Greetings,
I searched the forums and did not find a solution, so I apologize if this has been asked before.
When I set the velocity and acceleration using the KMotion console or C code to the KFlop channels, it affects the G0 speed as expected.
But, the only way I can seem to increase the speed of the G1 commands is by increasing the counts per inch inside of the KMotionCNC, setting the velocity parameter right next to the counts / inch doesn’t seem to accomplish anything.
Does anyone know of a reason why the motor would not increase in speed when I adjust the velocity, but can keep being adjusted upwards in speed by changing the counts per inch?
Thanks very much in advance to anyone who can provide some insight.
