588,496 active members*
4,663 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > "jword given for arc in xz plane line number xxx" ???
Results 1 to 6 of 6
    Jul 2008
    139
    Hi there,
    I tagged this problem on the bottom of a post I made in the Mach3 sub forum, but then figured it'd much more likely find a resolution here, as it's a G-Code query, *not* a MAch3 query!
    I've just built a CNC machine out of old dot matrix printer parts - I now have an X & Y plane moving around (Z plane to follow). Such is my keenness to see the fruits of my labour, I went for the the tried & tested 'strap a pen to the Z plane & start drawing stuff' approach!!
    I'd already knocked up a simple design in a cad program & saved it as a DXF file - I imported this DXF file into MACH3 & saved as G-Code (no errors when doing so). However when I come to start ,my CNC routing using the G-Code - it won't run...I see the error "jword given for arc in xz plane line number 10"
    Can anyone please help me (this has been a long path I've walked & I can see daylight at the end of the tunnel, but this one has me stumped!)
    Here's the fiull G-Code...
    G90G80G49
    G90.1
    G0 X3.9999 Y8.7351
    M3
    F1.000 G2 X3.9999 Y8.7351 I5.5499 j8.7351
    G0 X6.9999 Y2.7351
    F1.000 G2 X6.9999 Y14.7351 I6.9999 J8.7351
    G1 X74.9999 Y14.7351
    G2 X74.9999 Y2.7351 I74.9999 J8.7351
    G1 X6.9999 Y2.7351
    G0 X8.9999 Y8.7351
    F1.000 G2 X8.9999 Y8.7351 I9.9999 j8.7351
    G0 X12.0999 Y8.7351
    F1.000 G2 X12.0999 Y8.7351 I14.9999 j8.7351
    G0 X13.9999 Y14.7351
    F1.000G1 X67.9999 Y14.7351
    G2 X67.9999 Y2.7351 I67.9999 J8.7351
    G1 X13.9999 Y2.7351
    G2 X13.9999 Y14.7351 I13.9999 J8.7351
    G0 X14.9999 Y14.7351
    F1.000G1 X66.9999 Y14.7351
    G1 X66.9999 Y14.6511
    G0 X64.0999 Y8.7351
    F1.000 G2 X64.0999 Y8.7351 I66.9999 j8.7351
    G0 X70.9959 Y8.7351
    F1.000 G2 X70.9959 Y8.7351 I71.9959 j8.7351
    G0 X74.8999 Y8.7351
    F1.000 G2 X74.8999 Y8.7351 I76.4499 j8.7351
    G0 X53.6999 Y8.7351
    F1.000 G2 X53.6999 Y8.7351 I56.5999 j8.7351
    G0 X43.2999 Y8.7351
    F1.000 G2 X43.2999 Y8.7351 I46.1999 j8.7351
    G0 X32.8999 Y8.7351
    F1.000 G2 X32.8999 Y8.7351 I35.7999 j8.7351
    G0 X22.4999 Y8.7351
    F1.000 G2 X22.4999 Y8.7351 I25.3999 j8.7351
    G0 X14.9999 Y2.7351
    F1.000G1 X66.9999 Y2.7351
    M5M30
    (I've also attached the DXF file - if it helps!)
    It says "
    Attached Files Attached Files
    Jun 2004
    6618
    It loads up for me and runs okay except my machines are in inches. Check your IJ mode in Mach 3.
    Lee
    Jul 2008
    139
    Quote Originally Posted by LeeWay View Post
    Hello Lee...thank you for taking the trouble to try my G-code file. I will try to figure out what your solution means & apply accordingly!!
    Jun 2004
    6618
    It is under the general config tab.
    Lee
    Jul 2008
    139
    wow...great stuff Lee - thank you *so* much - I'll check this config screen outwhen I get home later today
    Many thanks for your excellent & speedy help.
    PS, I'm assuming the settings would be best set as per your screenshot?
    Jun 2004
    6618
    These settings work on all three of my machines.
    Lee
  1. Where is the "start from line"
    By mbinelo in forum LinuxCNC (formerly EMC2)
    Last Post: 08-13-2008, 05:11 AM
  2. "Bug Plane" ?????? error??
    By shnitzel in forum Mach Software (ArtSoft software)
    Last Post: 10-06-2007, 04:53 AM
  3. "tool slot number too large" code
    By dave6 in forum Mach Mill
    Last Post: 10-10-2006, 11:57 PM
  4. "Fancy" single line font
    By DAB_Design in forum G-Code Programing
    Last Post: 04-25-2005, 09:04 PM
  5. How to do 2 "IF" statements on the same line?
    By murphy625 in forum CamSoft Products
    Last Post: 04-02-2005, 02:28 AM
