586,058 active members*
4,344 visitors online*
    Komo VR408 Fanuc O-M
    Good Day All,
    We have a Komo VR408 router with a Fanuc O-M controller. Recently a lightning strike hit out network toasting the PC connected to the router and also blowing the serial interface on the memory card. Per Fanuc tech support I bought a replacement card, matching the original part # A16B-2201-0101/09A.
    I installed this using all the original eeprom chips and got fuzzies on the screen. So I replugged them to the original card "delete-reset" the memory and hand entered the parameters. Now I'm having trouble entering some of the parameters (924) and the diagnostics....
    What am I missing? Also, if anyone has a similar machine, I'd be quite happy for your settings to compare against what Komo (eventually) sent me....
    This is my 1st experience w/ Fanuc, I do have some w/ Fagor 8025's and quite a lot w/ SIemens 840Di..
    Thanks in Advance,
    Sylvan
    Attached Thumbnails Attached Thumbnails IMG_3105.jpg   IMG_3112.jpg   IMG_3123.jpg
    Apr 2009
    108
    Re: Komo VR408 Fanuc O-M
    Did you enter the 900 parameters first after clearing the memory? After entering them you should cycle power and enter the remaining parameters.
    Here's something that I wrote up a few hundred years ago.
  1. Replies: 2
    Last Post: 03-29-2018, 07:17 PM
  2. Komo VR 408 CNC Router Fanuc O-MC Alarm 1190
    By IIGuns in forum Commercial CNC Wood Routers
    Last Post: 04-09-2016, 01:25 AM
  3. Komo VR 1605TT Router Fanuc, Circlular Arc Problems
    By machinster in forum Commercial CNC Wood Routers
    Last Post: 04-25-2014, 09:01 PM
  4. Fanuc O-M on Komo VR-508 Display Corruption
    By gwilkerson in forum Fanuc
    Last Post: 07-01-2011, 08:09 PM
  5. First machine - Komo?
    By pahvantpiper in forum Commercial CNC Wood Routers
    Last Post: 11-18-2009, 10:15 AM
