587,157 active members*
3,053 visitors online*
Hybrid View
    Sep 2014
    7
    junkyard windmill
    Heres a idea that at first sovnds crazy but the more i think about it the more I like it . This would work on a ridge line , whese a short tower would be enough to get into clean air .we have all seen saviouios rotors oil drums cut in half , offset , and mounted veritacally not aerodynamicly very efficiant but that is not important thay have good doller per watt , work well at low wind speeds , and are not critical in design ( Its hard to get it wrong ) . Now imagin the same idea but substute intermodal shipping containers for the oil drums , asume free labor ( Ie. a barn raising ) , Cor-ten construction , and good fatigue properties of steel in general , with regular maintance the life time should be good and doller per watt low.
    Sep 2014
    7
    Re: junkyard windmill
    Been looking at containers and I think taking two containers removing the floor boards welding them togther facing oppsite directions and using some truck axel , wheel ,what not for the pivot with a flat belt rvnning around the wheel or just use the whole transaxel , There are a lot of home made farris wheels "Ruedo de Chicago" touring around central and south america that are built from old heavy duty trock parts like that .
    Nov 2014
    13
    This would work on a ridge line , whese a short tower would be enough to get into clean air .we have all seen saviouios rotors oil drums cut in half , offset , and mounted veritacally not aerodynamicly very efficiant but that is not important thay have good doller per watt , work well at low wind speeds.
  1. Open source Windmill design.
    By gavztheouch in forum Environmental / Alternate Energy
    Last Post: 06-28-2014, 11:58 AM
  2. Stragenmitsuko's junkyard router , an attempt
    By stragenmitsuko in forum CNC Wood Router Project Log
    Last Post: 10-11-2011, 10:44 AM
  3. miami Junkyard
    By Maxxxix in forum MetalWork Discussion
    Last Post: 07-14-2009, 04:14 PM
  4. making a windmill
    By pyroracing85 in forum Hobby Discussion
    Last Post: 03-09-2008, 01:26 PM
  5. a diy junkyard speacial pen plotter, hot cutter
    By wayword son in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 05-14-2007, 01:36 PM
