One Of Many said
“I don't see what benefit the recording tape is going to gain. Drip feed from a disk makes more sense.”
In MY world I would completely forget about using tape or any type of magnetic storage outside the original HD inside the computer. Once the signals and timing were recorded to EEProm Memory inside the “Black Box” then NO tape or disk would be involved. Yes, I did mention the DTMF to tape system, BUT that was only to show how it COULD done, NOT that it should be done that way. Tape schemes for any data storage are older than DINOSAUR BONES.
One Of Many said
”I'd doubt this to be realistic for servo systems which do use analog voltages. No servo amp would take this analog input and make use of it to maintain a consistant linear path velocity using stretchable tape? A home hobbyist is highly unlikely to make an analog converter from discrete semiconductors to drive servos direct with any kind of repeatability. Teddy Ruxpin style precision?
I agree with him 100% on the “stretchable tape” issue too many weak points in any tape system, I personally don’t care for any type of magnetic disk recording interface WAY too much “EMF” floating around in a shop with motors running and it’s all just waiting to attack your disk and scramble your data.
His “Teddy Ruxpin” brought to mind the world of “ANAMATRONICS” do a Google search for ”anamatronics” and “servo controller”, then add to that search “analog” and you end up finding things like
http://www.milinst.com/animatronics/1_965inst.pdf now to get analog add something like
http://www.milinst.com/animatronics/1_905.pdf and you’ll probably have to amplify / buffer that output but it looks like its there.
One Of Many said
“A home hobbyist is highly unlikely to make an analog converter from discrete semiconductors to drive servos direct with any kind of repeatability.”
I Highly disagree with this statement, if you are going to make that statement hold true then a statement such as
“A home hobbyist is highly unlikely to make a CNC system from discrete semiconductors and mechanical parts that will produce accurate parts with any kind of repeatability. “
would be just as valid of a statement. Never under estimate what a home shop hobbyist will do or is capable of doing, (some of the BEST Beer I ever drank came from home brewers) Apple Computer started in a garage, and if I’m not mistaken so did Microsoft at some level.
As an example of what people can and will do with electronics on a hobbyist level take a look at
http://www.seattlerobotics.org/
http://www.seattlerobotics.org/encoder/index.html
http://www.wa4dsy.net/robot/
Once again I’m not writing to make anyone mad or upset, just a interesting discussion that can hopefully help educate people to things they did not know were around and get the creative juices flowing.
Share your knowledge
Mike_L
