588,201 active members*
5,109 visitors online*
    Dec 2013
    3
    Krmx01 vs Krmx02
    Hello, I have few question on kronos robotics. krmx02 is the latest and it would be better of course. I see that the website provide upgrade to krmx02.
    Is it comparatively easy to upgrade from krmx01 ro 02?
    How about the resolution accuracy between these two? are they comparable?
    Thanks for your time
    Aug 2010
    686
    Re: Krmx01 vs Krmx02
    There is little comparison between the two machines. The KRMx01 is a hobby class machine. The KRMx02 is a production machine. While the KRMx01 has a theoretical higher accuracy this is generally not the case as the KRMx02 will hold its tolerances longer without tuning or changing components.
    Author of: The KRMx01 CNC Books, The KRMx02 CNC Books, The KRmc01 CNC Milling Machine Books, and Building the HANS Electric Gear Clock. All available at www.kronosrobotics.com
  1. krmx02 Questions?
    By motress in forum Uncategorised WoodWorking Machines
    Last Post: 08-18-2020, 11:38 PM
  2. Using KRMx02 to cut Bolts
    By msimpson99 in forum DIY CNC Router Table Machines
    Last Post: 10-26-2013, 10:05 PM
  3. KRMx02 CNC's Builds
    Last Post: 01-13-2013, 12:59 PM
  4. KRMx02 Support
    By msimpson99 in forum Uncategorised WoodWorking Machines
    Last Post: 08-30-2012, 07:31 PM
  5. KRMx02 Colors
    Last Post: 05-13-2012, 05:35 AM
