603,884 active members*
5,600 visitors online*
Thread: k motion cnc
    Nov 2022
    4
    Post k motion cnc
    can help me about this error
    BAD VALUE ZX FOR PLANE IN SETUP FILE
    Nov 2011
    490
    Re: k motion cnc
    Hello, friend. For the "BAD VALUE ZX FOR PLANE" Error in K Motion CNC
    Cause: Invalid plane definition (e.g., ZX instead of standard G17/G18/G19).
    Solutions:
    Check G-code: Replace ZX with G18 (ZX plane) or stick to G17 (XY plane).
    Verify Setup File:
    Open .set file in KMotionCNC ? Tool Setup ? Advanced tab.
    Ensure correct Plane Selection (G17/G18/G19).
    Recreate Setup File if corrupted.
    For 3-axis mills: Use G17 (XY plane) unless ZX motion is required.
    https://www.elephant-cnc.com/
    E-mail: manager@elephant-cnc.com Web: www.elephant-cnc.com
    --------------Jinan Blue Elephant CNC Machinery Co., Ltd-------------
    May 2006
    4090
    Re: k motion cnc
    Did you really want to default to the ZX plane instead of the XY Plane?
    If so the program is expecting the .set file to have "XZ" not "ZX". The comment is incorrect. We will make a change to accept either "XZ" or "ZX" in the next Version.
    TK
    http://dynomotion.com
  1. Testing CNC Motion Controller (500KHz) DDCS V3 CNC Control
    By automationtechinc in forum Automation Technology Products
    Last Post: 06-13-2021, 08:10 PM
  2. Motion error 411 axis full power without motion
    By roreyes in forum Centroid CNC Control Products
    Last Post: 09-28-2019, 08:05 PM
  3. Replies: 0
    Last Post: 02-23-2019, 08:25 PM
  4. Mach3 Motion card XHC 5th MK4-V 4 AXIS mach3 cnc motion control breakout board
    By samnang39 in forum Automation Technology Products
    Last Post: 01-01-2017, 03:22 AM
