I have a keling 54v 13amp unregulated power supply with. It is a toroid transformer and a small rectifier board. When I first fired it up and tested it about a year ago it read +53.4, -53.4v and the common was about 28v. Now the supply reads +55.4v and -55.4v or close to that. What causes the voltage to change like that? The reason I ask is my board is 55v and I need to keep the voltage below that. Is there a way to lower the output voltage by just a couple of volts. I'm also wondering if I can add a fuse somewhere to protect against over voltage and over current? Any help or advice would be appreciated. Thanks
Judleroy
