Hello fellow KFloppers,
It is likely that a lot of you follow the Yahoo forums as well so this may not be news, but in case there are kFlop users that only visit this CNCZone forum, I wanted to make a small anouncement::
MM is still under development, but is likely overkill for what most people want to do.
I have been doing a lot of Web development lately and naturally that led to me wanting to make an HTML based CNC controller!
So after a few late nights and weekends away from home I have what I belive to be a pretty much finished product to share with you all.
You can download the patch dlls for your KMotion428 install, the application .zip file and even the source code from here::
http://tech.groups.yahoo.com/group/D...ion%20CNC.net/
Other than tool path display and text editing, it has all the functionality of KMotionCNC and should be a very painless conversion as all the setup parameters are similar.
Mach users will need to adjust their jogging velocity parameters a little as KMotionCNC.net uses inches per second rather that inches per minute.
Happy to hear any feedback and feature requests.
-Brad Murry
