587,935 active members*
4,161 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Just wanted to show my troubles in the world of CNC
Results 1 to 10 of 10
    Jan 2011
    29
    Well I've been busy lately so I finally get home and start on my CNC retrofit of a Bridgeport series II interact. This morning I was testing out to see if my Main spindle motor was working.
    Powered everything up and a Faint "Hum" from the motor and no spin. Turns out I blew a fuse. Nothing big right? try again? same thing
    I start to Ohm out the phases in the motor....and find out one of the three phases is shot. Wonderful... SO I knew what I had to do, OFF WITH IT'S HEAD
    So I did and here's some pics of my adventures today.
    Attached Thumbnails Attached Thumbnails 2011-04-08_13-34-41_266.jpg   2011-04-08_13-35-35_998.jpg   2011-04-08_13-35-52_227.jpg   2011-04-08_14-12-19_556.jpg
    "Anything that can go wrong, will go wrong". {To Hell With Murphy FIX IT!}
    Jan 2011
    29
    So I'm sure I've done this wrong, I'm paraniod as hell about the speed control. The manual says I was supposed to turn on the spindle motor and run the RPM into the red then turn it off so the motor was proper position for motor removal. But my motor is inoperable so that was out of the question. SO if anyone has any nice words about how those go back together I'm all ears
    I hope the motor rewind place is open tomarrow...........
    MORE Pics!
    Attached Thumbnails Attached Thumbnails 2011-04-08_18-05-19_627.jpg   2011-04-08_18-05-54_500.jpg   2011-04-08_18-06-06_224.jpg   2011-04-08_18-06-36_172.jpg
    2011-04-08_18-06-45_859.jpg   2011-04-08_18-28-30_507.jpg   2011-04-08_18-28-41_270.jpg   2011-04-08_18-28-52_512.jpg
    Oct 2006
    181
    I also have a Bridgeport Series II Interact 2. It is an awesome machine. You will be happy once you fix it. I had to throw out the control and retrofit.
    Jan 2011
    29
    I know I used all your referance pics for digging into my machine. Also made a handy PDF printout of your photo manual (I bless you sir for posting it)
    Your machine was in so much better condition than mine, I am jealous of it but i'm "Learning" so much.
    Oh well At least by the end of all this I might know somthing about CNC equipment.
    Oct 2006
    181
    Good to hear. I was photographing that manual like a spy, I had two minutes.
    I would really like to get that PDF and post it on my website. Could you email it to [email protected], as a favor.
    i
    Sep 2010
    does anyone know if you can do letter writing useing the machine control on a bridgeport xr760 heidenhain control because up to now i,ve been generating one on cad cam and sending to machine, i cant beleive these state of the art machines havent got the ability to do this and a crappy hurco can
    Jan 2011
    29
    Haven't forgot about you ichudov I've seem to "misplaced" it lemme poke around abit more and I'll get it to you
    Oh and while I'm here Just threw the motor into the shop, 500$ bucks for a standard rewind and bearings, 600$ if the bearings are "Special".....Oh Yay!
    Well with any luck everything else will fricken work.
    Jan 2005
    15362
    Malzra
    No the bearings are not special, they are over charging you for them, you can get, these motors on ebay for much less then your repair
    Mactec54
    Apr 2010
    486
    I'm following this thread with great interest.
    Tom
    Jan 2011
    29
    Back again and I've got some new pictures of the reinstall of the (rebuilt) motor!
    Turns out all it needed was "cleaning" the factory that this came out of did not care about containing the flood coolant and it was a nasty type of flood coolant at that so much so that the motor was half filled up with caked in old coolant.
    So they did a good job making sure it worked like new and without further adew the pictures!
    Attached Thumbnails Attached Thumbnails 2011-04-23_11-54-53_406.jpg   2011-04-23_11-55-17_521.jpg   2011-04-23_12-14-37_97.jpg   2011-04-23_12-14-49_70.jpg
    2011-04-23_12-14-58_835.jpg   2011-04-23_12-15-32_324.jpg   2011-04-23_12-16-11_759.jpg   2011-04-23_13-02-51_441.jpg
    2011-04-23_13-02-59_140.jpg   2011-04-23_13-55-06_155.jpg   2011-04-23_13-55-32_802.jpg   2011-04-23_13-55-13_728.jpg
  1. X3 troubles
    By binfordw in forum Benchtop Machines
    Last Post: 09-06-2010, 02:29 PM
  2. MAX 100 troubles
    By matttargett4 in forum Hypertherm Plasma
    Last Post: 04-01-2010, 08:25 PM
  3. air troubles
    By wadetool in forum Haas Mills
    Last Post: 02-19-2007, 10:30 PM
  4. DXF troubles
    By kung in forum G-Code Programing
    Last Post: 11-02-2005, 10:41 PM
  5. CAD Troubles
    By Blackhawk in forum Uncategorised CAM Discussion
    Last Post: 06-12-2005, 04:13 AM
