587,259 active members*
2,911 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > KFlop Gecko G540 Sherline Lathe and Mill 4-axis setup
Results 1 to 6 of 6
    Apr 2013
    18
    All,
    As promised on a previous thread I've made an adapter for the Gecko G540 as well as sorting out the parameters required for the Sherline/Gecko package. I'm still working on the lathe and need to sort out the rotary encoder. The adapter is as simple as possible, connecting only the step and dir pins for the 4 axis of the gecko.
    REMEMBER TO DISABLE THE CHARGE PUMP ON THE G540 USING THE SWITCH if using this adapter board.
    I have now built and tested the boards, so am happy to release the board design files as open-source. Please don't sell the boards I've designed, check the license. The Eagle files can be downloaded here.
    I've written a little C Program that helps to configure the board. I found this most straightforward when testing as I'm not a mouse person so hate clicking things.
    Code:
    #include "KMotionDef.h"
    // Defines axis 0, 1, 2 as simple step dir outputs
    // enables them
    // sets them as an xyz coordinate system for GCode
    const int X=0, Y=1, Z=2, A=3;
    const double VEL=66000;
    const double ACCEL=160000;
    const double JERK=4e+006;
    const double PIDP=0, PIDI=0.01, PIDD=0;
    int main() {
    	FPGA(STEP_PULSE_LENGTH_ADD)=32+0x80;
    	ch0->InputMode=NO_INPUT_MODE;
    	ch0->OutputMode=STEP_DIR_MODE;
    	ch0->Vel=VEL;
    	ch0->Accel=ACCEL;
    	ch0->Jerk=JERK;
    	ch0->P=PIDP;
    	ch0->I=PIDI;
    	ch0->D=PIDD;
    	ch0->OutputChan0=X+8;
    	ch0->LimitSwitchOptions=0x100;
    	ch0->LimitSwitchNegBit=0;
    	ch0->LimitSwitchPosBit=0;
    	ch0->SoftLimitPos=1e+009;
    	ch0->SoftLimitNeg=-1e+009;
    	ch0->BacklashMode=BACKLASH_OFF;
    	ch0->BacklashAmount=0;
    	ch0->BacklashRate=0;
     	ch1->InputMode=NO_INPUT_MODE;
    	ch1->OutputMode=STEP_DIR_MODE;
    	ch1->Vel=VEL;
    	ch1->Accel=ACCEL;
    	ch1->Jerk=JERK;
    	ch1->P=PIDP;
    	ch1->I=PIDI;
    	ch1->D=PIDD;
    	ch1->OutputChan0=Y+8;
    	ch1->LimitSwitchOptions=0x100;
    	ch1->LimitSwitchNegBit=0;
    	ch1->LimitSwitchPosBit=0;
    	ch1->SoftLimitPos=1e+009;
    	ch1->SoftLimitNeg=-1e+009;
    	ch1->BacklashMode=BACKLASH_OFF;
    	ch1->BacklashAmount=0;
    	ch1->BacklashRate=0;
    	ch2->InputMode=NO_INPUT_MODE;
    	ch2->OutputMode=STEP_DIR_MODE;
    	ch2->Vel=VEL;
    	ch2->Accel=ACCEL;
    	ch2->Jerk=JERK;
    	ch2->P=PIDP;
    	ch2->I=PIDI;
    	ch2->D=PIDD;
    	ch2->OutputChan0=Z+8;
    	ch2->LimitSwitchOptions=0x100;
    	ch2->LimitSwitchNegBit=0;
    	ch2->LimitSwitchPosBit=0;
    	ch2->SoftLimitPos=1e+009;
    	ch2->SoftLimitNeg=-1e+009;
    	ch2->BacklashMode=BACKLASH_OFF;
    	ch2->BacklashAmount=0;
    	ch2->BacklashRate=0;
    	ch3->InputMode=NO_INPUT_MODE;
    	ch3->OutputMode=STEP_DIR_MODE;
    	ch3->Vel=VEL;
    	ch3->Accel=ACCEL;
    	ch3->Jerk=JERK;
    	ch3->P=PIDP;
    	ch3->I=PIDI;
    	ch3->D=PIDD;
    	ch3->OutputChan0=A+8;
    	ch3->LimitSwitchOptions=0x100;
    	ch3->LimitSwitchNegBit=0;
    	ch3->LimitSwitchPosBit=0;
    	ch3->SoftLimitPos=1e+009;
    	ch3->SoftLimitNeg=-1e+009;
    	ch3->BacklashMode=BACKLASH_OFF;
    	ch3->BacklashAmount=0;
    	ch3->BacklashRate=0;
        EnableAxisDest(X,0);
        EnableAxisDest(Y,0);
    	EnableAxisDest(Z,0);
    	EnableAxisDest(A,0);
    	DefineCoordSystem(X,Y,Z,A);
    	printf("4 Axis init done!\n");
        return 0;
    The Gecko G540 has 10 micro-steps. The Sherline supplied steppers have a 1.8 degree step angle. 360/1.8 = 200 steps * 10 micro-steps gives 2000 steps per revolution. Looking at the specs I can see the motors run out of steam above 2500 RPM, so I'll stick with 2000RPM with reasonable torque. So, 2000 RPM / 60 seconds * 2000 usteps = 66,666.6667 hz which is the VEL parameter in the code. My Sherline is metric with 1 rev = 1mm. So at 66KHz / 2000 usteps = 33 mm/s or 1980 mm/min
    Frankly moving at that speed on something as small as a sherline is almost pointless, but nice to know I can safely go way above the 25KHz limitation of my XP/Mach 3 machine
    Here are the Sherline stepper motor specs:
    Code:
         | Sherline P/N:         | 67127 (w/ DIN plug and flats of shaft) |
         |                       | 67130 (no plug, flats on shaft)        |
         | Manufacturer:         | NMB (Minebea Co. Ltd.)                 |
         | Mfg. P/N (Type):      | 23KM-K035-62V (double shaft)           |
         | Frame size:           | NEMA #23                               |
         | Step angle:           | 1.8°                                   |
         | Voltage:              | 3.2 V                                  |
         | Current:              | 2.0 A/Φ                                |
         | Resistance:           | 1.6 Ω/Φ                                |
         | Inductance:           | 3.6 mH/Φ                               |
         | Holding torque:       | 9.7 kg-cm                              |
         | Rotor inertia:        | 250 g-cm2                              |
         | Number of wire leads: | 6 (See color code diagram below)       |
         | Weight:               | 1.32 lb (0.6 Kg.)                      |
         | Length:               | 2.13" (54 mm)                          |
         | Shaft:                | Double ended, 1/4" dia.                |
    And here are the pinouts I've used for my adapter board:
    Code:
        | KFlop Pin | Kflop Note                                          | DB25 Pin | Gecko Note                                           |
        |         1 | VDD+3.3                                             |          |                                                      |
        |         2 | VDD+3.3                                             |          |                                                      |
        |         3 | VDD+12                                              |          |                                                      |
        |         4 | RESET                                               |          |                                                      |
        |         5 | IO44 GPIO (3.3V Only)                               |          |                                                      |
        |         6 | IO45 GPIO (3.3V Only)                               |          |                                                      |
        |         7 | IO0  GPIO (5v) or Encoder 0 Input Phase A           |          |                                                      |
        |         8 | IO1  GPIO (5v) or Encoder 0 Input Phase B           |          |                                                      |
        |         9 | IO2  GPIO (5v) or Encoder 1 Input Phase A           |          |                                                      |
        |        10 | IO3  GPIO (5v) or Encoder 1 Input Phase B           |          |                                                      |
        |        11 | IO4  GPIO (5v) or Encoder 2 Input Phase A           |          |                                                      |
        |        12 | IO5  GPIO (5v) or Encoder 2 Input Phase B           |          |                                                      |
        |        13 | IO6  GPIO (5v) or Encoder 3 Input Phase A           |          |                                                      |
        |        14 | IO7  GPIO (5v) or Encoder 3 Input Phase B           |          |                                                      |
        |           |                                                     |        1 | OUTPUT 2 (e.g. Coolant on Terminal blk #6)           |
        |        15 | IO8  GPIO (5v) or Axis 0 Home (or Step 0 output)    |        2 | X-Axis Step                                          |
        |        16 | IO9  GPIO (5v) or Axis 1 Home (or Dir  0 output)    |        3 | X-Axis Direction                                     |
        |        17 | IO10 GPIO (5v) or Axis 2 Home (or Step 1 output)    |        4 | Y-Axis Step                                          |
        |        18 | IO11 GPIO (5v) or Axis 3 Home (or Dir  1 output)    |        5 | Y-Axis Direction                                     |
        |        19 | IO12 GPIO (5v) or Axis 0 + Limit (or Step 2 output) |        6 | Z-Axis Step                                          |
        |        20 | IO13 GPIO (5v) or Axis 0 - Limit (or Dir  2 output) |        7 | Z-Axis Direction                                     |
        |        21 | IO14 GPIO (5v) or Axis 1 + Limit (or Step 3 output) |        8 | A-Axis Step                                          |
        |        22 | IO15 GPIO (5v) or Axis 1 - Limit (or Dir  3 output) |        9 | A-Axis Direction                                     |
        |           |                                                     |       10 | INPUT 1 (e.g. NC Limit sw on Terminal blk #1 to #12) |
        |           |                                                     |       11 | INPUT 2 (e.g. NC Limit sw on Terminal blk #2 to #12) |
        |           |                                                     |       12 | INPUT 3 (e.g. NC Limit sw on Terminal blk #3 to #12) |
        |           |                                                     |       13 | INPUT 4 (e.g. NC Limit sw on Terminal blk #4 to #12) |
        |           |                                                     |       14 | VFD PWM (50 hz)                                      |
        |           |                                                     |       15 | FAULT (input to PC)                                  |
        |           |                                                     |       16 | CHARGE PUMP (> 10kHz)                                |
        |           |                                                     |       17 | OUTPUT 1 (e.g. motor on Terminal blk #5)             |
        |           |                                                     | 18 to 25 | GND                                                  |
        |     23,24 | VDD+5                                               |          |                                                      |
        |     25,26 | GND                                                 |          |                                                      |
    I've had KMotion CNC running very well with my mill. I'll try and share the settings tomorrow for the 4-axis mill (with sherline rotary table). My next post will be some pictures and videos.
    - Paul (gresham . at . mediavisual . dot . com)
    Apr 2013
    18
    Re: KFlop Gecko G540 Sherline Lathe and Mill 4-axis setup
    The Prototype ... from this:
    To this ...
    My rather poor soldering ...
    Boards waiting to be soldered ...
    Apr 2013
    18
    Here's a grab of the Eagle schematic:
    Click the image or go here to download and I ask people to respectfully follow the license.
    Apr 2013
    18
    Deleted
    May 2006
    4047
    Hi Paul,
    Thanks for posting!
    Regards
    TK
    http://dynomotion.com
    Apr 2013
    18
    I thought I'd share the following backlash Information:
    As above, the G540 is ustepping at 2000 steps per rev. In my case my leadscrews are 1 rev per mm. On my lathe setup I measured 1.12 mm of backlash (Obviously I need to adjust the backlash nuts, but wanted to see if it works). I set the backlash rate to 6000 (this is just the speed of the backlash move, play with it until you feel comfortable),
    To set the backlash amount simply use the measured backlash 1.12mm x 2000 usteps per mm = 2240 steps of backlash.
  1. Gecko G540 Limit Switch Setup...
    By storm2313 in forum Gecko Drives
    Last Post: 12-14-2012, 12:26 PM
  2. CAM software setup for Sherline mill with 4th axis at an angle?
    By PaulMakesThings in forum Benchtop Machines
    Last Post: 10-18-2011, 03:12 AM
  3. Mach3/Gecko G540 setup questions
    By mlabruyere in forum Gecko Drives
    Last Post: 12-14-2009, 11:05 AM
  4. Wanted: Sherline or Similar CNC Mill/Lathe Setup
    By gerryv in forum Canadian Club House
    Last Post: 12-31-2007, 03:57 PM
  5. Sherline Ultimate 4-axis CNC Mill and Lathe Machine shop package
    By CorporalChaos in forum Benchtop Machines
    Last Post: 01-21-2006, 07:10 PM
