603,996 active members*
3,526 visitors online*
    Jan 2004
    668
    K2 Configuration and Mach 3
    Anybody running a K2 2514, with heavy duty steppers,3 amp, 3 volt, 253 oz 1.8 deg, with Mach 3 control. I have one and would appreciate a line by line configuration for Mach 3 configs. What I mean is the drop down list that Pins and Ports and the like are on. I've got something really off and can not seem to get it right. If you are running the same machine and it runs good, and smooth, and accurate, the numbers should be the same for all similar machines. I need to see what others configuration numbers are, and compare them to mine, and then make the appropriate changes. I have had the G code checked at the V Carve forum, but when I run it, the machine cuts air, or makes a pass a few thou above the part surface. Runs for a few lines and stops. I really have some issues here and need to see the numbers others have. HELP!!!
    SPEEDRE,
    Hi, call Mike at K2 Devices: 714-999-1156.
  1. Replies: 14
    Last Post: 01-15-2010, 02:06 PM
  2. MACH 3 USB INPUT CONFIGURATION
    By coremfg in forum Machines running Mach Software
    Last Post: 01-08-2008, 03:04 PM
  3. MACH 3 configuration Problems(Sherline)
    By MIAMIVICE in forum Benchtop Machines
    Last Post: 08-06-2007, 01:22 PM
  4. Confused: Mach Turn, Mach Mill, Mach 2/3 ?
    By CanSir in forum Mach Software (ArtSoft software)
    Last Post: 02-16-2007, 11:41 AM
  5. MACH 2 configuration for Xylotex Board
    By ngr1 in forum Mach Software (ArtSoft software)
    Last Post: 08-13-2004, 07:03 AM
