603,344 active members*
3,658 visitors online*
    May 2015
    9
    Jogging Step - first step after continuous too big
    Hi everyone
    I have a problem. I have had to build a new Mach3 pc (XP was locking up) and now when I use my XBox controller to jog the first step is about 15 times what it should be.
    I have step set to 0.05mm but the first step after a continuous jog is about 0.7mm.
    Any ideas?
    Regards
    Bruce
    May 2015
    9
    Re: Jogging Step - first step after continuous too big
    Found it
    Joypad plugin 2.0.1 was causing this. reverted to 2.0 and problem solved
  1. newbie question on step by step cutting setup/ process in Mach3
    By Matt Clara in forum Mach Software (ArtSoft software)
    Last Post: 05-27-2014, 07:36 AM
  2. Step Jogging
    By Jason Marsha in forum Mach Software (ArtSoft software)
    Last Post: 02-19-2014, 09:55 PM
  3. Where to set STEP jogging speed?
    By alank2 in forum Mach Software (ArtSoft software)
    Last Post: 04-30-2012, 04:38 PM
  4. Replies: 3
    Last Post: 04-10-2010, 01:23 AM
  5. Step/Direction pins should be Step FWD and Step BACK
    By rayscott in forum Mach Software (ArtSoft software)
    Last Post: 02-10-2010, 12:57 AM
