Hello,
Sorry the pictures aren't great but there all I have on the computer right now I highlighted the mills control box in case some one can visual ID
I hoping you could help me with some information on my kempsmith #4 mill . It was originally a horizontal mill and at some point it was converted to a Vertical mill by adding a head to the upper most shaft. I have no manual or information for this mill but it has worked good for me so far but now I want to be able to do more metal work on a steady basis. Unfortunately I don't think I can make it CNC both because I personally can't understand how to convert it with out seeing one n person and two because My machine is way past oldI have several questions witch I will list below, also if anyone happens to have a down loadable manual you could email a link to that would be a great help.
1) on the left side there is a drive shaft that connect to a box under the table the box has a lever on it....... it appears (I assume) to be a automatic power feed for the table control I have been consider connecting the drive shaft for this and running a separate 1Hp motor to drive the belt . I still wounder though why they would have disconnected a power table where they just a pain in the but hopefully some has experience with this type of machine and can help answer this before I spend time and money to reconnect the unit
2) I know it is probably beyond both me and my machines but I'm curious what would is cost me roughly price wise to connect my ill and lathe to a low budget CNC system ?
* kempsmith #4 mill set up as vertical ?
* Atlas 12x36 lathe ?
