603,848 active members*
3,675 visitors online*
Results 1 to 7 of 7
    Keyboard shortcuts for jog commands?
    I'd like to be able to set Z0 without touching the mouse. This way one hand could hold the feeler strip while the other hand cycles through the jog commands:
    1. the tab key would open the jog window.
    2. another key would set the jog mode to step.
    3. another key would set the cycle jog step increment.
    Is there a way to do this?
    Thanks,
    Charlie
    Aug 2006
    65
    Hey... Charlie you answered it your self, Now that you found tab key. set your key board in front of you as I do, and set it on 1.00 or .100 .010 .001 and hit your page down or page up if you went Z- too much, I hit the key with my left hand and I'am l sliding the block at what ever height you want to set the Z at with my right hand. SIMPLE STUFF. Charlie what are you making...
    9lrac9
    Aug 2006
    65
    Charlie... That's the safe way.
    9lrac9
    Mar 2003
    35494
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Aug 2006
    65
    Smile I Know...
    Just trying to keep it simple. After learning the 30000000000000000000000000...
    hot keys in MC9. In Mach 3 I try to not go nuts... Thank you ger21
    Aug 2006
    65
    And yes I have downloaded all 154 pages of Mach 3
    9lrac9
    Thanks for the responses.
    9Irac9, I'm making wooden ocarinas. Now you know as much as you did before...right? It's a type of musical instrument. If you're curious, you can see some of them on the following page from my website:
    http://hindocarina.com/sweet_potato.htm
    Charlie
  1. G2 and G3 Commands
    By Bohemund in forum G-Code Programing
    Last Post: 05-28-2007, 03:12 PM
  2. Difference between BL and SV commands?
    By Shizzlemah in forum Fadal
    Last Post: 03-23-2007, 02:33 PM
  3. VCarve Pro Shortcuts
    By dighsx in forum Vectric
    Last Post: 08-01-2006, 10:20 PM
  4. Thread commands on 6T control
    By Ricardo Guedes in forum Fanuc
    Last Post: 02-03-2006, 07:21 AM
  5. EMC & the G28/G30 Home commands
    By Javelin276 in forum LinuxCNC (formerly EMC2)
    Last Post: 07-18-2005, 09:13 PM
