![Quote](images/misc/quote_icon.png)
Originally Posted by
ChsBrown
OK, I have the 6" KITAGAWA chock on the SL-10. It's only been on about three months. I can't get the drawtube nut to come loose. The operator's manual says the chuck has to be clamped,..... HELP!!!
PLEASE!!!!!
Clamped as you should find out when you read my post that thum31 linked you to.
It can be a real pain unscrewing the nut because if you are not careful you round off the corners of the slots in the nut. The trick I have discovered is to keep the wrench held in firmly with the turret, but not too firmly otherwise you trigger a Z servo overload.
Good luck,
