603,545 active members*
2,332 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Language Problem (Brother TC-225 CNC Vertical Machining Center)
Results 1 to 5 of 5
    Nov 2011
    28
    Hello,
    I have Brother TC-225 CNC Vertical Machining Center, the operational program is in German language (display language), is it possible that I can change it to English language instead of German, your help is very important
    Regards
    Nov 2012
    29
    Re: Language Problem (Brother TC-225 CNC Vertical Machining Center)
    On my TC-229 I can change the language by setting special parameter. Download a manual for tc-215/225, you will find there instructions.
    I've got a Brother TC-225 with CNC-400 conversational control. I've read manual cover to cover but still struggling with milling a .500" dia. hole with a .3125" dia Endmill. Any help or pics would be great.
    Sent from my SM-G950U using Tapatalk
    Feb 2020
    8
    Quote Originally Posted by John1987 View Post
    Can you help me how I change language of brother tc 201 cnc machine also its have brother cnc 510 control
    Feb 2020
    8
    Quote Originally Posted by Johneezreno View Post
    I need help about brother tc 201 machine
  1. BMC 20, Ultimax Vertical Machining center
    By Mahmoud_hola in forum HURCO
    Last Post: 03-17-2015, 11:56 PM
  2. MHP-30 Vertical Machining Center
    By gearmachinist in forum HURCO
    Last Post: 07-16-2014, 03:50 AM
  3. Horizontal vs Vertical Machining Center
    By B.Reilly in forum Uncategorised MetalWorking Machines
    Last Post: 07-27-2011, 08:09 PM
  4. Beaver VC 15 Vertical Machining Center
    By MACHINEYARD in forum Uncategorised MetalWorking Machines
    Last Post: 11-11-2008, 08:40 AM
  5. CNC Vertical machining center
    By soumen in forum Mori Seiki lathes
    Last Post: 03-11-2008, 03:06 PM
