603,804 active members*
4,265 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > KM3P will not move X+
    Oct 2004
    173
    Hello All!!
    Just fired up my "new" KM3P and found a problem. All directions of movement work just fine except X+ direction. I moved it around in Y and Z in both directions but X will only move in the - direction. When homing the machine, Z axis homes fine but because X will not move in the + direction I get a "marker not found on X" error. Any suggestions on what it could be? Could there be a problem with the X+ limit switch that would cause that?
    Any suggestions would be appreciated!!
    Allen
    Oct 2004
    173
    Got it figured out... Bad board!!
    Allen
    Oct 2008
    42
    I can fix it
    Buddy
    www.amtsinc.com
  1. Km3p Ultimax 2
    By bertcnc in forum HURCO
    Last Post: 10-13-2020, 02:57 AM
  2. Km3p
    By rkonnen in forum HURCO
    Last Post: 08-02-2009, 02:54 PM
  3. Newbie needs help with KM3P
    By freak_brain in forum HURCO
    Last Post: 12-28-2008, 08:46 PM
  4. KM3P CRT test
    By winds1sj in forum HURCO
    Last Post: 12-23-2008, 05:15 PM
  5. Hurco KM3P HELP
    Last Post: 12-20-2008, 08:44 PM
