587,999 active members*
3,197 visitors online*
Page 1 of 4 123
Results 1 to 20 of 65
    Oct 2007
    76
    Lightbulb L297 with MOSFET H-Bridge
    Hello Everyone,
    I have been using the L297/L298 based stepper drivers. So far it has worked perfect except for the fact that it can only provide Max 2A per phase to the Stepper. Somehow most of the High Torque Steppers are rated 5A and more. I did some reading over here and found a few people using the L297 to drive a MOSFET H-Bridge and thus providing Higher currents to the motor. However I am not able to find a scematic for the same.
    I hope someone can provide me guidance for the same. Any Schematic/Circuit idea/suggestions/opinions regarding the same is highly appreciated.
    Please Advice!
    Thank You,
    Joe!
    Jun 2008
    8
    Unipolar Stepper Motor Driver with Chopper Action, using an L297 driver IC http://www.pchilton.co.uk/index.php?..._stepperdriver
    Oct 2007
    76
    Thank You Almaz.
    I'm using steppers in Bipolar mode. I'm not very familiar working with discrete H-Bridges. Do you have a similar design for a Bipolar Stepper?
    Thank You!
    Joe
    Jul 2008
    411
    Quote Originally Posted by joprinz View Post
    Thank You Almaz.
    Thank You!
    Joe
    Joe, I am also working on a design for using L297 or LS7290 (if I can get some) with discrete MOSFETs. The LS7290 datasheet shows an example using LS6203 drivers which is good to 4A but I am looking at using hi/lo side drivers and some gating logic to replicate the internal functions of the LS6203 with discrete parts to get to 6 or 8A eventually.
    I've not found any working schematics either...
    Oct 2007
    76
    Lightbulb
    Quote Originally Posted by irving2008 View Post
    Hello Irving,
    Well, i got my hands on the LS7290 thinking it would provide me Micro Stepping. But there is an issue with the LS7290 chip with its Micro Stepping Mode.
    Here is the Tech Note they sent me:
    Duty Cycles of active-low Outputs, INH1/ & INH2/:
    The duty cycles of INH1/ and INH2/ outputs are fixed per table 2 of the LS7290 datasheet.
    The SENSE1 and SENSE2 inputs are provided for over-current protection only, not for chopping control of the drive outputs.
    In any stepping mode other than the full-step and the half-step modes, if the inhibit outputs are truncated due to the SENSE inputs reaching the VREF level, the fixed duty cycle ratios of the INH1/ and the INH2/ will be disrupted leading to motor misstep.
    Therefore, in modes other than the full-step and half-step, the SENSE1 and SENSE2 inputs should be tied to ground and the VREF input should be tied to the positive rail. Under these circumstances, if over-current becomes an issue, it can only be resolved by lowering the motor supply voltage.
    In the full-step and the half-step modes however, since the fixed duty cycle ratios for the two inhibit outputs are 100%-0% and 70.7%-70.7%, the SENSE inputs can be utilized for chopping the INH1/ and INH2/ outputs, without disrupting the duty cycle ratio. Therefore, in full and half step modes SENSE input chopping can be used for motor current regulation.
    When the SENSE inputs are used for output chopping, the INH1/ and the INH2/ outputs are terminated (switched low) when the corresponding SENSE input becomes equal to the VREF. The maximum voltage at VREF= 3V, when chopping is used.
    For fixed PWM, the duty cycles in table2 are adjusted within a 32us window based on 8MHz clock. For reference, this will translate to 22.6us on and 9.4us off for a 70.7% duty cycle.
    For most applications its best to run the Steppers at a Higher Voltage than the rated Motor voltage to get Higher torque values at higher rpms. And I guess the LS7290 is not suited for High Voltage driving in Microstepping mode. Full Step and Half step can be achieved by just using the tried and tested L297 itself. So I think for a CNC application using the LS7290 is not a good idea (Jus my opinion).
    And as far as the MOSFET Drive circuit for L297 is concerned I think the Unipolar version is available in the LS7290 Datasheet itself. But I have very little experience in working with Discrete MOSFETS. But I'm sure there are plenty of experienced people here, who could modify the Unipolar design to a Bipolar setup with ease.
    Here is the LS7290 Datasheet.. Please check Page No: 7 for a MOSFET driven Unipolar setup.
    Hope someone can help us with this...
    Thank You,
    Joe!
    Jul 2008
    411
    Joe...
    Hmmm thats disappointing, as I just asked for some samples. Did you get a sample or paid for it (and if so, how much?).
    I wonder if the solution to the chopping is to add an external chopper such as the L6506
    Oct 2007
    76
    Lightbulb
    Irving...
    well I think you should be able to get samples...There is a Sample Form on the LSI/CSI site. But i got it from someone who had imported a couple of hundred of them. I got 5 of them for about 8USD each... its almost double the wholesale price on them (I think the wholesale is about 4USD if U buy about 100 chips) but i just wanted to experiment with them before i order big numbers... So I guess the price was ok...
    n Yes...it is a lil disappointing. I was soo excited to have Finally found THE ANSWER to My MicroStepping Needs. Like you said we could probably use the L6506 but again that be jus adding one more stage into the design. I personally think the lesser the number of stages the better.
    n btw have U checked the new L6205/6 Dual H-Bridges from ST??? They are rated 2.8A but they can be run in parallel to get 5.6A. if you don wanna go beyond 5A i think the L6205/6 would be sufficient.
    But finding a MOSFET H-Bridge design to work with the L297 would be still a Better Solution. I wonder Y noone seems to be interested in doing that even though the need for a Bipolar driver above 5A is quite Big considering everyone using Bigger NEMA 34 and above Steppers offlate...
    Joe!
    Jul 2008
    411
    Irving...
    Joe!
    Joe,
    I checked out the L6205/6/7 and they are indeed better suited to being paralleled up for 5A but higher than that requires a discrete solution. I would look at using something like four L6387E hi/lo drivers with some gating logic (needs 8 AND gates and 4 inverters), although there are other variants of the 6387 that might be better because they use less logic gates. The 6387 will drive just about any MOSFET you can find.
    The 6205/6/7 aren't new by the way, they date back to 2003 although the data sheet just had a revamp.
    rgds
    Irving..
    Sep 2010
    hey joe,
    I am too desperately looking for l297 and mosfet based h bridge driver,if you get any useful schematic please let me know.
    Jitender singh
    May 2010
    L6205/6/7 is not a multiwatt package. How do you heatsink it?
    I still prefer L6203. It provides 4A RMS current, 5A peak current.
    Jun 2008
    66
    Quote Originally Posted by jit_singh_tara View Post
    ... I am too desperately looking for l297 and mosfet based h bridge driver,if you get any useful schematic please let me know...
    In Russia, collected under the scheme CNCMASTERKIT Forums-viewtopic-L297-IRFZ (who is its author - I do not know). Reviews of the work - positive.
    Unfortunately, the ZIP-archive (3,3Mb - Scheme (Splan7), PCB (Sprint Layout 5) & Photo device) was unable to load here on the forum. Perhaps here we obtain Скачать файл - ХоÑ�тинг файлов - хранение файлов, беÑ�платный файлообменни� �º CncFiles
    Oct 2010
    448
    Well, seems to be lots of talk about all kinds of stuff that is available but impossible to locate a schematic that doesn't require hard to find components or assembly equipment not available to the average user and most of what is available is really unsuitable for general use when it has a limiting use factor based on the design.
    The best concept for the CNC world seems to be a modular design and if you stick with discreet components you can build a driver for almost nothing.
    If some one can provide a schematic (tried and true) that uses discreet components.
    I am willing to consider producing a PCB and making it readily available at a reasonable price which will become property of CNCZone if someone can provide such a schematic.
    The circuit must be for a bipolar (4 or 8 wire motor), support home, limit, dir, step and provide some current/voltage adjustment/protection.
    The use of discreet components makes building the driver relatively inexpensive and allows a means of increasing current capacity by the addition of output transistors which would affect the overall cost by very little.
    The posted russian schematic is something along that lines which can be made into a high-current capable device with little work but it needs some minor tweaks to provide the home, limit and protection so if someone has built this device we need to talk.
    Sep 2008
    27
    Well, I really don`t know if this can help them : this is an Bipolar stepper driver 4A - 42V for 1 ax. This drive uses a couple of h bridges (L6203) but it dont provide some current/voltage adjustment/protection -I don’t have tested this board -
    Stepper driver board with L297 and L6203
    Attached Thumbnails Attached Thumbnails schema[1].gif   pcb-foto[1].jpg   totalekaart-groot.jpg
    Mar 2007
    2083
    hi Joe ,
    has any one used 1 x L 297 and 2 x L 298
    to drive the stepper motor
    one L298 ic used for each coil
    channels 1 + 4 and 2 + 3 , paralleled
    John
    Sep 2009
    29
    "The circuit must be for a bipolar (4 or 8 wire motor), support home, limit, dir, step and provide some current/voltage adjustment/protection."
    Can you please elaborate on the switches? This is normally handled at the software level, ie by Mach3?
    motor stepper driver
    Quote Originally Posted by john_100 View Post
    hi Joe ,
    to dive the stepper motor
    John
    Hello I'm newbie in CNC zone
    I have little experience in making CNC, but I have more in stepper driver...
    my first project:
    one L297 + one L298 to drive 2 phase bipolar (4 wire) motor stepper.
    result = good
    second project :
    one Atmega8 + one L298 to drive 2 phase bipolar (4 wire) motor stepper.
    result = good
    third project :
    one atmega8 + two L298 to drive 5 phase bipolar pentagon (5 wire) motor stepper. ---> full step mode
    result = good
    fourth project
    one atmega8 + three L298 to drive 5 phase bipolar pentagon (5 wire) motor stepper.----> full and half step mode
    result = best
    Some of this project are written on my blog
    www.nastelroy.wordpress.com
    http://www.nastelroy.wordpress.com/2...river-pentagon
    I hope that will be a useful information.
    Now I have some problem to make this driver with microstepping mode. And still cooking how to do it...
  17. #17
    Sep 2009
    29
    OK. Having read through the LS7290 datasheet, I now see that it does not provide any real benefit over the L297. The LS7290, as others have pointed out, does not do Microstepping and chopping concurrently and chopping, however awkward, is often needed to get the required speed out of the motors.
    That being said, I would probably consider the LS7290 for a full/half-step design, since it lets you control the blanking time digitally. This helps reduce squeal from the motors.
  18. #18
    May 2010
    Quote Originally Posted by nastelroy View Post
    second project :
    result = good
    Welcome to CNCZONE.
    I'm interested about your 2nd project. Did you do the current control in this project?
  19. #19
    Quote Originally Posted by leaveme View Post
    Welcome to CNCZONE.
    I didn't do that yet...I just emulate Atmega8 as L297. So the current is still constant.
    But I will do this method in my last project (for 5 phase 5 wire pentagon stepper)...there are no chip that support microstepping for my motor stepper.
    If you want make microstepping driver for 2 phase bipolar, there are so many chip that support this. Such as A3967SLB, A3977, etc
    Have a nice Day
  20. #20
    Oct 2010
    448
    Have a nice Day
    None of those chips handle any real current, if it doesn't support at least 5A continuous then it's consider a toy driver.
Page 1 of 4 123
  1. Best MOSFET Driver and MOSFET choice for an H-Bridge Stepper Driver?
    By joprinz in forum CNC Machine Related Electronics
    Last Post: 04-28-2011, 09:57 AM
  2. L297+IRL mosfet
    By manmardam in forum Stepper Motors / Drives
    Last Post: 08-31-2009, 09:30 PM
  3. higher current h-bridge l297/l298
    By amplexus in forum Open Source Controller Boards
    Last Post: 01-21-2009, 03:43 AM
  4. L297 - opto - MOSFET
    By outside in forum CNC Machine Related Electronics
    Last Post: 11-03-2008, 04:38 PM
  5. mosfet h-bridge design
    By visky in forum CNC Machine Related Electronics
    Last Post: 06-11-2008, 09:51 PM
