587,997 active members*
3,202 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Key Pad Repair and KeyBoard?
Results 1 to 4 of 4
    Jun 2005
    116
    Hi
    Key Pad
    I need to replace the key pad on the VMX42, but before I fork out $1000 plus Aus I thought I would see if anyone has successfully repaired one?
    I see there are several repair methods on the net such as using aluminium foil, conductive paints etc, but before trying it would be nice to know if anyone has carried a repair and how successful it was?
    Only one key is playing up at the moment.
    Keyboard (optional apparently)
    Lost a lot of time trying to program only to find out that when I touch certain F keys they jump a few times, eg when I am in program setup and I hit F2 it will bounce me past some key strokes.
    I started to think there was no Milling setup screen only drilling, I took the protective cover off the keys but it made no difference, to make it work I am making very definite careful key strokes and about every couple of goes I can get it right, very annoying?
    Is it possible to replace these keyboard with a simple industrial keypad?
    I cannot use the touch screen because it has been replaced with a non touch screen monitor although the original monitor touch screen part still works only too hard to get to it, the original screen is blacked out.
    I may try getting the new original repaired, as I have had one successfully repaired previously, although being US I had to supply a 240 to 110V transformer so they could power it up, not sure what voltage the Hurco screen is?
    Any advice greatly appreciated
    Best Regards
    Burgs
    Aug 2013
    89
    Re: Key Pad Repair and KeyBoard?
    What control does it have ? I am sure you could find parts for that on epay ?
    Jun 2005
    116
    Hi.
    Control is a Hurco WINMAX the single screen job 2005 year. Did the Ebay and internet thing and have had no success at this stage.
    Might just have to do a bit more paying work and buy from HURCO.
    Best regards
    Burgs
    Aug 2013
    89
    Good luck hope you can find something before you have to spend the big bucks.
  1. Technical Repair Solutions (Midwest USA): Industrial Electronic Machine Repair
    By TechnicalRepair in forum Manufacture Company Listing
    Last Post: 11-04-2014, 09:04 PM
  2. Replies: 2
    Last Post: 11-20-2013, 03:24 AM
  3. Fadal repair or not repair?
    By MCAD3D in forum DNC Problems and Solutions
    Last Post: 08-20-2013, 01:13 AM
  4. HEIDENHEIN CONTROLLER KEYBOARD REPAIR NEEDED
    By stuflo in forum Uncategorised MetalWorking Machines
    Last Post: 03-24-2013, 12:24 PM
  5. keyboard,,
    By billwe in forum Haas Mills
    Last Post: 04-29-2008, 02:57 AM
