588,342 active members*
5,077 visitors online*
Results 1 to 5 of 5
    Mar 2003
    66
    Kurt DL600 Double Vise
    I just bought 2 Kurt DL 600 Twin Vises. It looks like the jaws only have a
    window of travel. The movable jaws will not fully close up on the fixed center
    jaws. Is this how the vise operates or do I have something wrong. It looks
    like each jaw will travel approx. 2.5".
    Thanks,
    Scott
    Mar 2003
    4826
    Usually these double vises have a special collar on one end of the screw which may have to be loosened off to allow the jaws to float into position when clamping different width objects. Indeed, this float collar should be adjusted to give a bit of slack so that the jaws can accommodate a slight discrepancy in part width. That way you won't get a surprise loose piece.
    Hope this helps. I have a cheaper clone vise which has about a 4" capacity in each side, but it will definitely close right up tight on both ends.
    First you get good, then you get fast. Then grouchiness sets in.
    Sep 2008
    229
    Only 6 years too late with this reply:
    The DL vices have two different lengths of swarf cover plate. You need the short ones to clamp small work.
    (it is a footnote on this drawing)
    http://www.kurtworkholding.com/image...ction-view.jpg
    Mar 2003
    66
    Thanks for the long awaited reply. I still have the vises. Do you have to buy the shorter covers or just remove the long ones to clamp smaller pieces?
    Thanks,
    scott
    Sep 2008
    229
    Quote Originally Posted by Fudd View Post
    I guess you have three options, according to budget and time. You could run without (the threads are all protected by seal), make some short ones (I think they are just flat plate) or buy some short ones for a surprisingly reasonable $8 http://www.kurtworkholding.com/doubl...1_75-l-en.html
    (Though I would ring the number on the DL600 page rather than assume the DL640 fits)
  1. Acupro Vise
    By kenlambert in forum MetalWork Discussion
    Last Post: 01-21-2005, 08:30 PM
  2. Cross Slide Vise Recommendation
    By edge in forum Uncategorised MetalWorking Machines
    Last Post: 07-24-2003, 08:15 AM
  3. Need vise advise LOL
    By cncadmin in forum Uncategorised MetalWorking Machines
    Last Post: 03-30-2003, 04:42 AM
