603,872 active members*
3,672 visitors online*
Results 1 to 10 of 10
    May 2017
    4
    kinematic calculations
    Im building a machine with an articulating spindal . I was reading the Mach3 manual and it says "if the machanism is like a robot arm or a hexapod, then Mach3 "will not" be able to control it because of the kinematic calculations that would be needed to relate the "tool"position in X,Y and Z coordinates to the lenght and rotation of the arms " is there a program that would solve this for me?
    Jun 2011
    692
    Re: kinematic calculations
    LinuxCNC (instead of Mach.)
    Apr 2014
    215
    Quote Originally Posted by skrubol View Post
    +1
    Jun 2013
    1041
    Dynomotions k- flop and k- motion CNC would also work well for this.
    Ben
    Sent from my E6810 using Tapatalk
    May 2017
    4
    Ok i've been reeding about linux cnc over the last few days and it sounds good Thank you
    I just have one question will it work with a -UC100- usb to parallel port
    Jan 2005
    1943
    Quote Originally Posted by jawnee View Post
    No it won't. USB is not an option with LinuxCNC. You can use mesa hardware though which is not too costly
    May 2017
    4
    No it won't. USB is not an option with LinuxCNC. You can use mesa hardware though which is not too costly[/QUOTE]
    Ok dam aney obe whant to buy a UC100..just kiding The mesa hardware is it cat5/ ethernet based that would be nice
    this rabit hole is geting deep thanks for the help
    Jan 2005
    1943
    I don't have experience with ethernet on LinuxCNC, but according to this: LinuxCNC Documentation Wiki: LinuxCNC Supported Hardware it does support ethernet. There are others on the forum that may have more information
    May 2017
    4
    I think ican get db25 port tha will fit PCIe x2 port on the alatepanda single board compcter will that work?
    Jun 2011
    692
    You'd need to do some research on the Lattepanda with LinuxCNC. Like Mach, LinuxCNC doesn't play nice with all hardware, especially as you get to more embedded stuff.
    You could try downloading the LinuxCNC live image and try booting the Latte from it on a USB stick and run the diagnostics, but no idea about getting a parallel port on it. Also not sure if the LattePanda would even work with one of the ethernet Mesa cards, as its ethernet may be a USB-Ethernet adapter, which I don't think can work with the realtime environment LinuxCNC needs.
  1. How to set G7 kinematic on DMU50 EVO
    By toneko in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 06-04-2025, 08:22 PM
  2. DMG65/KINEMATIC
    By urspro in forum Videos
    Last Post: 02-25-2018, 09:55 PM
  3. DMG 50 5 AXIS/ KINEMATIC
    Last Post: 02-21-2018, 12:29 AM
  4. Kinematic Models
    By One of Many in forum Mechanical Calculations/Engineering Design
    Last Post: 06-20-2006, 06:26 PM
