587,608 active members*
3,477 visitors online*
    Nov 2009
    16
    KX1 Owners LOOK!
    I'm about to go ahead and buy a kx1... everything I've read seems to be good but I need some real world expierence from people who own one or have used one.. For another 1500 dollars is the kx3 worth it for an inch more travel?
    May 2007
    1026
    I've considered a KX-1 but mainly because I don't have room for a KX-3. I think it adds a lot more than an inch of travel.
    One thing I like about my X2 DIY conversion is the ability to use Tormach Tooling System quick-change adapters. Now that I have a pneumatic drawbar (based on the Hoss design) I can switch tools in seconds--I can't tell you how nice that is. If you have a lathe, you could probably make your own in 1/2" size or make depth rings for your most common tools. If you can easily make your parts with just one tool this isn't such a big deal.
    Jun 2007
    3891
    if you have room and money, get the bigger machine.
    i have an early kx1, and its got many Z axis issues. the newer ones are better, but the Z saddle is still a bit too short and with the ball screw in the back it causes a lever effect when the z axis changes direction.
    other than that, its a rather decent and capable machine if its all you have room for.
  1. To all your sherline owners
    By nofx in forum Benchtop Machines
    Last Post: 06-11-2010, 02:36 PM
  2. Any LMS CNC owners out there?
    By slawsonb in forum Uncategorised MetalWorking Machines
    Last Post: 05-15-2010, 04:09 PM
  3. Question for NM-200 Owners?
    By wicked0ne in forum Novakon
    Last Post: 08-21-2009, 02:55 PM
  4. Any CS 250 Owners out there?
    By Polishpiper in forum Mori Seiki lathes
    Last Post: 06-15-2009, 11:40 AM
  5. Looking for Reichenbacher Owners
    By jgriffith66 in forum Commercial CNC Wood Routers
    Last Post: 11-15-2007, 10:42 AM
