588,563 active members*
5,024 visitors online*
Results 1 to 1 of 1
    Dec 2010
    634
    Kflop/G540 wiring check please
    I already posted this question on the Dynomotion Yahoo group but thought I'd post here for a few more eyes to have a look so Tom, no need to re-respond
    In the process, I'd really like to add encoders to my stepper system to be used in closed loop mode. If the homing between Mach 3 and Kmotion is similar, I may used the Mach 3 plug in in open loop or simply missed step mode while I'm getting used to Kmotion and then ultimately switch over to Kmotion once I have all of the macro functionality I have in Mach 3 replicated in Kmotion.
    I'm planning on adding 3 encoders, on the X,Y, and Z axes, either 2000 or 4000 line count depending on what I hear in terms of performance requirements. Encoders will be single ended wired directly into the Kflop as I simply can't afford something like a kanalog right now.
    The rest of my setup is based on a G540 with the standard parallel port wiring. Here's the wiring I intend on doing. The Kflop box will have a DB25 output that plugs into the G540 and then 3 additional connectors for the encoders. I might add an mpg into the kflop as well as I've gotten used to using the Shuttle express for certain machining operations.
    Could you guys have a look at this wiring setup and let me know if it looks pretty good?
    TIA
    -Andy
    Attached Files Attached Files
    -Andy B.
    http://www.birkonium.com CNC for Luthiers and Industry http://banduramaker.blogspot.com
  1. Quadrature encoder wiring with the KFlop
    By nova24 in forum Dynomotion/Kflop/Kanalog
    Last Post: 06-26-2015, 06:41 AM
  2. KFLOP and KSTEP Three Axis Wiring
    By Mick14 in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-20-2014, 12:49 AM
  3. how to use a G540 and KFlOp
    By johnyac in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-11-2014, 06:34 PM
  4. Another sPID, G540, and Mach wiring question for the wiring challenged..
    By adam_m in forum DIY CNC Router Table Machines
    Last Post: 01-02-2014, 01:29 AM
  5. help for wiring kflop to 3 CL stepper
    By fettah in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-22-2013, 11:21 PM
