Re: Kflop spindle PWM control -10 + 10v
If the original spindle controller had ±10vdc analogue input, presumably this was for bi-directional control with 0v being 0rpm?
If so, inputting a -10v will be full rpm reverse?
Maybe you require Kanalog for bi-directional analogue control, especially if it has encoder feedback?
Also many of these drives have at-speed and zero speed outputs.
The up-to-speed is useful when M3/M4 is issued to wait for this input to prevent premature machining before the spindle is at speed.
Al.
Albert E.
