... 02-25-2006, 05:25 PM
joecnc2006 Yes you were right, i must... 02-25-2006, 06:12 PM
litris As I can print with my... 02-25-2006, 06:37 PM
cornfed Hi Joe, I am not very well... 02-27-2006, 10:05 PM
joecnc2006 a bouble 1/2"-10 nuts on each... 02-27-2006, 10:11 PM
cornfed Joe, I get the part about... 02-28-2006, 05:05 AM
joecnc2006 Double nut system... 02-28-2006, 05:34 AM
cornfed EURKEKA!!!!!!! The bulb is... 02-28-2006, 05:49 PM
joecnc2006 the Z Axis is one 5/16" nut,... 02-28-2006, 05:56 PM
ViperTX Joe....you've done a great... 02-28-2006, 05:39 AM
joecnc2006 Thanks you very much, the... 02-28-2006, 05:53 AM
Fodder1 Hi All, Please dont take... 02-28-2006, 06:15 AM
joecnc2006 I have read many of Vipers... 02-28-2006, 06:32 AM
ger21 You can easily spend $150 on... 03-03-2006, 08:40 PM
joecnc2006 don't get discouraged though,... 03-03-2006, 09:58 PM
Lionclaw The costs do add up. I tried... 03-03-2006, 10:15 PM
NIL8r Thanks for all the info. I... 03-04-2006, 01:59 AM
graffixjones Well, this is my first post... 03-06-2006, 05:48 PM
aggie_67 Joke!!! 03-08-2006, 08:01 PM
graffixjones LOL. :D Maybe I did pick a... 03-08-2006, 08:53 PM
NIL8r Joe, Had a thought on this... 03-10-2006, 04:47 PM
joecnc2006 the dust is not a problem... 03-10-2006, 06:01 PM
aggie_67 Hopefully this will be my... 03-10-2006, 08:19 PM
David Da Costa Pipe question 10-28-2006, 06:50 AM
ccsparky Not a pipe man but I believe... 10-28-2006, 02:45 PM
ger21 You can't necessarily figure... 03-10-2006, 04:55 PM
joecnc2006 That is absolutely correct,... 03-10-2006, 05:57 PM
Bowman I find it amusing to compare... 03-28-2006, 07:07 PM
truman I just recieved a set of... 03-28-2006, 07:53 PM
joecnc2006 Thanks, glad they fit good,... 03-28-2006, 09:02 PM
Surgical Joe, check your PM's....... I... 03-30-2006, 05:51 AM
AMorgan Rockler has the 2 1/4 hp... 03-30-2006, 03:41 PM
scott wiggins I don't think that is... 03-30-2006, 05:18 PM
joecnc2006 The M12VC is variable... 03-30-2006, 05:40 PM
Surgical ***Edited for correctness 03-30-2006, 05:30 PM
Madclicker The one on sale for $95 is... 03-30-2006, 05:38 PM
Surgical I should have read the note... 03-30-2006, 05:44 PM
joecnc2006 Out of curiousity (and people... 03-31-2006, 04:48 AM
jmytyk In Progress. With some minor... 03-31-2006, 07:15 AM
mike hide Thinking about it .I have... 03-31-2006, 09:11 AM
mike hide Some further thought I might... 03-31-2006, 04:10 PM
joecnc2006 Looked at your plog, with a... 03-31-2006, 05:59 PM
joecnc2006 mike hide, I get the HDPE... 03-31-2006, 06:07 PM
ger21 Cutting forces are probably... 03-31-2006, 04:23 PM
mike hide With some knowledge of loads... 03-31-2006, 06:10 PM
glnth I would be interested in the... 04-01-2006, 12:08 AM
joecnc2006 I would say there abouts... 04-01-2006, 02:10 PM
wallyh I am in the planning stage,... 03-31-2006, 05:41 PM
scott wiggins My neighbor and I are... 04-01-2006, 02:53 PM
joecnc2006 That was the disassemble of... 04-01-2006, 04:49 PM
glnth Joe what cutter depth do you... 04-01-2006, 11:09 PM
joecnc2006 1/4" 2 flute upspiral at... 04-01-2006, 11:20 PM
dighsx I tell ya the only thing... 04-02-2006, 02:26 PM
joecnc2006 What is the cutting area of... 04-02-2006, 06:18 PM
joecnc2006 Here is a Complete Kit cut... 04-03-2006, 01:20 AM
Surgical 76? Do I win a free kit? 04-03-2006, 02:20 AM
esmiller I count 82, but some you... 04-03-2006, 02:57 AM
joecnc2006 close, sorry no free kit...... 04-03-2006, 04:08 AM
ShayArnett So have you decided on a... 04-03-2006, 02:17 AM
ShayArnett I see 80 but then again its... 04-03-2006, 02:25 AM
rpage I count 84 04-03-2006, 04:45 AM
Madclicker Time to count...NOT. How much... 04-03-2006, 04:52 AM
joecnc2006 Yes that one is for the... 04-03-2006, 05:02 AM
joecnc2006 That is correct... Alot of... 04-03-2006, 04:58 AM
rpage what are you selling the... 04-03-2006, 02:23 PM
joecnc2006 I have a price in mind, some... 04-03-2006, 02:43 PM
vacpress joe, congrats on such a... 04-04-2006, 01:32 AM
joecnc2006 Thats an idea, but i'm not... 04-04-2006, 01:37 AM
wallyh Could you please send me the... 04-04-2006, 08:01 PM
joecnc2006 I have sent the DWG files to... 04-04-2006, 08:51 PM
hines Joe's bada$$ machine 04-05-2006, 07:55 PM
jmytyk For me, your E-drawings you... 04-04-2006, 09:36 PM
wallyh I am seriously thinking about... 04-04-2006, 10:35 PM
vacpress 3/8 ply will almost certainly... 04-04-2006, 10:39 PM
nMotion Plywood is actually... 04-05-2006, 09:51 PM
joecnc2006 sdantonio I have 200oz... 04-05-2006, 10:21 PM
wallyh Thank you for the quick reply... 04-04-2006, 10:52 PM
lemonyx Joe - pls send me the updated... 04-05-2006, 09:11 AM
sdantonio This is from another thread. ... 04-05-2006, 04:46 PM
sdantonio Even better afterthought. ... 04-05-2006, 05:15 PM
GaryM Joe - please send me the... 04-05-2006, 11:49 PM
Surgical Joe how big are the files? I... 04-06-2006, 03:39 AM
eqreservoir Joe Thanks for the DWG files... 04-06-2006, 04:56 PM
cwdance1 I just completed my first... 04-06-2006, 09:52 PM
AMorgan Joe, DHL delivered my CNC... 04-07-2006, 07:07 PM
creative_mind Joe, I am aware that you... 04-08-2006, 05:39 PM
mindstorm88 Joe , Can i get them too... 04-08-2006, 07:42 PM
joecnc2006 Here is the cover page of the... 04-09-2006, 01:00 AM
cornfed Hi Joe, I've been on the... 04-09-2006, 03:59 AM
ShayArnett Hey Joe, Could I get a... 04-09-2006, 06:29 PM
joecnc2006 I finished the Parts List and... 04-10-2006, 01:21 AM
RD&F Joe, I have read and... 04-10-2006, 07:24 PM
scott wiggins Could I get a copy of the... 04-10-2006, 02:18 PM
CurtisU Joe, I've really enjoyed... 04-10-2006, 06:27 PM
joecnc2006 Can you be a little more... 04-10-2006, 06:29 PM
CurtisU Yes, The bearings on your Y... 04-10-2006, 06:54 PM
joecnc2006 Ok maybe its a monday or... 04-10-2006, 09:38 PM
joecnc2006 Ok after getting home... 04-11-2006, 04:40 AM
CurtisU Actually, The more I think... 04-11-2006, 11:31 AM
ShayArnett Thanks for the files. This... 04-11-2006, 02:59 AM
joecnc2006 Nice looking rendering. :) 04-11-2006, 04:30 AM
Salty72 Joe, I have recently... 04-11-2006, 04:57 AM
eqreservoir Joe Thank you for the... 04-11-2006, 06:06 AM
wallyh May I have a copy of the... 04-11-2006, 02:17 PM
joecnc2006 Ok, i have been bombarded... 04-12-2006, 02:57 AM
martink Hey Joe, Missed out on... 04-20-2006, 02:07 AM
cwdance1 Thanks JOE :cheers: 04-12-2006, 03:03 AM
jmytyk flip'in awesom joe! I vote... 04-12-2006, 07:23 AM
joecnc2006 Thanks, and thanks everyone..... 04-12-2006, 01:23 PM
Jason Marsha I'll second that proposal.... 04-12-2006, 11:18 AM
GaryM Thanks Joe 04-12-2006, 12:41 PM
Jamf2 Thank You for your hard work... 04-12-2006, 02:23 PM
Jamf2 Downloaded your drawings and... 04-12-2006, 02:31 PM
mike hide Joe could you list the motors... 04-12-2006, 02:39 PM
Madclicker I don't recommend running... 04-12-2006, 02:54 PM
joecnc2006 As mentioned earlier, I use... 04-12-2006, 03:14 PM
jseiler I just wanted to say thank... 04-12-2006, 09:35 PM
eloid Im a expericanced custom... 04-18-2006, 02:59 AM
joecnc2006 Here is the hardware i use...... 04-18-2006, 03:15 AM
eloid what type of steper is this... 04-18-2006, 03:26 AM
sdantonio John, Most of the HDPE... 04-13-2006, 03:41 AM
joecnc2006 the only other pieces that... 04-13-2006, 03:52 AM
sdantonio Hi Joe, When you get a... 04-18-2006, 03:40 AM
joecnc2006 the 3/4" HDPE is cut with a... 04-18-2006, 04:18 AM
eloid diy 3 axis stepper control... 04-18-2006, 05:32 AM
joecnc2006 Look in the electronic... 04-18-2006, 03:04 PM
vid1900 joe, ive been lurking here... 04-18-2006, 06:43 AM
joecnc2006 Right now, it is more... 04-18-2006, 03:09 PM
oldtimer82 To any of you readers of this... 04-18-2006, 03:19 PM
joecnc2006 your machine is looking... 04-18-2006, 06:18 PM
sdantonio Oldtimer, Nice looking... 04-18-2006, 06:35 PM
vacpress wow. a 49x97" version would... 04-18-2006, 07:57 PM
randyf1965 http://www.profilepowder.com/r... 04-18-2006, 09:23 PM
sdantonio Randy, That would be them... 04-18-2006, 10:39 PM
Salty72 martink where abouts are you... 04-20-2006, 02:52 AM
martink Hi Salty, Another member... 04-20-2006, 03:54 AM
Agro The couplers are easy enough.... 04-20-2006, 05:10 AM
Fodder1 Hi Aussies, 04-20-2006, 06:21 AM
joecnc2006 go ahead this time..... Joe 04-20-2006, 08:05 AM
martink Thanks Joe! :cheers: 04-20-2006, 08:24 AM
litris Please send me it to my also.... 04-20-2006, 03:13 PM
ShayArnett Joe I read in another thread... 04-30-2006, 08:20 PM
joecnc2006 I have been using the CMT... 05-01-2006, 12:28 AM
joecnc2006 I got all of the ACME Thread... 05-01-2006, 04:17 AM
Sanghera Hey Joe, what kind of... 05-01-2006, 06:50 AM
joecnc2006 As far as i Know it is less... 05-01-2006, 01:34 PM
NIL8r Mindstorm88, This is from... 08-17-2006, 03:43 AM
ShayArnett Send me a kit and full... 05-01-2006, 07:35 PM
joecnc2006 I have not had to adjust them... 05-01-2006, 07:55 PM
Salty72 One thing I still have... 05-02-2006, 02:25 AM
spalm “I have been using the CMT... 05-02-2006, 03:55 AM
sdantonio Salty, It's a common... 05-02-2006, 03:59 AM
joecnc2006 Well my machine is both i... 05-02-2006, 04:08 AM
ShayArnett Hrmm... and I was just trying... 05-04-2006, 05:44 PM
sdantonio [QUOTE=ShayArnett] Can't... 05-04-2006, 05:46 PM
sdantonio Joe, definitely post dust... 05-02-2006, 04:27 AM
Salty72 yer I would be interested... 05-02-2006, 04:45 AM
joecnc2006 Well I got the Dust Skit... 05-03-2006, 09:01 AM
mindstorm88 Anyone knows if that dust... 05-04-2006, 04:54 PM
sdantonio If you make the supporting... 05-04-2006, 05:33 PM
CanSir Don't trust their shipping... 05-04-2006, 07:55 PM
joecnc2006 manufactured the dust skirt... 05-05-2006, 07:54 AM
sdantonio Here is another product,... 05-04-2006, 05:37 PM
sdantonio Getting back to the dust... 05-04-2006, 05:51 PM
Jason Marsha Looks good Joe. sdantonio,... 05-05-2006, 11:00 AM
Salty72 what about making the skirt... 05-08-2006, 04:31 AM
sdantonio hi Salty. I was thinking... 05-08-2006, 05:24 PM
Surgical Long story but I was building... 05-09-2006, 04:10 PM
CanSir Do the nuts holding the... 05-13-2006, 01:14 AM
joecnc2006 I use a lockwasher on the end... 05-13-2006, 01:43 AM
HayTay I used Nylock nuts (hex nuts... 05-13-2006, 02:57 AM
joecnc2006 the proper nuts and washers... 05-13-2006, 04:00 AM
HayTay Wow, how could I have missed... 05-13-2006, 01:50 PM
hugo carradini Hello Joe. I just want to... 05-18-2006, 01:30 AM
joecnc2006 [QUOTE=hugo carradini] ... 05-18-2006, 02:55 AM
joecnc2006 Here are some simple work... 05-18-2006, 03:08 AM
cadfish Joe, How much are those... 05-19-2006, 05:48 AM
joecnc2006 I sell the Kit for 700.00... 05-19-2006, 02:15 PM
sdantonio It is quite time consuming. ... 05-23-2006, 03:40 PM
tgreening I see you do a fair amount of... 05-26-2006, 02:56 AM
joecnc2006 you should use an upspiral... 05-26-2006, 03:07 AM
CanSir I'm half-way through building... 05-19-2006, 10:23 PM
Sanghera You'll learn the basics, the... 05-20-2006, 07:05 AM
joecnc2006 People can learn this just by... 05-22-2006, 01:02 PM
Wade Thanks for all the work, and... 05-22-2006, 06:46 AM
cadfish sorry joe, just found out... 05-23-2006, 02:02 AM
joecnc2006 ok, no problem, I thought... 05-23-2006, 02:54 AM
Wade I am mostly collecting design... 05-24-2006, 05:24 AM
zigmart Do the clamps and dust... 05-24-2006, 05:36 AM
joecnc2006 No but you are welcome to the... 05-24-2006, 06:42 AM
hma Hey Joe, Have you any idea... 05-24-2006, 11:41 AM
joecnc2006 I do not have twist in the... 05-24-2006, 06:41 AM
Wade Uhhhh, I'm not talking about... 05-25-2006, 03:27 AM
vacpress wade. closed loop control... 05-25-2006, 03:50 AM
joecnc2006 yes he is talking about a... 05-25-2006, 04:05 AM
Wade Both. The encoder would be... 05-25-2006, 04:09 AM
JonC Joe.. most EXCELLENT... 05-26-2006, 12:24 AM
sdantonio There is another thread on... 05-26-2006, 12:32 AM
txcowdog Has anyone noticed that this... 07-10-2006, 05:45 AM
joecnc2006 Wow, that is a lot of views,... 07-10-2006, 06:27 PM
hugo carradini Hello Joe In the beginning I... 07-10-2006, 05:17 PM
FPV_GTp HI hugo carradini is that... 08-08-2006, 09:37 PM
hugo carradini Hello Joe. Now that I... 07-27-2006, 01:57 AM
joecnc2006 message sent 07-27-2006, 02:02 AM
hugo carradini Thanks 07-27-2006, 02:46 AM
mindstorm88 Hi Joe , I may have... 07-31-2006, 03:18 PM
joecnc2006 cutting area is 24x45x6.5,... 08-01-2006, 03:22 AM
zigmart Bearings measurements 08-01-2006, 08:10 AM
joecnc2006 They are the standard that... 08-01-2006, 03:34 PM
NIL8r I didn't think of that... 08-01-2006, 03:47 PM
jfowlie Joe-- I'm not sure if you... 07-31-2006, 08:48 PM
mindstorm88 JGRO cutting area is about... 08-01-2006, 10:55 AM
joecnc2006 The 30" will be a little... 08-01-2006, 03:36 PM
hugo carradini Hi FVP GTp , yes it is the... 08-10-2006, 06:35 PM
voltsandbolts Joe, would you send me a copy... 08-14-2006, 05:29 PM
Pappy If you are still sending your... 08-14-2006, 11:30 PM
Jojje Bergan Joe, please, can you send a... 08-14-2006, 11:55 PM
Jamf2 Joe Please add my name to... 08-15-2006, 02:13 AM
daltonjl Joe, I want to say thanks... 08-15-2006, 03:43 AM
Wadec hello, How do you convert... 08-15-2006, 06:02 PM
txcowdog This thread now has over... 08-16-2006, 05:39 AM
joecnc2006 Sorry i have not posted... 08-16-2006, 02:02 PM
Jojje Bergan Thanks my friend :wave: 08-16-2006, 02:58 PM
mindstorm88 Thanks Joe my message was... 08-16-2006, 10:25 PM
hugo carradini Hello Joe. Do you think that... 08-17-2006, 03:43 AM
mindstorm88 Thanks NIL8r i had mist that... 08-17-2006, 04:17 AM
zigmart Limit and Home switches 08-19-2006, 11:42 AM
sdantonio Hi John, These are the... 08-19-2006, 01:46 PM
ALAN2525 Shipping MDF / HDPE parts kit... 08-21-2006, 03:14 PM
Jojje Bergan I changed a few things. I can... 08-21-2006, 03:53 PM
Wadec Hello, I am going to make a... 08-21-2006, 05:29 PM
Jojje Bergan I dont know yet, but why not... 08-23-2006, 11:55 AM
Drakkn UK parts 11-01-2006, 12:16 AM
joecnc2006 Since the X-Axis has the... 08-21-2006, 06:08 PM
zigmart Problem? 09-03-2006, 10:46 PM
joecnc2006 Just a note, on your drawing,... 08-21-2006, 06:15 PM
Wadec Thanks for the info Jojje, ... 08-29-2006, 05:22 PM
dighsx Zigmart, I think I've been... 09-04-2006, 11:17 AM
joecnc2006 Does not sound like backlash... 09-04-2006, 03:20 PM
zigmart Joe, I am using sheetcam and... 09-04-2006, 07:06 PM
joecnc2006 Can you elaberate a little... 09-04-2006, 07:38 PM
Bowman Did you check to make sure... 09-05-2006, 04:44 PM
GaryM This same thing happened to... 09-05-2006, 06:21 PM
zigmart thanks I will try these... 09-05-2006, 08:02 PM
*o* I've downloaded the plans... 09-11-2006, 11:21 AM
RyanS Joe this is quite an awesome... 09-12-2006, 08:12 AM
silver4dracs Joe I cannot find any... 09-16-2006, 01:28 AM
NIL8r Haven't built mine yet, but... 09-16-2006, 06:08 PM
joecnc2006 X Axis - 8.00" Y Axis -... 09-17-2006, 06:10 PM
NIL8r Thanks Joe. That's even... 09-17-2006, 09:10 PM
jsage Joe, Just completed... 10-02-2006, 06:26 AM
joecnc2006 Yes it is a lot to read... 10-02-2006, 01:32 PM
jasoncelia Just finished reading all 37... 10-03-2006, 01:02 AM
juan30 That`s a good idea... 10-13-2006, 03:22 PM
joecnc2006 I can see if i can get it... 10-13-2006, 05:03 PM
juan30 JOE, I use mach3 to and y`ve... 10-13-2006, 05:51 PM
cpy911 Does anybody have STEP files... 10-14-2006, 09:56 PM
joecnc2006 here is my mach3mill.xml... 10-15-2006, 03:23 AM
joecnc2006 I have made some slt files,... 10-15-2006, 03:25 AM
cpy911 Are slt files for... 10-15-2006, 03:58 AM
ushesba Hey Joe, I can't seem to... 10-15-2006, 09:11 PM
powerglider I've read this whole thread... 10-16-2006, 12:57 PM
bigz1 Hi Joe Did you put... 10-17-2006, 12:15 AM
joecnc2006 I have all the files zipped... 10-17-2006, 01:36 AM
joecnc2006 To be honest with you i just... 10-17-2006, 01:52 AM
hugo carradini Now will be waiting, hope not... 10-26-2006, 01:57 AM
cpy911 Joe...you da man! Thanks... 10-20-2006, 05:05 AM
truman hey Joe did you get my email... 10-25-2006, 05:05 PM
yohinan Joe I am trying to get ahold... 10-25-2006, 07:58 PM
epineh So is there going to be a... 10-26-2006, 12:30 AM
joecnc2006 email is best: joecnc2006 at... 10-26-2006, 12:36 AM
therios Could someone please send me... 10-26-2006, 05:43 PM
joecnc2006 http://www.filefactory.com/dlf... 10-26-2006, 06:44 PM
jxdunker It looks like this file is... 11-06-2006, 08:06 AM
David Da Costa Thanks William, I did not... 10-28-2006, 03:54 PM
ccsparky Joe's CNC Router 10-28-2006, 04:10 PM
David Da Costa Sounds like we are both at... 10-28-2006, 04:55 PM
ccsparky David, I moved over to... 10-28-2006, 05:38 PM
David Da Costa Joe, what paint did you use... 10-28-2006, 05:18 PM
David Da Costa I am in the process of... 10-28-2006, 05:47 PM
joecnc2006 Sorry, for not posting... 10-28-2006, 07:41 PM
David Da Costa Thanks Joe, one ;) more... 10-28-2006, 08:39 PM
joecnc2006 I nailed mine with a braid... 10-30-2006, 12:47 AM
freakinhuge Hey Joe, I downloaded the... 10-30-2006, 11:44 AM
freakinhuge Nevermind Joe, I... 10-30-2006, 12:37 PM
David Da Costa I believe Joe is using the... 10-30-2006, 03:40 PM
bp092 im thinking of taking on... 10-31-2006, 08:24 PM
joecnc2006 corrisponded with messages as... 11-01-2006, 03:04 PM
bp092 Yes, thanks joe for answering... 11-01-2006, 05:30 PM
nikolaw this is not good splusion for... 11-02-2006, 11:51 AM
joecnc2006 Really can not understand... 11-02-2006, 02:47 PM
joecnc2006 Here are updated bearing... 11-03-2006, 05:47 AM
Joules Hi, another UK member... 11-02-2006, 12:55 PM
bp092 You rock Joe. Could have used... 11-03-2006, 06:06 AM
David Da Costa Thanks Joe, that will be... 11-03-2006, 06:54 PM
bp092 Question, any specific reason... 11-03-2006, 07:31 PM
Drakkn So much information - have... 11-03-2006, 07:56 PM
bp092 Drakkn, it's eDrawings... 11-03-2006, 08:02 PM
Drakkn Thanks bp092 - cant wait to... 11-03-2006, 09:19 PM
bp092 :) I'm going to get a... 11-04-2006, 03:12 AM
David Da Costa I got all my bolts, nuts and... 11-04-2006, 03:16 AM
Madclicker LOL, the standard reply at... 11-04-2006, 04:06 AM
bp092 LOL figures, thanks for the... 11-04-2006, 06:11 AM
joecnc2006 Here are some video, sorry... 11-05-2006, 11:08 PM
bp092 awesome videos joe, :rainfro:... 11-06-2006, 12:23 AM
joecnc2006 Acme is the thread type, not... 11-06-2006, 12:32 AM
David Da Costa Great thanks Joe, it's great... 11-06-2006, 01:57 AM
bp092 Thanks for clearing that up... 11-06-2006, 01:25 AM
bp092 I think people mentioned... 11-06-2006, 02:04 AM
bp092 It's there, just scroll down... 11-06-2006, 10:43 AM
jxdunker I can just get the text, in... 11-06-2006, 11:58 AM
jxdunker found it with firefox!!! the... 11-06-2006, 12:03 PM
joecnc2006 Works with IE 7. and also the... 11-06-2006, 02:21 PM
bp092 If it happens next time just... 11-06-2006, 06:52 PM
bp092 Also I rehosted it for Joe... 11-06-2006, 06:56 PM
David Da Costa I am about to go buy the... 11-06-2006, 07:05 PM
joecnc2006 just make sure it is 60" or... 11-06-2006, 07:45 PM
David Da Costa Thanks Joe. I assume that... 11-07-2006, 02:15 AM
joecnc2006 No, actually the thread... 11-07-2006, 05:03 AM
bp092 joe, ever use home depot for... 11-06-2006, 07:58 PM
silver4dracs Joe nice to see your machine!... 11-06-2006, 10:54 PM
Jojje Bergan How long is the cable between... 11-06-2006, 11:00 PM
wallyh bp092 I had some gas pipe... 11-07-2006, 04:49 AM
David Da Costa Okay - thanks for the... 11-07-2006, 05:04 AM
wallyh bp092 I had some gas pipe... 11-07-2006, 01:51 PM
bp092 Wally, thanks for the advice.. 11-07-2006, 03:17 PM
Drakkn A quick question about using... 11-07-2006, 08:01 PM
joecnc2006 I would imagine 1/2" and... 11-07-2006, 08:28 PM
kosymailman Just checking to see if... 11-07-2006, 11:13 PM
David Da Costa Kosymailman, can't help... 11-08-2006, 12:27 AM
joecnc2006 You should be able to import... 11-08-2006, 01:48 AM
silver4dracs The length of cable is 10' ... 11-07-2006, 11:49 PM
joecnc2006 Lorenzo you going to post a... 11-08-2006, 01:47 AM
silver4dracs Joe I am unable to cure that... 11-09-2006, 01:09 AM
joecnc2006 if the machine is loosing... 11-09-2006, 05:21 AM
mindstorm88 I may have miss it but What... 11-09-2006, 11:52 AM
hugo carradini Hello David. ¿How can I... 11-08-2006, 01:26 AM
joecnc2006 here are the dwg files, and... 11-08-2006, 01:42 AM
David Da Costa Indeed you can import them,... 11-08-2006, 02:13 AM
kosymailman David & Joe, thanks for the... 11-08-2006, 06:39 AM
Tony Mac Hi, VCarve Pro will Open... 11-08-2006, 08:47 PM
joecnc2006 if you do not have a way to... 11-08-2006, 10:47 PM
ger21 You can also try the free... 11-09-2006, 12:20 AM
David Da Costa Joe, I have just finished... 11-09-2006, 07:27 PM
David Da Costa One further question on the... 11-09-2006, 07:59 PM
joecnc2006 I will look at the 7 1/2"... 11-09-2006, 09:18 PM
David Da Costa Thanks Joe, please also... 11-09-2006, 09:40 PM
joecnc2006 yes 8 on the 6", and the 7.5"... 11-10-2006, 03:37 AM
David Da Costa Thanks Joe. 11-10-2006, 03:48 AM
bp092 anyone else receive joe's kit... 11-12-2006, 06:25 PM
ccsparky Yahoooooo, FedEX was good to... 11-14-2006, 04:01 AM
bp092 Awesome, post pics while you... 11-14-2006, 04:05 AM
ccsparky bp092, Thanks! I will... 11-14-2006, 04:16 AM
joecnc2006 Looking forward to seeing... 11-14-2006, 04:47 AM
David Da Costa Can't wait for mine. I... 11-14-2006, 06:16 AM
kosymailman I have ordered some of the... 11-14-2006, 11:01 AM
bp092 Kos, if you're referring... 11-14-2006, 02:04 PM
David Da Costa Guys, you might want to try... 11-14-2006, 06:36 PM
kosymailman Joe, what do you charge for... 11-15-2006, 07:02 AM
joecnc2006 sent you a message. 11-15-2006, 07:19 AM
kosymailman I have a question on the... 11-16-2006, 09:44 AM
mindstorm88 Same quote needed here... 11-16-2006, 12:25 PM
coltey Joe, I have read all 44 pages... 11-16-2006, 09:16 PM
David Da Costa Joe, did you do any prep to... 11-16-2006, 10:05 PM
joecnc2006 i lightly sanded them, just... 11-17-2006, 02:07 AM
joecnc2006 Thought I would post picture... 11-19-2006, 08:13 PM
bp092 lol, look at the bright side,... 11-19-2006, 08:20 PM
David Da Costa Joe I noticed in your picture... 12-06-2006, 02:09 AM
joecnc2006 the X-axis i just never got... 12-06-2006, 02:31 AM
David Da Costa Very neat Joe, but why is'nt... 11-19-2006, 11:09 PM
PaulH Joe, you own the same... 11-19-2006, 11:17 PM
bp092 Yeah bostich makes pretty... 11-19-2006, 11:28 PM
joecnc2006 this is what i am using now... 11-20-2006, 12:33 AM
joecnc2006 Well Been busy, and with the... 11-27-2006, 12:14 AM
bp092 thanks Joe, I have confidence... 11-27-2006, 12:23 AM
David Da Costa ditto that 11-27-2006, 12:28 AM
bp092 Hey Joe, was going to pm you... 12-01-2006, 02:26 AM
joecnc2006 No have not thought about... 12-01-2006, 02:49 AM
bp092 Thanks for the info. Just... 12-01-2006, 05:49 AM
Noogies Has anyone come up with a... 12-04-2006, 03:49 AM
bp092 Pay Joe to cut them? Here,... 12-04-2006, 08:46 PM
Noogies Thanks for the funny... 12-06-2006, 02:21 AM
Rance Joe, Looking at the... 12-05-2006, 01:05 AM
joecnc2006 acually there is a slight... 12-05-2006, 04:33 AM
Madclicker I've found after 7 months of... 12-05-2006, 04:54 AM
bp092 what about using a chemical... 12-05-2006, 04:58 AM
joecnc2006 mine has not compressed. 12-05-2006, 05:05 AM
joecnc2006 since the pipes are not... 12-05-2006, 05:04 AM
mike hide A couple of questions if you... 12-16-2006, 05:52 PM
joecnc2006 the pipe go into the end... 12-16-2006, 07:25 PM
mike hide Thanks for the reply Joe and... 12-16-2006, 10:42 PM
bp092 David, I asked Joe about... 12-06-2006, 02:17 AM
David Da Costa Thanks for the clarification.... 12-06-2006, 03:25 AM
Rance Joe, After thinking about... 12-07-2006, 07:17 PM
ronmark Joe I just discovered this... 12-07-2006, 07:41 PM
David Da Costa Rance, there are four 1/4-20... 12-07-2006, 08:12 PM
Rance Thanks David. That tells me... 12-08-2006, 05:58 PM
dighsx It's funny you guys are... 12-08-2006, 05:58 PM
rbartko Anyone heard from Joe? Tried... 12-10-2006, 11:29 PM
bp092 He's away for the weekend,... 12-11-2006, 12:03 AM
joecnc2006 Well i hope people can... 12-11-2006, 08:24 AM
bp092 The only downside to MDF for... 12-11-2006, 09:57 PM
mike hide I agree with the comments... 12-12-2006, 04:07 AM
Madclicker I built my torsion boxes and... 12-12-2006, 04:24 AM
rbartko Torsion Box modification 12-13-2006, 03:48 AM
Madclicker Not really a modification of... 12-13-2006, 04:05 AM
rbartko Joe, Still can't get a... 12-13-2006, 05:06 AM
BMG I tried also with no avail. ... 12-14-2006, 04:03 AM
joecnc2006 I cleared some messages. ... 12-14-2006, 04:30 AM
mike hide [QUOTE=joe2000che;229733]I... 12-15-2006, 07:23 PM
joecnc2006 Register the Viewer, its... 12-15-2006, 07:52 PM
bp092 http://video.google.com/videos... 12-16-2006, 07:53 PM
Robert M Hi Joe, I’ve just started... 12-17-2006, 12:47 AM
joecnc2006 email me and i will send the... 12-17-2006, 01:30 AM
Robert M done ! Robert 12-17-2006, 02:48 AM
David Da Costa Todd, check post 70 above and... 12-18-2006, 04:26 PM
walltoddj I looked at 70 not much help,... 12-18-2006, 05:37 PM
David Da Costa Yes you need to download the... 12-18-2006, 05:48 PM
walltoddj Not bad still it will not... 12-18-2006, 06:17 PM
Jojje Bergan Look at post #717. 12-18-2006, 06:44 PM
walltoddj Veiwing Files 12-18-2006, 07:52 PM
Robert M SPECIAL THANKS to Joe 12-19-2006, 02:22 AM
Hacksaw I was looking at the pictures... 12-21-2006, 06:38 AM
David Da Costa Hacksaw, I am not sure what... 12-21-2006, 06:55 AM
Hacksaw It turns out I was looking at... 12-23-2006, 05:38 AM
paul3112 File format tools/conversion 12-23-2006, 01:04 PM
joecnc2006 I uploaded the latest files,... 12-25-2006, 06:57 PM
DayneInfo Files in Sketch-up 12-25-2006, 09:38 PM
eqreservoir Files in Sketch-up For... 12-26-2006, 04:56 AM
walltoddj New Drawings 12-26-2006, 06:15 PM
joecnc2006 No they are not diminsioned,... 12-26-2006, 06:34 PM
joecnc2006 Here is a simple and quick... 12-26-2006, 06:38 PM
walltoddj Prints 12-26-2006, 06:54 PM
truman you can just use the... 12-26-2006, 06:42 PM
DayneInfo Part of the problem with... 12-26-2006, 07:31 PM
joecnc2006 you are correct, machine to... 12-26-2006, 09:15 PM
DayneInfo My first router on my machine... 12-26-2006, 09:39 PM
BMG Joe, I downloaded the DWG... 12-27-2006, 03:17 PM
David Da Costa That is correct BMG. The... 12-27-2006, 03:57 PM
joecnc2006 The front and rear pieces are... 12-27-2006, 04:26 PM
gtschance On my kit from Joe .... ... 12-28-2006, 08:10 PM
David Da Costa truman, I have the xylotex... 12-28-2006, 10:10 PM
truman my z axis may be a bit... 12-28-2006, 10:14 PM
joecnc2006 I use the HobbyCNC 200oz kit... 12-28-2006, 10:29 PM
truman 36V 10A as well with an... 12-28-2006, 10:41 PM
bp092 LOL I was wondering where you... 12-31-2006, 04:59 AM
ccsparky Don't feel like the Lone... 12-31-2006, 03:06 PM
bp092 Yes, the design is extremely... 12-31-2006, 06:10 PM
mike hide Joe did you use all 1/2" MDF?... 12-31-2006, 09:58 PM
joecnc2006 the only 3/4" is the back of... 12-31-2006, 10:58 PM
David Da Costa Mike, it is all 1/2" except... 12-31-2006, 10:06 PM
rbartko I have access to alot more... 12-31-2006, 10:43 PM
David Da Costa It might cause issues so I... 12-31-2006, 10:51 PM
bp092 Rich, check around, I would... 12-31-2006, 10:51 PM
rbartko Thanks for the feedback... 12-31-2006, 11:02 PM
bp092 Rich, do you mean all the... 01-01-2007, 12:59 AM
rbartko No, not the hardware in Joe's... 01-01-2007, 03:42 AM
Woodie1 Joe, Can you Email, the... 01-01-2007, 02:32 AM
bp092 Well here is the hardware... 01-01-2007, 11:06 PM
David Da Costa I got the u-bolts via Amazon... 01-01-2007, 11:26 PM
David Da Costa I also got the Hitachi... 01-01-2007, 11:28 PM
jcook40 Hello All I wanted to thank... 01-02-2007, 07:17 AM
David Da Costa Whether the machine has 3d... 01-02-2007, 03:26 PM
joecnc2006 Well a 3-axis machine is... 01-02-2007, 04:25 PM
David Da Costa That is true - thanks for the... 01-02-2007, 05:11 PM
jcook40 Joe and or David, I run a 6... 01-02-2007, 07:23 PM
joecnc2006 Hi, and welcome. you will... 01-03-2007, 12:04 AM
BMG My wife thinks I am mad but... 01-03-2007, 04:29 AM
Mr.Chips You are on the right track.... 01-03-2007, 05:33 AM
joecnc2006 Brian, I can understand... 01-03-2007, 05:59 AM
bp092 Brian, I think you have great... 01-03-2007, 04:46 AM
jcook40 Joe, I have seen in your... 01-03-2007, 08:46 PM
Marm Wow Joe nice job. I have been... 01-04-2007, 04:44 AM
joecnc2006 Thanks Mark, with either... 01-04-2007, 06:40 AM
Lionclaw Joe, I just got my HF router... 01-04-2007, 06:25 AM
joecnc2006 I got some from lowes and HD... 01-04-2007, 06:43 AM
joecnc2006 Heres some info if people... 01-04-2007, 06:46 AM
dsquire Joe: You the MAN. 5 stars for... 01-04-2007, 09:13 AM
ccsparky Interesting and informative... 01-04-2007, 12:46 PM
David Da Costa This is where I order my HDPE... 01-04-2007, 03:30 PM
DayneInfo DOM pipe? What is that? 01-04-2007, 07:04 PM
joecnc2006 http://www.copperweld.com/pdfs... 01-04-2007, 07:48 PM
Marm I have bought quite a bit of... 01-05-2007, 05:31 AM
DayneInfo Move anti backlas nut? 01-05-2007, 02:48 PM
joecnc2006 Yes you can move it anywhere... 01-05-2007, 04:33 PM
mike hide Joe do you know of a source... 01-06-2007, 06:04 AM
sdantonio Acme lead screws are... 01-06-2007, 04:39 PM
sdantonio Prices at Mcmaster-Carr are... 01-05-2007, 03:56 PM
DayneInfo Thanks Joe Dwayne 01-05-2007, 05:49 PM
Woodie1 Can some one tell what... 01-06-2007, 01:04 AM
gtschance The free way is: ... 01-06-2007, 01:40 AM
Woodie1 Down loaded edrawingsvierwer,... 01-06-2007, 03:26 AM
dicksonhof If anybody out there would... 01-06-2007, 03:43 AM
HayTay Here's the link to all of the... 01-06-2007, 04:32 AM
Marm Also if you look bad somebody... 01-07-2007, 05:30 PM
joecnc2006 http://www.lumenlab.com/~joe20... 01-07-2007, 06:15 PM
gtschance Several pages of posts back,... 01-06-2007, 04:18 AM
ger21 Nook stocks acme in 12'... 01-06-2007, 05:25 PM
bp092 I hosted the files for Joe in... 01-07-2007, 05:47 PM
mike hide Could someone direct me to... 01-08-2007, 05:32 PM
mike hide gantry sides e drawings 01-08-2007, 05:33 PM
bp092 heh joe I see you moving the... 01-07-2007, 07:09 PM
Robert M Hi all, Out of joe’s... 01-07-2007, 10:16 PM
bp092 Robert, the machine part... 01-07-2007, 10:29 PM
Robert M Hi Brian, Thank you very... 01-08-2007, 01:57 AM
bp092 I think David or Joe could... 01-08-2007, 02:25 AM
joecnc2006 For the leadscrew we do not... 01-08-2007, 03:24 AM
Woodie1 What is David DaCosta 's web... 01-08-2007, 02:19 AM
bp092 http://web.mac.com/dacostad/... 01-08-2007, 02:22 AM
BMG Hey all. 1 sheet of MDF... 01-08-2007, 03:21 AM
Jason Marsha Joe, Hobbycnc has 276... 01-08-2007, 04:08 AM
joecnc2006 I'm sorry i guess i was... 01-08-2007, 04:14 AM
David Da Costa Mike the gantry side drawings... 01-08-2007, 06:18 PM
mike hide Thanks very much ,I have... 01-09-2007, 05:13 PM
joecnc2006 Did you reg. the e-drawing... 01-09-2007, 05:40 PM
cdsgraphic Wider Y axis? 01-09-2007, 08:14 PM
joecnc2006 yes, you can expand it out,... 01-09-2007, 09:49 PM
mike hide Yes I did so I must be doing... 01-10-2007, 09:57 AM
bp092 BTW I see the end of a red... 01-13-2007, 04:23 AM
joecnc2006 LOL, I will be making a... 01-13-2007, 04:28 AM
David Da Costa Nice Joe and I like the... 01-13-2007, 05:43 AM
BMG Pipe Dimensions 01-13-2007, 06:38 PM
David Da Costa BMG, check the drawings (with... 01-13-2007, 06:40 PM
BMG Dimensions 01-13-2007, 06:49 PM
calgrdnr Hello BMG. I got Joes Kit... 01-13-2007, 07:06 PM
David Da Costa Brian it's 1" the pipe on the... 01-13-2007, 06:58 PM
Madclicker Pipe is not measured I.D *or*... 01-13-2007, 06:58 PM
BMG Time to restart. 01-13-2007, 07:06 PM
joecnc2006 Yes the radius is 0.68" /... 01-13-2007, 07:11 PM
BMG Thanks Joe, I made a few... 01-13-2007, 07:19 PM
truman stepper mach 3 settings 01-13-2007, 08:02 PM
David Da Costa Thanks for the clarification... 01-13-2007, 07:05 PM
Woodie1 Help, When I try to open the... 01-14-2007, 04:17 AM
David Da Costa try opening the files with... 01-14-2007, 05:06 AM
mike hide anyone noticed the price of... 01-14-2007, 08:49 AM
mike hide Joe the upper yaxis... 01-15-2007, 02:12 AM
joecnc2006 it is the same size as the... 01-15-2007, 02:26 AM
joecnc2006 Here is the Final seal, What... 01-15-2007, 03:02 AM
mike hide Dont mean to be a pest but... 01-15-2007, 03:28 AM
DayneInfo I noticed last week when I... 01-14-2007, 08:51 AM
Lionclaw You could always try to make... 01-14-2007, 09:03 AM
calgrdnr Table legs 01-14-2007, 09:24 PM
joecnc2006 yes it was on the 2/4"... 01-14-2007, 09:49 PM
joecnc2006 Here is the seal cut at 16"... 01-14-2007, 09:51 PM
calgrdnr Thanks for the picture Joe ,... 01-14-2007, 11:08 PM
joecnc2006 I am using a trash can with a... 01-15-2007, 12:10 AM
bp092 looks awesome joe! going to... 01-15-2007, 03:20 AM
studysession Can't wait till my router is... 01-15-2007, 03:35 AM
spydermeister I could really use some help... 01-15-2007, 03:54 AM
bp092 spyder, must be some kind of... 01-15-2007, 05:33 AM
ccsparky I second what bp092 said! I... 01-15-2007, 01:01 PM
joecnc2006 I have the PhotoCarve woorks... 01-15-2007, 03:15 PM
spydermeister Yeah, It was a glitch. Whew. ... 01-15-2007, 06:19 PM
David Da Costa I also have Cut3D, I haven't... 01-15-2007, 05:18 PM
spydermeister it was definitely a glitch. I... 01-15-2007, 06:49 PM
joecnc2006 No problem as long as... 01-15-2007, 06:54 PM
joecnc2006 Here is the second Seal in... 01-16-2007, 04:10 AM
mike hide anti backlash nut arrangement 01-16-2007, 06:05 PM
JLT Very nice Joe. 01-17-2007, 01:59 AM
BMG Table Legs 01-16-2007, 04:20 AM
joecnc2006 Sure it can be done, but you... 01-16-2007, 04:25 AM
BMG Silly me. Seeing I can only... 01-16-2007, 04:45 AM
bp092 So hows the gantry move over... 01-16-2007, 04:39 AM
Woodie1 Does anyone have a copy of... 01-16-2007, 04:30 AM
DayneInfo What format are you looking... 01-16-2007, 04:35 AM
Woodie1 Any thing in Adobe Reader? ... 01-17-2007, 01:38 AM
David Da Costa Check out the drawings Mike.... 01-16-2007, 06:09 PM
mike hide thanks for clearing that up... 01-16-2007, 07:22 PM
bp092 where is mention of the... 01-16-2007, 07:34 PM
mike hide lash eliminator 01-17-2007, 02:16 AM
David Da Costa There is no spring Brian. 01-16-2007, 07:48 PM
joecnc2006 As david mentioned there is... 01-16-2007, 08:16 PM
sdantonio There are several popular... 01-16-2007, 08:17 PM
bp092 Ah I see. So I think I saw... 01-16-2007, 08:32 PM
joecnc2006 here is backlash.. ... 01-16-2007, 09:08 PM
bp092 thanks for the info, good read 01-17-2007, 02:16 AM
sdantonio Joe, Excellent picture and... 01-16-2007, 09:30 PM
bp092 I hear yah now, makes sense.... 01-17-2007, 02:19 AM
joecnc2006 I just added a threaded rod... 01-17-2007, 03:15 AM
Marm Hey Joe do you have a link to... 01-17-2007, 06:27 AM
joecnc2006 Jay has a web site he has the... 01-17-2007, 10:41 PM
DayneInfo http://www.lumenlab.com/~joe20... 01-17-2007, 01:51 AM
bp092 Hey joe, seems as though your... 01-17-2007, 03:52 AM
joecnc2006 I use clamps, and clamp my... 01-17-2007, 04:40 AM
bp092 Sweet, so when are you adding... 01-17-2007, 04:44 AM
joecnc2006 We are reaching close to... 01-17-2007, 05:36 AM
dighsx Hey thanks for the plug Joe!... 01-18-2007, 02:23 PM
ccsparky Jay, Is this what you're... 01-18-2007, 02:39 PM
dighsx Yep that's it. Thanks. I've... 01-18-2007, 03:15 PM
ccsparky I agree, very nice setup all... 01-18-2007, 03:31 PM
joecnc2006 I have one of the JLT ATC... 01-18-2007, 04:31 PM
joecnc2006 Ok, here is the machine using... 01-19-2007, 02:55 AM
ccsparky Not bad at all! Very cool! I... 01-19-2007, 02:59 AM
joecnc2006 Actually its just sitting... 01-19-2007, 03:02 AM
David Da Costa Well once I get working I... 01-19-2007, 03:06 AM
bp092 whered you pick up the... 01-19-2007, 03:35 AM
HayTay Here's a source for "Solid... 01-19-2007, 04:26 AM
David Da Costa I have got it from ebay in... 01-19-2007, 03:36 AM
ccsparky I'm in too, the videos of the... 01-19-2007, 03:55 AM
DayneInfo I got some for free. Here is... 01-19-2007, 04:52 AM
Lionclaw Any reason why the tool rack... 01-19-2007, 05:49 AM
joecnc2006 it has to be strong enough... 01-19-2007, 05:59 AM
Bowman Nice photo carving there.. ... 01-19-2007, 03:13 PM
joecnc2006 40IPM, 16 mins. it is 5x7... 01-19-2007, 03:37 PM
bp092 404 pictures not found :( 01-19-2007, 10:02 PM
joecnc2006 I had asked Tony Mac from... 01-20-2007, 12:08 AM
joecnc2006 Here is the Photo i cut into... 01-20-2007, 05:29 AM
bp092 looks good joe.. any... 01-20-2007, 05:54 AM
joecnc2006 no perticular reason, i saw... 01-20-2007, 06:00 AM
Tashammer there is something uplifting... 01-21-2007, 08:31 PM
David Da Costa Mike, I think Joe has said it... 01-22-2007, 07:03 AM
bp092 I used those solidworks... 01-22-2007, 02:14 PM
dighsx Thanks for the info Joe I... 01-24-2007, 03:52 PM
Robert M Hi Joe, To the best of... 01-24-2007, 07:38 PM
David Da Costa Guys I ordered some from here... 01-24-2007, 07:56 PM
bp092 anyone have good sizes on the... 01-27-2007, 03:59 PM
David Da Costa bp092, the sizes are in the... 01-27-2007, 05:31 PM
bp092 I was going to go off of... 01-27-2007, 06:22 PM
bp092 just pulled them off the... 01-27-2007, 06:31 PM
David Da Costa 60 can't be right, the table... 01-27-2007, 06:50 PM
bp092 only cut the 18", and yeah... 01-27-2007, 06:59 PM
David Da Costa Brian STOP!!!!!! If you... 01-27-2007, 07:02 PM
David Da Costa Yes for some reason the... 01-27-2007, 07:04 PM
bp092 thanks david, having probs on... 01-27-2007, 07:13 PM
bp092 tried my other axis and its... 01-27-2007, 07:31 PM
bp092 think I figured it out.. just... 01-27-2007, 07:56 PM
joecnc2006 All you have to do is make... 01-27-2007, 08:06 PM
bp092 yeah I ended up trying that... 01-27-2007, 08:31 PM
David Da Costa Both nuts go under the... 01-27-2007, 08:44 PM
David Da Costa Also, I have found that a 1/4... 01-27-2007, 08:16 PM
bp092 sounds good david, the motor... 01-27-2007, 08:32 PM
David Da Costa Well you have my z axis test... 01-27-2007, 08:45 PM
bp092 ran it and it was totally... 01-27-2007, 09:05 PM
David Da Costa The 75% jog has no effect... 01-27-2007, 09:18 PM
bp092 I'm kind of lost in what you... 01-27-2007, 09:02 PM
David Da Costa Sorry. Here is two quick... 01-27-2007, 09:17 PM
bp092 oh, I mean when I'm jogging... 01-27-2007, 09:25 PM
bp092 well now I screwed it up bad,... 01-27-2007, 10:01 PM
David Da Costa How did that happen? Was... 01-27-2007, 10:51 PM
Lionclaw You could always replace the... 01-27-2007, 11:14 PM
bp092 not a huge issue david, I... 01-27-2007, 11:23 PM
bp092 and by the way even if I... 01-27-2007, 11:26 PM
David Da Costa Okay, now you have confused... 01-27-2007, 11:29 PM
bp092 well the motor mount screws... 01-27-2007, 11:33 PM
bp092 http://www.cnczone.com/forums/... 01-27-2007, 11:36 PM
bp092 http://www.cnczone.com/forums/... 01-27-2007, 11:38 PM
bp092 any ideas david? hookin up... 01-28-2007, 12:23 AM
David Da Costa Lets start again, 18" is... 01-28-2007, 12:25 AM
David Da Costa As I mentioned earlier, you... 01-28-2007, 12:27 AM
bp092 so the nuts are on the... 01-28-2007, 12:34 AM
David Da Costa No there are two nuts on the... 01-28-2007, 12:38 AM
David Da Costa Yes it sounds like you are... 01-28-2007, 12:40 AM
bp092 so two nuts on the top and... 01-28-2007, 01:45 AM
David Da Costa Okay I see problem, the... 01-28-2007, 01:49 AM
David Da Costa Make sure your limit switch... 01-28-2007, 01:52 AM
David Da Costa Here is the picture from... 01-28-2007, 02:10 AM
bp092 wow I'm at a lost for words..... 01-28-2007, 04:38 AM
David Da Costa They should not come loose if... 01-28-2007, 04:45 AM
bp092 nice david, will try that... 01-28-2007, 04:57 AM
David Da Costa You are welcome - thats what... 01-28-2007, 05:03 AM
mike hide So basically the two upper... 01-28-2007, 05:30 AM
bp092 well my night just got worse,... 01-28-2007, 05:19 AM
bp092 yep just checked the gantry,... 01-28-2007, 05:22 AM
David Da Costa Very interesting. Is the... 01-28-2007, 05:26 AM
bp092 but that won't solve the... 01-28-2007, 05:29 AM
David Da Costa It does for me it makes my... 01-28-2007, 05:37 AM
David Da Costa Actually just checked mine... 01-28-2007, 05:30 AM
bp092 gotta get joe's opinion on... 01-28-2007, 05:34 AM
bp092 and yeah the acme rod is too... 01-28-2007, 05:32 AM
David Da Costa Yes that could be a problem.... 01-28-2007, 05:40 AM
bp092 lol I get frustrated because... 01-28-2007, 05:51 AM
joecnc2006 Sorry i was away, have been... 01-28-2007, 03:13 PM
bp092 thanks for the info joe, I... 01-28-2007, 03:15 PM
joecnc2006 To adjust the gantry height,... 01-28-2007, 03:27 PM
bp092 okay now it is even with the... 01-28-2007, 03:42 PM
joecnc2006 you adjust them... 01-28-2007, 03:49 PM
bp092 got it centered but the... 01-28-2007, 03:52 PM
bp092 well Joe got it close,... 01-28-2007, 03:59 PM
joecnc2006 Good, Yes try with motor, but... 01-28-2007, 04:01 PM
bp092 joe running just the y now,... 01-28-2007, 04:15 PM
bp092 and up to 60ipm air testing... 01-28-2007, 04:27 PM
bp092 just got the third axis in.... 01-29-2007, 01:01 AM
David Da Costa sounds like you are getting... 01-29-2007, 02:55 AM
bp092 lol just ran your program and... 01-29-2007, 03:02 AM
David Da Costa Depends what you mean about... 01-29-2007, 03:05 AM
bp092 oh, it stops half way... 01-29-2007, 03:09 AM
David Da Costa Not sure why it would stop... 01-29-2007, 03:10 AM
bp092 so david, what was it that... 01-29-2007, 03:33 AM
David Da Costa Nope, yours is working fine,... 01-29-2007, 03:44 AM
bp092 I know it's too late but... 01-29-2007, 03:51 AM
David Da Costa I could not get Xylotex to... 01-29-2007, 03:59 AM
mhiggins bp092, I think you are... 01-29-2007, 04:15 AM
David Da Costa Good point I forgot about... 01-29-2007, 04:39 AM
jllewel812 The demo version of mach 3... 01-29-2007, 02:08 PM
joecnc2006 Hey I was just thinking and... 01-29-2007, 06:20 PM
ezgoin I'll start on one soon,... 01-30-2007, 02:42 AM
mike hide finished glueing up the Y... 01-31-2007, 04:32 AM
rdhharm Hi all my first post here. I... 01-31-2007, 08:13 PM
David Da Costa Hi Rick, yes you will. I... 01-31-2007, 08:25 PM
joecnc2006 No you do not (have) to use a... 01-31-2007, 08:27 PM
bp092 ah I see, I might order the... 01-29-2007, 04:04 AM
bp092 oh that's it lol, yeah I... 01-29-2007, 04:20 AM
David Da Costa I agree, let's all share. 01-29-2007, 06:41 PM
bp092 there are joe, there are tons... 01-29-2007, 07:02 PM
bp092 By the way, david I'm going... 01-29-2007, 07:04 PM
truman well I will be putting a... 01-29-2007, 07:10 PM
mhiggins I have been keeping a build... 01-29-2007, 07:28 PM
jspencer mhiggins- On the CNC Wood... 01-29-2007, 07:32 PM
mhiggins Thanks. I stumbled into it... 01-29-2007, 07:33 PM
Mr.Chips Or go to "Forums" on the... 01-29-2007, 07:35 PM
Mr.Chips Fuel Injection Hose 01-29-2007, 07:27 PM
sdantonio Joe, As you know I'm in... 01-29-2007, 07:53 PM
mhiggins Okay, thread started 01-30-2007, 02:21 AM
David Da Costa Joe the question Rick asked... 01-31-2007, 08:55 PM
rdhharm Thanks guys I under stand the... 01-31-2007, 09:02 PM
DayneInfo Hey Joe, I just noticed the... 01-31-2007, 09:08 PM
joecnc2006 Oh, Very sorry about that,... 01-31-2007, 09:12 PM
joecnc2006 Well finally got everything... 02-05-2007, 04:20 AM
joecnc2006 yea figured they were same... 02-05-2007, 04:23 AM
dighsx This is a bit off the subject... 02-08-2007, 05:21 AM
sdantonio Jay, if you go much beliw... 02-08-2007, 05:37 PM
David Da Costa I just bought a hand held... 02-08-2007, 05:42 AM
dighsx where'd you get the... 02-08-2007, 06:05 AM
David Da Costa From ebay about $30. Will... 02-08-2007, 06:06 AM
Smackre As far as Compression bits. ... 02-08-2007, 07:40 AM
IN-WondeR What is the largest version... 02-08-2007, 04:07 PM
David Da Costa I think you will find that it... 02-08-2007, 04:13 PM
IN-WondeR I was thinking more in the... 02-08-2007, 05:32 PM
milhead Just a thought... With the... 02-08-2007, 07:42 PM
David Da Costa Once the dust extractor and... 02-08-2007, 08:27 PM
joecnc2006 That is true, once everything... 02-08-2007, 09:16 PM
letterguy Hey Joe, I have been lurking... 02-09-2007, 04:28 AM
joecnc2006 sure that would work fine... 02-09-2007, 04:58 AM
letterguy Sintra in 6mm (1/4") is... 02-09-2007, 05:40 AM
joecnc2006 Post some pictures of it :) 02-09-2007, 06:07 AM
ezgoin I saw the angle jay had... 02-09-2007, 04:41 PM
joecnc2006 you can see them in this... 02-09-2007, 04:57 PM
ezgoin Got it, Thanks for your help.... 02-09-2007, 05:06 PM
Marm Our local Menards sells this... 02-10-2007, 04:05 AM
letterguy Hey Joe, Attached are some... 02-10-2007, 06:44 AM
dighsx Where do you get your pvc... 02-10-2007, 08:48 AM
letterguy Hey Jay, Trade name Sintra... 02-10-2007, 10:42 PM
bp092 anyone have the dust... 02-10-2007, 10:05 PM
DougO This is the ones you were... 02-11-2007, 12:09 AM
David Da Costa Brian, were the v-carve files... 02-10-2007, 10:11 PM
bp092 which files? you sent me two... 02-10-2007, 10:59 PM
David Da Costa Letterguy, is this the stuff... 02-10-2007, 10:55 PM
letterguy Yes, right material. Looks... 02-10-2007, 11:22 PM
David Da Costa Do you know if they have a... 02-11-2007, 12:51 AM
letterguy Pvc 02-14-2007, 03:26 PM
David Da Costa Thanks Letterguy, I will... 02-14-2007, 03:59 PM
David Da Costa I sent you 2 files today to... 02-10-2007, 11:02 PM
bp092 no david, never received them... 02-10-2007, 11:26 PM
DougO Forget this post. Made... 02-11-2007, 12:07 AM
bp092 huh? talking about the dust... 02-11-2007, 12:14 AM
bp092 whoo hoo found all them,... 02-11-2007, 12:17 AM
bp092 quick question, what material... 02-11-2007, 12:36 AM
David Da Costa Mine are 0.5" HDPE and the... 02-11-2007, 12:46 AM
bp092 thank you david, I will cut... 02-11-2007, 01:32 AM
DougO BP092, don't ask me where I... 02-11-2007, 07:03 AM
mike hide gantrylower torsion box 02-19-2007, 07:42 AM
joecnc2006 Well we hit a record for... 02-19-2007, 07:52 AM
joecnc2006 Mike just use another... 02-19-2007, 07:55 AM
mike hide z axis 02-19-2007, 08:00 AM
joecnc2006 hmmm maybe it is possible i... 02-19-2007, 08:09 AM
David Da Costa Broom bristles may be a... 02-11-2007, 01:38 AM
bp092 Yeah I know but the one I'm... 02-11-2007, 01:48 AM
bp092 Anyone cut plexi glass on... 02-14-2007, 01:08 PM
dighsx I cut some plexiglass. Did... 02-14-2007, 03:41 PM
bp092 Right on, I guess I will just... 02-14-2007, 03:53 PM
Marm When I have used a router on... 02-14-2007, 04:11 PM
bp092 Well one thing I noticed as a... 02-14-2007, 04:22 PM
sdantonio Glenn, you are correct :). ... 02-22-2007, 05:02 PM
NIL8r Mike, To my knowledge... 02-23-2007, 04:54 PM
David Da Costa I can second that. I just... 02-23-2007, 05:19 PM
Depdog Joe So you have the... 02-23-2007, 08:05 PM
Depdog Ahh nuts! He pulled the... 02-23-2007, 08:09 PM
joecnc2006 I would go ahead and get the... 02-23-2007, 08:25 PM
sdantonio For you guy's looking to... 02-25-2007, 01:22 AM
bp092 anyone getting any wear in... 02-25-2007, 10:42 PM
mike hide I guess you are bound to get... 03-10-2007, 10:28 AM
David Da Costa I have black marks where the... 02-25-2007, 10:52 PM
sdantonio Tell us more please since I... 02-26-2007, 04:14 PM
bp092 That's what I'm getting..... 02-25-2007, 10:57 PM
bp092 well I think I've concluded... 02-26-2007, 12:24 AM
ccsparky I've been taking the time to... 02-26-2007, 02:17 AM
dighsx Hey bp092 don't know if it's... 02-26-2007, 02:20 PM
bp092 Me too. It's the only thing I... 02-26-2007, 02:24 PM
mike hide You are bound to get some... 03-07-2007, 07:09 AM
joecnc2006 that is why we try to preload... 03-07-2007, 02:59 PM
truman ok I havn't bugged in a while... 03-07-2007, 05:09 PM
bp092 mine is much better now than... 03-07-2007, 11:01 PM
mike hide To get any real help in this... 03-08-2007, 07:17 AM
bp092 sparky, I'm not familiar with... 02-26-2007, 02:24 AM
ccsparky And happy cutting to you as... 02-26-2007, 02:39 AM
bp092 Jay just found this, what do... 02-26-2007, 02:42 PM
David Da Costa DOC total= 0.125 with 0.01... 02-26-2007, 08:34 PM
sdantonio David, Thanks. Just a... 02-26-2007, 09:02 PM
bp092 maybe jay could post his... 02-26-2007, 09:06 PM
sdantonio Typically for most non... 02-27-2007, 09:38 PM
ger21 They make router bits for... 02-28-2007, 12:32 AM
bp092 20,000 rpms, david could you... 02-26-2007, 09:02 PM
bp092 well I ordered two new acme... 02-27-2007, 09:10 PM
David Da Costa 1=8,500 2=11,500 3=14,500... 02-27-2007, 09:49 PM
David Da Costa Although the router cut the... 02-27-2007, 09:52 PM
dighsx I think I'd try the more... 02-27-2007, 10:23 PM
bp092 Jay too late, its here lol. I... 02-27-2007, 11:01 PM
David Da Costa The gantry "judders" a bit... 02-27-2007, 11:05 PM
bp092 good, glad I'm not the only... 02-27-2007, 11:16 PM
sdantonio Hi Gerry, Yes they do, I... 02-28-2007, 03:17 AM
David Da Costa As we are talking about bits,... 02-28-2007, 03:54 AM
joecnc2006 I think a compresion bit... 02-28-2007, 04:08 AM
sdantonio Hi David, Not really,... 02-28-2007, 01:35 PM
ger21 What do you mean by better?... 02-28-2007, 04:07 AM
ger21 If you don't mind changing... 02-28-2007, 04:14 AM
bp092 Ger, my upspiral (3/8) like... 02-28-2007, 05:05 AM
ballendo Hello, I'm not Ger; but I... 02-28-2007, 06:11 AM
glnth Pendant for Mach 3 02-28-2007, 06:13 AM
dighsx bp092, If you look up the max... 02-28-2007, 06:12 AM
David Da Costa I am currently building my... 02-28-2007, 07:02 AM
bp092 has anyone been checking... 03-03-2007, 09:21 PM
mike hide Similar problem in building... 03-03-2007, 09:45 PM
bp092 I guess you're right, my good... 03-03-2007, 10:13 PM
rkd Hi, slightly off topic but i... 03-03-2007, 11:34 PM
joecnc2006 No i never posted those dwg... 03-04-2007, 12:11 AM
ballendo testing machine/part... 03-04-2007, 09:23 AM
bp092 anyone know how to figure out... 03-04-2007, 03:57 AM
bp092 Ballendo thanks for the help,... 03-04-2007, 03:47 PM
bp092 question about joe06 users,... 03-07-2007, 02:59 AM
alleycat_tn dwg or dxf for the aluminum... 03-07-2007, 03:14 AM
calgrdnr Axis brackets 03-07-2007, 03:36 AM
alleycat_tn Thanks for the quick response... 03-07-2007, 04:43 AM
David Da Costa It sounds like you may have... 03-07-2007, 03:13 AM
bp092 so if you grab the router... 03-07-2007, 10:59 PM
David Da Costa The only movement I get is... 03-07-2007, 11:41 PM
ccsparky Hey Brian, I double... 03-08-2007, 04:11 AM
bp092 :D I have almost a dozen... 03-08-2007, 04:34 AM
dighsx Ahh the ole battle with whip.... 03-09-2007, 10:12 AM
Glidergider Excellent write up dighsx. 03-09-2007, 01:13 PM
joecnc2006 Nicely said Jay, Thanks. ... 03-09-2007, 02:54 PM
sdantonio Do the folks with bent... 03-09-2007, 03:28 PM
joecnc2006 Go to a Steel supplier near... 03-09-2007, 03:35 PM
sdantonio Yup, that will work too. ... 03-09-2007, 04:04 PM
softailjack Hey Joe and All, I just... 03-09-2007, 04:51 PM
David Da Costa Jac, welcome! Don't worry... 03-09-2007, 05:00 PM
bp092 That's a pretty interesting... 03-10-2007, 01:44 PM
mike hide I came up with that idea last... 03-10-2007, 07:26 PM
temler Hi How much is Joe's kit?... 03-10-2007, 04:45 PM
just_lkn Joe's plans are free... As... 03-10-2007, 05:43 PM
djronbxs hi, can you tell me please... 03-13-2007, 03:51 PM
David Da Costa Hi, not sure what you are... 03-13-2007, 04:03 PM
djronbxs but the z-axis is used to cut... 03-13-2007, 04:17 PM
AMorgan Yes, the z-axis cuts the... 03-13-2007, 04:29 PM
AMorgan Sì, l'z-asse taglia la... 03-13-2007, 04:32 PM
David Da Costa Yes it is controlled by the... 03-13-2007, 04:29 PM
bp092 anyone forsee a problem... 03-13-2007, 06:35 PM
joecnc2006 Brian should not be a... 03-16-2007, 03:13 PM
bp092 thank you joe, I purchased it... 03-16-2007, 09:43 PM
Depdog For the lead screws whipping... 03-17-2007, 05:15 AM
mhiggins I bought thrust bearings for... 03-18-2007, 02:12 AM
joecnc2006 Mike those should work good... 03-19-2007, 03:06 AM
joecnc2006 Here is a sign, i just cut... 03-19-2007, 03:18 AM
rbartko What bit did you use? Joe,... 03-19-2007, 03:58 AM
joecnc2006 You can use V-Carve Pro, just... 03-19-2007, 05:14 AM
ccsparky Joe, As always, great job!... 03-19-2007, 02:01 PM
joecnc2006 When i get home i will post a... 03-19-2007, 03:16 PM
Glidergider Joe, Where did you get your... 03-26-2007, 11:03 PM
joecnc2006 they were samples from... 04-01-2007, 12:13 AM
Jason Marsha Its good when we can get in a... 03-19-2007, 03:51 AM
joecnc2006 Jason, you are so right. we... 03-19-2007, 01:12 PM
samcrow is lighter better? 03-21-2007, 03:25 AM
bp092 You'de be suprised how much... 03-21-2007, 03:27 AM
thorsgaard Hey Joe, remember me? It's... 03-25-2007, 03:55 PM
joecnc2006 [QUOTE=thorsgaard;276341]Hey... 03-25-2007, 11:04 PM
sdantonio Hi All, OK the first Joe... 03-26-2007, 02:20 PM
bp092 I believe joe and david tried... 03-26-2007, 03:12 PM
David Da Costa I am currently using the... 03-26-2007, 03:39 PM
joecnc2006 the only problem i had with... 03-26-2007, 05:00 PM
sdantonio My nacklash problem. I... 03-31-2007, 11:58 PM
joecnc2006 I would not think that... 04-01-2007, 12:23 AM
David Da Costa The only pre-load I have is... 03-26-2007, 05:04 PM
sdantonio Squareness adjustment 03-31-2007, 11:55 PM
bp092 Joe designed those parts to... 04-01-2007, 04:54 PM
sdantonio When I made mine I only had a... 04-01-2007, 06:33 PM
AndrewN Thanks guys, I run a cnc... 04-01-2007, 09:47 PM
mindstorm88 Hi Guys , my shop is about to... 04-02-2007, 12:28 PM
thunterman Cutting Joe's parts on a JGRO 04-02-2007, 01:19 PM
joecnc2006 You can do what buzz has done... 04-02-2007, 01:45 PM
joecnc2006 Heres a quick test to see if... 04-05-2007, 04:38 AM
Glidergider Hi Thunterman, What is... 04-05-2007, 07:18 AM
ccsparky Dave, I don't have the... 04-05-2007, 01:16 PM
Glidergider wow, those parts look great. ... 04-05-2007, 08:37 PM
thunterman Hi Dave Some of Joe's part... 04-06-2007, 01:23 PM
sdantonio A good well built Joe... 04-05-2007, 09:26 PM
Buzz9075 Lol while I agree with you I... 04-05-2007, 10:12 PM
sloog Hi, my name is patrick, I'm... 04-06-2007, 03:18 PM
AndrewN Another question for Joe or... 04-07-2007, 01:52 AM
sdantonio I made my gantry sides out of... 04-07-2007, 04:06 AM
AndrewN 4 x 1/4" pieces would not be... 04-07-2007, 06:08 PM
Jason Marsha Hello Patrick welcome to the... 04-07-2007, 11:28 AM
sloog Hello Jason and thank you for... 04-07-2007, 03:12 PM
Buzz9075 I am interseted in this... 04-07-2007, 11:42 AM
Jason Marsha Check out his site... 04-07-2007, 11:45 AM
Buzz9075 Thanks Jason. Lots of good... 04-07-2007, 12:23 PM
sdantonio Andrew, I would glue up 2... 04-08-2007, 02:56 PM
Jojje Bergan We have no problem with... 04-09-2007, 01:21 AM
PhillyCyberJoe Joe, I'm not really sure... 04-09-2007, 10:36 PM
ballendo Hello, Not Joe, but yes,... 04-09-2007, 11:18 PM
PhillyCyberJoe Ballendo, Thanks much for... 04-10-2007, 12:21 AM
Buzz9075 Humm if you are using 1/4... 04-08-2007, 03:10 PM
joecnc2006 one kg = 176.73oz one cm =... 04-11-2007, 09:28 PM
Peterpanta So as i can understand the... 04-11-2007, 10:44 PM
ballendo Hello, You should have a... 04-12-2007, 12:39 AM
Peterpanta Dissapointed.... :confused: ... 04-12-2007, 01:20 AM
joecnc2006 you can always put the motors... 04-12-2007, 02:13 AM
spookybonus has anyone used thier 2006 to... 04-12-2007, 07:29 AM
dshowalt Why not Plywood 05-24-2007, 03:51 AM
sdantonio MDF is more dimensionally... 05-24-2007, 01:56 PM
spalm Dshowalt, you will get... 05-24-2007, 02:17 PM
acondit Joe, I am redoing my... 04-12-2007, 05:11 PM
Buzz9075 Not Joe, but 2 cents to think... 04-12-2007, 06:01 PM
acondit Buzz, I want to mount the... 04-12-2007, 08:09 PM
joecnc2006 Ok, I know many people have... 04-18-2007, 04:16 AM
ccsparky That looks like it'll do the... 04-18-2007, 06:07 AM
joecnc2006 I was asked if I could upload... 04-19-2007, 04:03 PM
mike hide I have not followed this... 04-20-2007, 08:29 AM
bp092 Cool design Joe! If that is... 04-18-2007, 04:21 AM
bp092 Sounds good joe. Will cut it... 04-19-2007, 11:16 PM
joecnc2006 It works well in picking up... 04-20-2007, 04:13 AM
bp092 thats awesome joe, thanks for... 04-24-2007, 01:56 AM
Buzz9075 Nice job!!!! I have modified... 04-24-2007, 02:44 AM
sdantonio Lookin good Joe. I gotta... 04-24-2007, 02:54 PM
acondit Joe, Thanks for taking a... 04-24-2007, 03:39 PM
joecnc2006 You can always cut your own... 04-24-2007, 05:13 PM
sdantonio Joe, I was looking at the... 04-24-2007, 07:58 PM
joecnc2006 Yes original is 1/2" HDPE,... 04-24-2007, 09:27 PM
joecnc2006 Here is the file david... 04-26-2007, 02:03 AM
fade2black I got the same parts from... 04-26-2007, 03:01 PM
Glidergider Joe, I know this question... 04-27-2007, 06:30 AM
joecnc2006 I actually called fastenal,... 04-27-2007, 07:34 AM
David Da Costa I got mine from McMaster. ... 04-30-2007, 02:48 PM
oscar la fuente hi to all 04-26-2007, 03:57 PM
Buzz9075 Caution with Fastenal... 04-27-2007, 11:35 AM
sdantonio Interesting that MSC has the... 04-27-2007, 01:39 PM
fade2black I bought mine from MSC and... 04-27-2007, 01:44 PM
erebus I purchased the 1/2-8 2 start... 04-27-2007, 03:25 PM
Glidergider How about the nuts, did you... 04-27-2007, 03:28 PM
joecnc2006 I will be using 1/2" metal... 04-27-2007, 04:42 PM
Wally6800 Information on plans &... 04-30-2007, 02:05 PM
bp092 Wally, This machine might... 04-30-2007, 03:27 PM
joecnc2006 Well said Brian, If anyone... 04-30-2007, 03:53 PM
joecnc2006 those who have upgraded to... 05-04-2007, 05:14 PM
mike hide That seems strange to me, you... 05-04-2007, 05:54 PM
spalm Joe, long time no talk. I... 05-04-2007, 06:09 PM
joecnc2006 Thanks steve, that is a good... 05-04-2007, 08:52 PM
David Da Costa I did not have any problems... 05-04-2007, 06:12 PM
fade2black I'll check mine when I get... 05-04-2007, 06:48 PM
joecnc2006 David and Fade2Black, can... 05-04-2007, 07:27 PM
rodneydeeeee Wow this thread is HUGE! May... 05-05-2007, 01:34 AM
isaac.braun Nice model joe. That would be... 05-05-2007, 04:37 AM
sdantonio Hi kb18951452, Here is one... 05-15-2007, 01:59 PM
kb18951452 Vibrations 05-15-2007, 03:54 PM
nikolaw I Have Big Problem I Cant... 05-15-2007, 04:02 PM
Jason Marsha oops 05-30-2007, 12:07 PM
sdantonio The water issue will be a... 05-15-2007, 04:46 PM
nikolaw I Have Big Problem I Cant... 05-15-2007, 05:11 PM
kb18951452 Controllers and Steppers 05-15-2007, 07:21 PM
BobLWeiss I have a question on the 1/2"... 05-15-2007, 07:26 PM
joecnc2006 Yes 1/2"-8 two start = 4... 05-15-2007, 08:45 PM
sdantonio These guys have a good... 05-15-2007, 09:04 PM
ibanana Hi everybody!! Hello Joe ;) ... 05-21-2007, 03:56 PM
joecnc2006 The torsion box is to provide... 05-22-2007, 03:21 AM
Buzz9075 Lessons learned from my first... 05-22-2007, 03:28 AM
ibanana HEllo, Thanks for your... 05-22-2007, 06:03 PM
iet35127 THANK YOU!!! Thanks for... 06-07-2007, 09:01 PM
Phantom_Najd Wow! Just finished reading... 06-12-2007, 09:50 AM
Buzz9075 Joe if I remember correctly... 06-13-2007, 01:09 PM
joecnc2006 Here ya go... :) i think you... 06-13-2007, 03:16 PM
Buzz9075 Exactly what I need. Thanks,... 06-13-2007, 04:07 PM
brokenlaser Awesome Machine 06-14-2007, 01:35 AM
Phantom_Najd Any special settings for the... 06-14-2007, 08:53 AM
brokenlaser It's not really a settings... 06-14-2007, 10:24 AM
holdenwaca Hey, everyone. Got my kit... 11-14-2011, 05:11 AM
arudson Thanks Don. I think I now... 11-14-2011, 06:32 AM
Glidergider Joe, Humm, I would guess the... 06-15-2007, 02:46 AM
joecnc2006 Well with my new machine now,... 06-15-2007, 02:55 AM
Buzz9075 I just installed a new... 06-15-2007, 04:41 AM
brokenlaser It was just a though as the... 06-15-2007, 12:29 PM
Glidergider Joe, Last night I was... 06-15-2007, 01:16 PM
joecnc2006 Yes the Delrin Dumpster uses,... 06-15-2007, 05:47 PM
Glidergider In Rick's thread he said he... 06-15-2007, 11:21 PM
joecnc2006 for the Hitachi Router I use... 06-15-2007, 11:49 PM
joecnc2006 I use Autocad and solidworks,... 06-18-2007, 02:28 PM
kb18951452 Wow, That one set me back... 06-18-2007, 02:31 PM
joecnc2006 V-Carve pro does allow for... 06-18-2007, 02:33 PM
kb18951452 Yea, i am heavily considering... 06-18-2007, 02:38 PM
raverys12 Thanks for the info .. I do... 06-18-2007, 11:26 PM
brokenlaser A program for 2D drafting... 06-19-2007, 11:55 AM
kb18951452 I need to make some... 06-19-2007, 02:57 PM
joecnc2006 Here is an example of a rib... 06-19-2007, 03:28 PM
raverys12 Thanks for the feedback. I... 06-19-2007, 12:11 PM
brokenlaser Solid Edge will call too, but... 06-19-2007, 01:43 PM
joecnc2006 They say Texas has not had... 07-11-2007, 02:26 PM
mike hide Hitachi make several routers... 07-16-2007, 04:04 PM
ClaudioG It's the M12VC 07-16-2007, 04:19 PM
sasii sory no english :(... 07-11-2007, 10:27 PM
joecnc2006 Good ideal for energy chain,... 07-13-2007, 02:17 PM
william boman Gentlemen I have monitored... 07-13-2007, 12:15 PM
joecnc2006 Glad the info is of some use... 07-13-2007, 02:21 PM
william boman Thanks Joe There is so much... 07-13-2007, 07:39 PM
joecnc2006 Not sure but i think this... 08-06-2007, 01:43 PM
raverys12 Joe ... just a quick question... 08-06-2007, 02:16 PM
joecnc2006 I use Acad Civil 3D 2008... 08-06-2007, 05:28 PM
bp092 Glad you are finding... 08-07-2007, 12:33 AM
joecnc2006 Matt, i recieved your e-mail,... 08-21-2007, 01:52 AM
Robrecht Could you mail me the price... 08-21-2007, 07:10 AM
joecnc2006 Hopefully soon we will have a... 08-23-2007, 01:48 PM
Wm McNett Is there anyone in S.E.... 08-25-2007, 05:52 PM
janapurushottam Dear joe i am not getting... 09-04-2007, 10:36 AM
joecnc2006 Can you clearify the... 09-04-2007, 01:51 PM
BobF Joe, I plan to get the Hobby... 09-04-2007, 10:45 PM
rcpilot82 Well this is my first post... 09-05-2007, 04:03 PM
mikeg53549 We all start out thinking... 09-10-2007, 05:00 PM
BobF Cable 09-17-2007, 10:31 PM
skiddaw If run in the same cable I... 09-18-2007, 12:05 PM
phamiltonsmith Joe, I finished your design... 09-05-2007, 11:46 PM
joecnc2006 The anti-Backlash nuts uses... 09-06-2007, 01:51 PM
phamiltonsmith Hi Joe, thks for yr input.... 09-06-2007, 02:48 PM
janapurushottam joe i meant that i am from... 09-06-2007, 08:05 AM
joecnc2006 There are several... 09-06-2007, 02:00 PM
snipper Dear Joe, I am a newbee,... 09-06-2007, 07:53 PM
janapurushottam thanks joe will check and... 09-07-2007, 10:20 AM
BobF Aluminum not square. 09-07-2007, 09:59 PM
joecnc2006 Its best to have the bearings... 09-09-2007, 05:37 AM
cephjedi Hey Gang, I built a basic... 09-19-2007, 12:55 PM
bp092 Best way to do it is to... 09-19-2007, 10:41 PM
cephjedi Thanks for the input BP! ... 09-20-2007, 02:14 PM
bp092 Two things to consider. I... 09-20-2007, 11:46 PM
cephjedi you're insightful BP! I've... 09-21-2007, 04:36 PM
joecnc2006 What you want to ask yourself... 09-24-2007, 08:12 PM
cephjedi I started building my first... 09-26-2007, 01:39 PM
PhillyCyberJoe Dust collection holder 09-26-2007, 04:14 PM
PhillyCyberJoe Hey Buzz, Thanks for the... 09-26-2007, 10:36 PM
Buzz9075 Good timing.... I was running... 09-26-2007, 04:33 PM
Buzz9075 I uploaded some pictures of... 09-26-2007, 06:11 PM
bp092 Nice photos buzz, nice... 09-26-2007, 10:29 PM
Buzz9075 BP092, I checked my newly... 09-27-2007, 12:50 AM
bp092 Buzz, it's saying "The page... 09-27-2007, 12:54 AM
Buzz9075 Sorry BP092... but yup people... 09-27-2007, 01:20 AM
fatham Hello Just to let you... 09-27-2007, 01:47 AM
eqreservoir I use IE and get only "The... 09-27-2007, 01:54 AM
HayTay To those with problems... 09-27-2007, 03:20 AM
rdhharm I think HayTay is correct and... 09-27-2007, 03:30 AM
fatham Sorry No Change.... Cheers 09-27-2007, 03:31 AM
HayTay Buzz9075, It seems to have... 09-27-2007, 05:22 AM
mdframe Joe Check Your E-Mail Spam... 10-03-2007, 03:14 AM
BobF Me Too. 10-03-2007, 01:45 PM
Jii Dee I've worked my way through... 10-07-2007, 06:38 PM
DeWalt58 Well the way I see it Jii Dee... 10-07-2007, 09:58 PM
HayTay Buzz, I viewed your new... 09-27-2007, 03:36 AM
fatham I Just rebooted machine and... 09-27-2007, 03:53 AM
Buzz9075 Thanks for the help guys. I... 09-27-2007, 01:58 AM
fatham Just tried again still no-go... 09-27-2007, 02:06 AM
rdhharm It seems to be okay I can see... 09-27-2007, 02:19 AM
Buzz9075 Something is very strange. ... 09-27-2007, 02:22 AM
fatham Well I don't know why I can't... 09-27-2007, 02:41 AM
Buzz9075 On the newdustcollector page,... 09-27-2007, 03:07 AM
fatham I see on your... 09-27-2007, 03:18 AM
rdhharm Buzz I see without and New... 09-27-2007, 03:19 AM
Buzz9075 Yup it helps, tells me you... 09-27-2007, 03:21 AM
bp092 works in IE now, nice photos 09-27-2007, 03:52 AM
Buzz9075 Hopefully everyone gets to... 09-27-2007, 04:07 AM
Buzz9075 NP Doug, keeps the gray... 09-27-2007, 04:11 AM
Buzz9075 You are da man. I made the... 09-27-2007, 12:11 PM
joecnc2006 I just created a Yahoo User... 10-12-2007, 04:25 PM
biotech1 what would we nee to do to... 10-13-2007, 03:16 AM
joecnc2006 Thought this might be... 10-30-2007, 08:34 PM
sdantonio Thanks Joe, Been there, got... 10-30-2007, 09:43 PM
anoel I use this one... ... 10-30-2007, 09:43 PM
sdantonio I've also seen them on ebay... 10-30-2007, 09:55 PM
BobF I made a wired one from an... 11-01-2007, 11:58 PM
Marm For my dust collector I wired... 11-02-2007, 11:24 PM
Deweydog Auto dust collection 11-05-2007, 07:15 PM
Glidergider DeweyDog, Outstanding... 11-08-2007, 06:44 PM
curtis I would like to know how much... 11-08-2007, 10:28 AM
Glidergider Joe, I have a nagging... 11-24-2007, 02:31 PM
joecnc2006 If you extend the X-Axis I... 11-24-2007, 08:28 PM
joecnc2006 4 hrs of machining time, done... 11-25-2007, 04:32 AM
jdell42 Joe was this all done with... 01-04-2008, 05:33 PM
bp092 I have a feeling it is mostly... 11-24-2007, 05:29 PM
Glidergider That's some great looking... 11-25-2007, 10:48 PM
mdframe Joe, Can you check your... 11-26-2007, 05:06 PM
HayTay Matt, Forget the PM and... 11-26-2007, 05:22 PM
Sbthomas13 Joe, whats the thickest... 12-02-2007, 07:24 PM
bp092 3/4 HDPE, he buys it in full... 12-02-2007, 07:55 PM
dshowalt HDPE Question 12-03-2007, 09:39 PM
joecnc2006 I use the 1/4 tap i got from... 12-03-2007, 10:30 PM
dshowalt Tapping HDPE 12-04-2007, 02:01 AM
flyon I used a cheap set of taps I... 12-04-2007, 06:37 PM
dshowalt Tapping HDPE 12-04-2007, 09:31 PM
Sbthomas13 Joe, My first part for... 12-06-2007, 03:56 AM
joecnc2006 over 300ipm should be no... 12-06-2007, 04:06 AM
tybrenis Ok. Basically, you're gonna... 12-06-2007, 11:21 PM
Sbthomas13 Joe- Today I made the... 12-07-2007, 03:37 AM
ger21 Ideally, you should use bit's... 12-07-2007, 03:44 AM
joecnc2006 the bits from enco are not... 12-07-2007, 04:00 AM
Sbthomas13 Joe- I just ordered a CMT... 12-07-2007, 06:44 AM
BobF Was it trying to plunge the... 12-07-2007, 02:40 PM
tybrenis Our bit is an upspiral bit. 12-07-2007, 09:05 PM
Sbthomas13 yeah the bit is a... 12-07-2007, 11:35 PM
Sbthomas13 Joe- Today was the second... 12-08-2007, 05:37 AM
joecnc2006 mine are 2 flute upspiral,... 12-08-2007, 06:03 AM
ger21 Unless you blow compressed... 12-08-2007, 02:08 PM
bp092 Ger is right and suggested aw... 12-08-2007, 03:15 PM
bamabones3 Hello everybody 12-13-2007, 09:49 PM
Glidergider Bama, Are you in Elkmont... 12-14-2007, 10:52 PM
bamabones3 Oh yeah! I live in Elkmont. ... 12-15-2007, 03:26 AM
Dougie085 I used to live in... 12-15-2007, 03:51 AM
Glidergider Dougie, I'm north of your... 12-15-2007, 06:43 AM
Dougie085 And thats a good thing?... 12-15-2007, 08:05 AM
Glidergider Dougie, I'm just making... 12-15-2007, 04:31 PM
DeWalt58 I liked that Dave...LMAO... 12-15-2007, 04:46 PM
Dougie085 Yeah I'm debating on waiting... 12-15-2007, 04:42 PM
Glidergider Yeah, DeWalt58 is from the... 12-15-2007, 11:20 PM
Dougie085 Well you won't catch me back... 12-15-2007, 11:24 PM
joecnc2006 Add me to use to live there,... 12-16-2007, 03:52 AM
Dougie085 All these unfortunate souls :) 12-16-2007, 04:02 AM
jjvogre@aol.com Pittsburgh's not bad. I've... 12-31-2007, 10:25 PM
Dougie085 I live in North Side... 12-31-2007, 10:38 PM
joecnc2006 all done with a 1/4" 0 flute... 01-04-2008, 06:15 PM
joecnc2006 The only reason i do not... 01-07-2008, 02:04 PM
steptoey ok joe, no worries. What i... 01-08-2008, 12:09 AM
Sbthomas13 To make a cut you need the... 01-08-2008, 12:21 AM
Sbthomas13 A short answer to your... 01-08-2008, 12:40 AM
steptoey Thanks thomas, i read the lot... 01-08-2008, 01:25 AM
joecnc2006 you do not need to be... 01-08-2008, 04:26 AM
silentreaper I really don't want to argue... 01-08-2008, 04:10 AM
Sbthomas13 I was incorrect in saying... 01-08-2008, 05:02 AM
acondit I have written a bunch of... 01-08-2008, 06:35 PM
BobF Alan, Is a call a common... 01-09-2008, 04:03 AM
acondit Bob, I am running EMC2.... 01-09-2008, 06:46 AM
joecnc2006 I would have to say most... 01-08-2008, 04:24 AM
Sbthomas13 I really want to get Autocad... 01-08-2008, 05:09 AM
cinerman37 your CNC is very good , i... 01-14-2008, 11:12 PM
joecnc2006 http://groups.yahoo.com/group/... 01-15-2008, 05:49 AM
DistortedDesign Misc Parts Questions and... 01-15-2008, 06:32 PM
Buzz9075 I think I have my T slot... 01-15-2008, 06:35 PM
PhillyCyberJoe Hey DistortedDesign, I... 01-15-2008, 08:52 PM
flyon PhillyCyberJoe, Can you... 01-15-2008, 09:05 PM
joecnc2006 I did this also a while back... 01-15-2008, 10:08 PM
DistortedDesign Don't forget about the other... 01-16-2008, 03:44 AM
Buzz9075 Correct me if I am wrong. I... 01-16-2008, 03:48 AM
DistortedDesign Yep that is it. Thanks! ... 01-16-2008, 05:42 PM
Buzz9075 The file should be in DXF... 01-16-2008, 05:47 PM
DistortedDesign Nope I got it open in autocad... 01-16-2008, 05:55 PM
DistortedDesign Need to check the mounting... 01-16-2008, 06:11 PM
Glidergider Buzz, I like the down draft... 01-16-2008, 05:51 PM
Buzz9075 The dxf is based on the... 01-16-2008, 06:08 PM
DistortedDesign Ok, that makes some sense but... 01-16-2008, 06:27 PM
PhillyCyberJoe Flyon, I bought the T-Slot... 01-17-2008, 11:16 PM
Buzz9075 Some times it sucks in but... 01-16-2008, 06:26 PM
Buzz9075 Sorry that one is a little... 01-16-2008, 06:28 PM
Buzz9075 To confirm I drilled the... 01-16-2008, 06:30 PM
joecnc2006 Buzz you have the files? the... 01-16-2008, 06:44 PM
Buzz9075 Joe, OK the problem...... 01-16-2008, 06:56 PM
joecnc2006 does this look like yours? ... 01-16-2008, 07:48 PM
Buzz9075 That's it. Not sure if you... 01-16-2008, 08:04 PM
DistortedDesign I am making Joes vacuum and I... 01-17-2008, 02:03 PM
joecnc2006 I do not have the 06 anymore,... 01-17-2008, 03:25 PM
joecnc2006 Ok, for those who want a cad... 01-17-2008, 03:27 PM
Sbthomas13 Awesome! My trial on... 01-17-2008, 10:11 PM
Glidergider I just downloaded the... 01-20-2008, 05:31 AM
mike hide Changing the subject I am... 05-05-2008, 08:07 PM
TCGliderguy >Has anyone made a T-Slot... 05-10-2008, 02:39 PM
kb18951452 Racking 05-12-2008, 03:09 AM
mike hide Why do they refer to it as... 05-19-2008, 06:57 PM
tpworks I don't know about the moving... 05-26-2008, 05:15 AM
krsta.brcic Hello 06-11-2008, 04:38 PM
mike hide I do not see anyway to... 06-11-2008, 06:59 PM
tpworks Mike, Are you meaning to... 06-12-2008, 05:10 AM
mindstorm88 Hi guys , just need to... 06-12-2008, 04:12 PM
joecnc2006 Correct. 06-12-2008, 08:32 PM
mindstorm88 Thanks Joe BTW anybody... 06-16-2008, 04:54 PM
joecnc2006 we have someone right now... 06-16-2008, 07:18 PM
mindstorm88 Joe , what spindle speed and... 06-17-2008, 11:01 AM
mindstorm88 Please any reply ???? 07-08-2008, 02:29 PM
mike hide Probably not but it should... 08-04-2008, 03:18 PM
joecnc2006 Very sorry i did not see this... 07-08-2008, 03:01 PM
vbodi Good job Joe. Very nice. 07-21-2008, 08:32 PM
mindstorm88 Hi Joe , i would like to know... 07-27-2008, 01:22 PM
joecnc2006 I replied in your thread hope... 08-05-2008, 11:03 PM
j.guenther Hi everyone, This is my... 09-12-2008, 12:31 PM
ger21 Welcome, John. Are you going... 09-12-2008, 04:27 PM
j.guenther Of couse I am, the reality is... 09-12-2008, 04:44 PM
GibbonsRock Hi Guenther, At the risk... 09-12-2008, 09:05 PM
j.guenther Hi Jim, Well, we won't... 09-13-2008, 01:27 AM
gfc62 John, The 2006 is a great... 09-16-2008, 04:12 AM
j.guenther Gordon, That is a good... 09-16-2008, 03:38 PM
tonybert Joe's 4x4 in Centreville 09-17-2008, 02:19 AM
gfc62 Tony, You know I'm up for... 09-17-2008, 04:37 AM
HAR THA CAD software 03-03-2009, 12:36 PM
j.guenther Gordon, Jim, Tony; I am up... 09-17-2008, 11:07 AM
joecnc2006 Its great to be able to go... 09-17-2008, 01:46 PM
JeepMcMuddy Just thought I'd throw this... 09-17-2008, 11:06 PM
bp092 Joe is still cutting kits for... 09-17-2008, 11:13 PM
JeepMcMuddy Excellent, I thought he... 09-17-2008, 11:52 PM
bp092 Sure is, I believe he still... 09-17-2008, 11:54 PM
tangocc35 Looking for Info 09-07-2009, 05:17 PM
BigMike4u I think thus is the one you... 09-07-2009, 05:37 PM
tonybert Gordon, John & Jim Drop me... 09-18-2008, 12:59 AM
HAR THA Nice! 02-18-2009, 05:19 AM
rzerk Dimensioned PDF Plans? 02-22-2009, 04:38 PM
bp092 Joe is still cutting 06 kits... 02-22-2009, 04:45 PM
morphious69 why are you still using 98 ?... 12-17-2009, 07:14 AM
TCGliderguy I'm going to cut the parts... 12-17-2009, 03:17 PM
ger21 I think you can measure them... 12-17-2009, 05:11 PM
Fatboy That is correct, exactly what... 12-20-2009, 12:48 AM
TCGliderguy I'd love to know how you... 12-20-2009, 01:49 AM
Fatboy Taylor, Look in the... 12-20-2009, 03:40 AM
TCGliderguy Thanks Gerry, I'm... 12-18-2009, 02:52 PM
joecnc2006 ok found this in an old... 12-18-2009, 03:02 PM
TCGliderguy GREAT! Thanks Joe! That... 12-19-2009, 03:24 AM
Fatboy I'm tired now!!! 12-19-2009, 11:25 PM
ger21 I've never tried it, so maybe... 12-18-2009, 02:59 PM
ger21 Perhaps it's a different... 12-20-2009, 03:36 AM
Fatboy I'm using version 9.2.0.128... 12-20-2009, 03:58 AM
rfriesen Joe's Original or Joe's... 01-12-2010, 12:21 AM
curtis build the hybird. I built em... 01-12-2010, 09:08 AM
BRYANA One of my friends refer me to... 03-12-2010, 08:43 AM
PietVR Depth and cutting speed 05-04-2010, 12:35 PM
rfeatherhawk Unhappy about Joes forum 05-07-2010, 01:16 AM
joecnc2006 Well, there has not been as... 05-07-2010, 04:03 AM
Biff Hi, I'm considering building... 05-13-2010, 04:13 AM
curtis Sorry to see you are not... 05-13-2010, 06:38 AM
keshin Newbie 06-14-2010, 03:33 PM
s3r4ph Hi all, I'm starting my first... 07-08-2010, 03:05 PM
Joe Cleary Build hints: 07-08-2010, 10:34 PM
Joe Cleary Oops! 07-08-2010, 10:43 PM
lemonyx I can't find the dimensions... 08-02-2010, 04:58 AM
Fatboy Check the JGRO plans. ... 08-02-2010, 01:00 PM
swiftden Well what a read 141 pages... 09-08-2010, 02:57 PM
swiftden sorry for some reason it... 09-08-2010, 02:59 PM
craigjh G'day Swiften, I too have... 09-09-2010, 12:57 PM
psyolent swiftden.......plenty of... 02-04-2011, 06:06 AM
atwooddon New Joe's 2006 Owner/Operator 02-15-2011, 07:59 PM
ultrabrains hi, where can i find the... 04-06-2011, 07:17 AM
Fatboy Ultrabrains, Look in the... 04-06-2011, 01:57 PM
ger21 Google "Joes 2006 CNC... 04-06-2011, 04:42 PM
thebuggman Wow. After several hours of... 08-04-2011, 07:22 AM
mark9407 Hello All i am new to cnc... 08-17-2011, 06:42 AM
atwooddon Mark, welcome.... The Joes... 08-18-2011, 03:46 PM
JoyMonkey I'm about to start my Joes... 08-18-2011, 07:11 PM
atwooddon I would be more concerned... 08-18-2011, 08:31 PM
mark9407 THANK YOU 08-18-2011, 07:15 PM
40fordcoupe I too have purchased several... 08-22-2011, 06:09 PM
mark9407 The Bigprint 08-22-2011, 06:31 PM
40fordcoupe You can download the free... 08-22-2011, 06:46 PM
mark9407 WILL THIS PDF work 08-22-2011, 06:47 PM
atwooddon If the pdf doesn't work, here... 08-23-2011, 12:51 AM
abqjohn It depends on how you're... 08-24-2011, 12:38 AM
joecnc2006 I have not seen any Klevoden... 11-13-2011, 07:02 PM
azinhak Jewelry Box Model 04-09-2013, 10:04 AM
azinhak Jewelry Box Model free... 04-09-2013, 10:05 AM
azinhak There is a wooden box in the... 04-09-2013, 10:07 AM
SosaCNC Re: Joe's CNC Model 2006 02-03-2016, 02:49 AM
Guest Re: Joe's CNC Model 2006 11-10-2016, 03:44 AM
thunterman Re: Joe's CNC Model 2006 11-10-2016, 12:43 PM
Guest Re: Joe's CNC Model 2006 11-10-2016, 02:27 PM
thunterman Re: Joe's CNC Model 2006 11-10-2016, 03:57 PM
Warhawk Re: Joe's CNC Model 2006 07-09-2019, 09:17 PM
pal7mentor34 Re: Joe's CNC Model 2006 06-26-2021, 03:29 PM
pdsseointern1 Re: Joe's CNC Model 2006 11-08-2022, 09:37 AM
ajay456 Re: Joe's CNC Model 2006 03-30-2025, 10:01 AM
Salty72 Joe, I have been looking for... 05-22-2007, 12:10 AM
joecnc2006 I believe JLT did the dust... 05-22-2007, 03:29 AM
mlabruyere Joe, Are you still selling... 05-15-2009, 07:12 PM
newsense2004 HAR THA, can you email me the... 06-25-2009, 04:25 AM
    Aug 2004
    3215
    I was busy the last couple days, drawing a new CNC, I have thought about what the flaws were on a Diy Pipe rail system most of us build in wood/MDF.
    I will be using a torsion box system, and also nave a new twist, by adding an extra Pipe rail on the long Axis. I think this will help alot on the twisting and rocking of the Gantry.
    Here are pictures of my drawings.
    Attached Thumbnails Attached Thumbnails Joes CNC Model 2007.jpg   Joes CNC Model 2007a.jpg   Joes CNC Model 2007b.jpg
  1. Two more of Joe's CNC Model 2006
    By JLT in forum Joes CNC Model 2006
    Last Post: 01-31-2019, 02:27 AM
  2. [AU] Joe's 2006 Model
    By nat.andrews in forum Joes CNC Model 2006
    Last Post: 11-11-2013, 11:50 AM
  3. Electronics for a Model 2006
    By joegtp in forum Joes CNC Model 2006
    Last Post: 08-31-2011, 04:43 PM
  4. New to Joe model 2006
    By Darroll in forum Joes CNC Model 2006
    Last Post: 01-16-2008, 11:31 PM
  5. JOES cnc MODEL 2006 R-1 or R-2???
    By Khalid in forum Joes CNC Model 2006
    Last Post: 11-11-2007, 06:58 PM
