603,350 active members*
4,837 visitors online*
Results 1 to 6 of 6
    Laser alignment system for plasma cutter
    I recently added on a laser alignment system for my Precision Plasma table. I took a drill press laser alignment kit and modified it a little to work with my plasma system. It took about 15 minutes to make the mods and get everything hooked up.
    I drilled an tapped a couple of small holes in the plasma torch mount so that I could lock down the laser system. The laser system was nearly a perfect fit. It was a little too thin for a perfect fit. I used some foam with a thickness of .19 and cut it too fit on top of the laser system.
    This made the system a perfect snug fit. The screws keep things aligned and allow repeat-ability if the mount is removed and re-installed.
    The system was easy to align. While a laser is not needed its a neat tool add on for $30 bucks that makes aligning a starting point a little easier, and in the rare case things get messed up during a cut, with pin point cross hairs you can get back to a known point.
    I saw some other commercial products from $70 - $199 going to give this a try and see how it works.
    Desert Fabworks LLC -Fort Mohave, Arizona
    www.desertfabworks.com - Project Sites: www.cncplasmabuild.com - www.cncrouterbuild.com
    Sep 2013
    326
    Very neat! Can you tell us fellow iPlasma'nites where you purchased it from? Link or a stock # appreciated. I'll pop $30 for that easy!
    I appologize for not putting the info into the first post. I got mine at WoodCraft.com Here is a direct link to the page: Buy WoodRiver Universal Drill Press Laser Attachment at Woodcraft
    The laser is a woodriver item number # 152577. Checking the current prices it has gone up to $45.00 maybe because of Obama Care but still a decent price.
    Woodcraft has coupons from time to time and you may be able to snag it cheaper.
    Jun 2011
    6
    @rescueweasel - Just curious how your laser(s) are holding up being subjected to a plasma cutting environment?
    Jun 2004
    6618
    I had the same on my mill for awhile. It worked quite well on there even with coolant and chips getting on the lens. When I installed better lighting, it was a little more difficult to see, but still usable. When I had to replace my spindle bearings, I just never re installed it. They are easy to align and give good accuracy though.
    Lee
    Quote Originally Posted by JB4x4 View Post
    Sorry for the delay in writing the notification got sent to spam. So far things are working great. I wipe off the lens area when I'm done cutting for the day with plexis and a microfiber cloth and so far so good. Been using it several months now.
  1. CNC Laser cutter versus CNC Plasma cutter?
    By squale in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-24-2020, 02:14 AM
  2. Laser alignment of machine ways, cheap DIY system possible?
    By Apples in forum MetalWork Discussion
    Last Post: 04-02-2019, 08:29 AM
  3. CNC Plasma Cutter, Laser Cutter, Water Jet
    By antsals in forum Waterjet General Topics
    Last Post: 03-11-2011, 01:56 PM
