587,547 active members*
3,626 visitors online*
    Nov 2007
    6
    KL4030 quit - motor justs chatters in place
    Everything working fine on 3 axis router then Y axis jerks and chatters. Replaced unit and not its fine.
    System has only 3 to 4 hours of use. Checked V+, OK at 35.5VDC. Driving NEMA 23s at 3A.
    Guess its a bad 4030.
    Does anyone have info on replacing the drive transistors?
    Part numbers etc.
    Thanks,
    Dennis
    Jan 2013
    119
    thegeekineer
    If the driver failure was due to a manufacture defect, use the warranty.
    Be sure not to even remove the cover, as any attempt to fix it will void the warranty.
    As to replacement part numbers they are on the existing components.
    The replacement cost of the KL4030 driver is minimal compared to the time
    and expense you will have into maybe getting it to work correctly.
    Mike
  1. KL4030
    By nicotom in forum Automation Technology Products
    Last Post: 04-22-2013, 03:16 PM
  2. How to prepare a FADAL 3060 to transport form place to place
    By Swykore in forum CNC Machining Centers
    Last Post: 08-08-2011, 01:09 PM
  3. Help identifying this motor. Can this be used in place of a stepper?
    By joprinz in forum Stepper Motors / Drives
    Last Post: 01-29-2010, 01:40 AM
  4. Are the motor pulleys pressed in place?
    By Grego in forum Shopmaster/Shoptask
    Last Post: 11-01-2008, 02:50 PM
  5. New tool chatters.... easy way to dull end mills?
    By InspirationTool in forum Uncategorised MetalWorking Machines
    Last Post: 05-27-2007, 09:29 AM
